Hi all,
I'm using a roterboard with two WANS and two bridges. Each bridge is configured to bo connected to one of the WANS, so that bridge A (with local IP 10.1.50.1) is connected to WAN 1 and bridge B (with local IP 10.1.60.1) is connected to WAN 2.
Everything works fine, clients connected to the LAN A (10.1.50.0/24) are connected to internet through WAN 1, and so for LAN B (10.1.60.0/24) and WAN 2.
The point are the DNS servers. At the moment, the two DHCP servers of the two bridges are configured to give 8.8.8.8 and 208.67.222.222 as DHCP servers.
I would like to have the clients of the LAN A refer to a DNS like 10.1.50.1 and the clients of the LAN B 10.1.60.1, using the routerboard to manage the DNS so that I can use static DNS entries to address different manchines on the two LAN.
It is possible with just one router?
Thank you!
Denis
