BTW after my fix my router looks like:
https://ibb.co/n7r6QXv
i.e.
1. I used special double side scotch for heatsinks
2. Yes, I made "support leg" using thick scotch like Mikrotik's do due to no choice, you can see it.
3. I replaced original plate pin heat sink with square pin one with about same area. Why? It better for airflow (original is placed at 45grad to fan, may be they, designers, tried turn airflow to ventilation holes on the left? Can't say. But after replacing heatsink temperature actually becomes few degrees lower (may be also because I fix heatsink better than it was before %))
4. I replaced fan to Noctua one. I know that it performance is less comparing to the original fan (last one is very loud), I even bought 2nd fan and thought install it on left or rear side but after few weeks of usage I see that I needn't to do this, router is not hot and is very quite %) (it is used mainly as 2.5G VLAN desktop switch)
5. I noted to never put this router in vertical position %)
