morphema
Audience network setup with wifi-qcom-ac
Mon Feb 26, 2024 1:31 pm
Hey folks!
I'm trying to configure two Mikrotik Audiences (7.13.5) with the wifiwave2 package. However, I have had limited luck with the CAP setup. Here is what I did step by step:
  1. Installed the wifi-qcom-ac package on the primary device and reset the configuration.
  2. I added rules for wlan1 (2ghz) and wlan2 (5ghz) and enabled capsman on wlan3
  3. I created AP on wlan3 with a hidden SSID.
  4. I could see and use both WiFi networks on my devices at this step
  5. Then I took the second Audience device, installed a new package, reset the configuration in CAPs mode, and connected it to the primary device via Ethernet.
This cap got IP via Ethernet, so I connected to the admin panel and configured wlan3 as a Station. I'm unsure if this is a proper mode, but both wlan1 and wlan2 on CAP became provisioned via CAPSMAN.
I was glad everything seemed to work, and I disconnected the ethernet cable from the CAP device. After that, I saw a bizarre thing — both interfaces on CAP are still provisioned by Capsman, but CAP doesn't receive an IP address. I cannot connect to the admin panel anymore.
I want to underline that I didn't create any datapaths on both devices, so their wlan3 networks are not in any bridge. If I add wlan3 in bridge on any device, provisioning stops on CAP. I also didn't change any firewall rules.
Please let me know what I could overlook.
morphema
Re: Audience network setup with wifi-qcom-ac
Wed Feb 28, 2024 3:17 pm
Problem solved. CAP mode on Audience devices seems to be broken.
Users browsing this forum: Pilo2710 and 24 guests
