alexv305
VRRP Sync Connection Tracking not working without bridge
Thu Feb 29, 2024 2:02 am
Hello, I am not sure if this is a bug..
I have two Mikrotik Hex S running Router OS v7.13.5.
I have setup VRRP before and it worked fine.
But Recently I discovered when enabling VRRP directly on eth interface such as eth3 (on both sides), the sync connection tracking option only works initially and then doesnt sync connections anymore.
When I add eth3 to a bridge and put the VRRP interface in a bridge on both sides, the sync connection tracking works as intended.
Scenario 1: (sync stops after initial sync)
MikrotikRTR1 ETH3 to Cisco Switch Port 1 (same VLAN on both ports)
MikrotikRTR2 ETH3 to Cisco Switch Port 2 (same VLAN on both ports)
Scenario 2: (sync works as intended)
MikrotikRTR1 ETH3(in bridge1) to Cisco Switch Port 1 (same VLAN on both ports)
MikrotikRTR2 ETH3(in bridge1) to Cisco Switch Port 2 (same VLAN on both ports)
Am I doing something wrong?
Users browsing this forum: Amazon [Bot], Bing [Bot], ggwp, gotsprings and 32 guests
