I have had now two different RB4011 routers running 7.12.1 that have had ports 1-5 (same switch chip) go offline for seemingly no reason in the last 3 weeks. A reboot of the router fixes it.
Base configs are the same on each, but the port configuration is different and one is running OSPF and the other is just static routing. One switch has a bridge for ports 1-2 but the other has no bridges have been created on ports 1-5.
Is there a known issue with RB4011 and ROS7? What happens is I get an alert from the router that ports 1,2,3,4,5 go to ethernet down at the same time. No other errors reported in the logs.
