EdPa
v7.14.3 [stable] is released!
Thu Feb 29, 2024 4:57 pm
RouterOS version 7.14 have been released in the "v7 stable" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.14.3 (2024-Apr-17 15:47):
*) bgp - correctly synchronize input.accept-nlri address list;
*) bridge - use default "edge=auto" for dynamically bridged interfaces (PPP, VPLS, WDS);
*) disk - improved system stability;
*) fetch - fixed slow throughput due to "raw" logging which occurred even when not listening to the topic (introduced in v7.13);
*) queue - improved system stability (introduced in v7.6);
*) wifi-qcom - added configuration.distance setting to enable operation over multi-kilometer distances (CLI only);
What's new in 7.14.2 (2024-Mar-27 09:48):
*) defconf - do not override default DHCP server lease time;
*) defconf - fixed 5ghz-ax channel width for L11, L22 devices;
*) ethernet - fixed interface disable for CRS326-4C+20G+2Q;
*) ethernet - improved port speed downshift functionality for CRS326-4C+20G+2Q;
*) leds - fixed LEDs for L22 device;
*) lte - fixed firmware upgrade not found issue for Chateau LTE12 (introduced in v7.14.1);
*) ssh - require "policy" user policy when adding public key;
*) timezone - updated timezone information from "tzdata2024a" release;
*) traffic-flow - improved system stability;
*) vrf - fixed VRF interfaces being moved to main table after reboot (introduced in v7.14);
What's new in 7.14.1 (2024-Mar-08 14:50):
*) bgp-vpn - use VRF interface as gateway for leaked connected routes;
*) chr - fixed Xen and Vultr missing ethernet (introduced in v7.14);
*) chr - fixed bogus messages printed out while booting up the system (introduced in v7.14);
*) console - fixed do/while implementation not working with variables (introduced in v7.14);
*) ethernet - fixed default names for CRS310-8G+2S+ device (introduced in v7.14);
*) lte - fixed R11e-LTE-US modem dial-up;
*) sfp - improved system stability for CR2004-1G-2XS-PCIe (introduced in v7.14);
*) wireguard - do not attempt to connect to peer without specified endpoint-address;
What's new in 7.14 (2024-Feb-29 09:10):
!) rose-storage - moved SMB service to the RouterOS bundle;
!) smb - removed legacy SMB service (replaced with newer and faster ROSE SMB service, compatible with SMB 2.1, SMB 3.0 and SMB 3.1.1);
*) 6to4 - make "ipsec-secret" sensitive parameter;
*) api - improved REST API stability when processing invalid requests;
*) api - properly return SNMP OIDs when requested;
*) arm - improved system stability when using microSD on RB1100Dx4;
*) arp - added ARP status;
*) bgp - allow to leak routes between local VRFs;
*) bridge - added MLAG support for MSTP bridges;
*) bridge - avoid per-VLAN host flushing on HW offloaded bridge;
*) bridge - fixed auto "path-cost" for bonding interfaces (introduced in v7.13);
*) bridge - fixed MLAG connection after peer-link flap (introduced in v7.13);
*) bridge - fixed packet forwarding after changing HW offloaded bridge interface settings in certain cases (introduced in v7.13);
*) bridge - improved bridge VLAN configuration validation;
*) bridge - improved configuration speed on large VLAN setups;
*) bridge - improved protocol-mode MSTP functionality;
*) bridge - improved protocol-mode STP and RSTP functionality;
*) bridge - make "point-to-point=yes" default value for non-wireless bridge ports;
*) bridge - removed "mst-config-digest" from MSTI menu;
*) bridge - try to set wireless bridge ports as edge ports automatically;
*) bth - added simple "Back To Home Users" manager under IP/Cloud menu;
*) calea - improved system stability when adding bridge rule without "calea" package installed;
*) certificate - improved certificate validation performance;
*) console - added ":tolf" and ":tocrlf" commands for converting line break to/from LF or CRLF;
*) console - added "show-at-cli-login" option to display a note before telnet login;
*) console - added missing "where" clause for "/ipv6/firewall/filter" table print command;
*) console - do not accept negative or too large values for ":delay" command;
*) console - do not allow to use out-of-range values for time type fields;
*) console - fix configuration export when user does not have a "sniff" policy;
*) console - fixed delayed output from ":grep" command in certain cases;
*) console - fixed incorrect behavior of ":onerror" command in certain cases;
*) console - hint on reset command help that ".rsc file" is required for "run-after-reset" parameter;
*) console - improved editor functionality in full screen mode;
*) console - improved stability when using autocomplete with "export";
*) console - increased maximum file content length that can be managed through command line to 60 KB;
*) console - updated copyright notice;
*) container - improved VETH interface management responsiveness and reliability;
*) container - restrict "/container/shell" menu for users without "write" permissions;
*) defconf - added log about configuration reset due to pressed reset button;
*) defconf - fixed Audience scanning-for-wps-ap timeout;
*) defconf - fixed configuration script on KNOT devices if "ppp-out" interface is removed;
*) defconf - fixed firewall rule for IPv6 UDP traceroute;
*) defconf - fixed wifi configuration if interface MAC address is changed;
*) defconf - improved wifi interface detection after upgrade;
*) defconf - increased LTE interface wait time;
*) defconf - updated health settings on configuration revert;
*) defconf - use "fq_codel" queue as default interface queue for wired ports on LTE devices;
*) dhcpv6-client - install dynamic IPv6 blackhole routes in corresponding routing-table;
*) dhcpv6-client - updated error logging when multiple prefixes received on renew;
*) disk - added exFAT and NTFS mount/read/write support;
*) disk - added global disk "settings" menu;
*) disk - fixed changing settings on some GPT formatted disks;
*) disk - properly unmount disk when it is disconnected;
*) dns - do not add new entries to cache if "cache-size" is reached;
*) dns - fixed domain name lookup resolving for internal services;
*) ethernet - fixed issue with default interface names for CRS310-8G+2S+ in rare cases;
*) ethernet - improved cable-test reliability for hAP ax3 PoE out port;
*) ethernet - resolved minor memory leak while processing packets;
*) fetch - added "head" option for "http-method";
*) fetch - added "patch" option for "http-method";
*) fetch - allow specifying link-local address in FTP mode;
*) fetch - allow to use certificate and check-certificate parameters only in HTTPS mode;
*) fetch - do not require "content-length" for HTTP (introduced in v7.13);
*) fetch - fixed DNS resolving when domain has only AAAA entries (introduced in v7.13);
*) fetch - fixed fetch execution when unexpected data is received in HTTP payload;
*) fetch - fixed fetch when using "src-path" with HTTP/HTTPS modes (introduced in v7.13);
*) fetch - fixed fetch when using "src-path" with SFTP mode (introduced in v7.13);
*) fetch - fixed incorrect "src-path" error message when "upload=yes";
*) fetch - fixed IPv4 address logging (introduced in v7.13);
*) fetch - improved fetch stability in SFTP mode;
*) fetch - improved file download stability with HTTP/HTTPS modes;
*) fetch - less verbose logging;
*) fetch - print all "Set-Cookies" headers in response;
*) fetch - treat any 2xx HTTP return code as success (introduced in v7.13);
*) filesystem - improved filesystem integrity for several RB3011 units with automatic firmware upgrade;
*) firewall - added "creation-time" parameter for IPv6 address list entries;
*) firewall - fixed underlying CAPsMAN tunnel reusing packet marks of encapsulated packets;
*) firewall - fixed underlying VXLAN/EoIP tunnel reusing packet marks of encapsulated packets;
*) firewall - increased default "udp-timeout" value from 10s to 30s;
*) health - added limited manual control over fans for CCR1016r2, CCR1036r2 devices;
*) health - changed default "fan-min-speed-percent" from 0% to 12%;
*) health - improved fan control on CRS3xx and CCR1016-12S-1S+r2;
*) health - show voltage when powering KNOT R through Micro-USB;
*) health - updated health properties for CCR1016r2, CCR1036r2 devices;
*) iot - added bluetooth whitelist wildcard asterisk support;
*) iot - added LoRa CUPs protocol support;
*) iot - fixed modbus partial frame reception issue;
*) iot - improved LoRa LNS;
*) iot - improved modbus Tx/Rx switching behaviour;
*) iot - improvements to GPIO behavior on boot;
*) iot - improvements to LoRa CUPS;
*) iot - removed bluetooth whitelist maximum entry limit of 8;
*) ipv6 - made "valid" and "lifetime" parameters dynamic for SLAAC IPv6 addresses;
*) isis - show passive interface active levels;
*) l3hw - fixed IPv6 host offloading in certain cases;
*) l3hw - fixed neighbor offloading after link flap;
*) l3hw - preserve offloading for VLANs when bridge ports are down;
*) leds - added "dark-mode" functionality for hAP ax3 and Chateau ax series devices;
*) leds - do not show LTE connection state/mode using RGB power LED from configless LTE modems;
*) leds - fixed "type=on" LED behaviour after reboot;
*) leds - fixed default LTE LED configuration for wAPR-2nD;
*) leds - fixed modem LED indication for SXT LTE 3-7;
*) leds - fixed wireless type of LED triggers for routers using WiFi package;
*) lte - added "at-chat" support for Sierra Wireless EM9293 5G modem;
*) lte - added AT channel support for Quectel EM120K-GL modem;
*) lte - added redial timer when the MBIM modem fails to register or does not receive APN activation notification;
*) lte - don't duplicate primary band in 5G SA mode for chateau 5G;
*) lte - fixed "use-peer-dns" setting for EC200A modem;
*) lte - fixed an issue for EC200A modem that IPv6 address could be added as IPv4 address;
*) lte - fixed APN authentication for FG621-EA modem;
*) lte - fixed MBIM interface enabling for Quectel EC25 modem (introduced in v7.13);
*) lte - fixed Simcom modem support in 0x9000; 0x9002, 0x9002; 0x901a and 0x901b USB compositions;
*) lte - fixed Simcom modem support in 0x9001 USB composition;
*) lte - fixed support for config-less modem detection (introduced in v7.13);
*) lte - fixed USB mode switch and initialization race condition for configless USB modems;
*) lte - improved FG621-EA modem firmware upgrade;
*) lte - improved modem recovery after failed IPv4 configuration;
*) lte - improved support for "ACER" and "MSFT" branded EM12-G modems;
*) lte - optimized "at-chat" response reading;
*) lte - refactored AT command control for AT modems;
*) modem - fixed SMS removal (introduced in v7.13);
*) modem - improved stability when performing modem FOTA upgrade;
*) mpls - fixed VPN fragmentation when forwarding IP traffic;
*) netinstall-cli - check package and device architecture before formatting;
*) ovpn - added support for pushing routes;
*) ovpn - improved "push-routes" option handling when large amount of routes is specified;
*) ovpn - improved key-renegotiation process;
*) ovpn - improved OVPN configuration file import process;
*) ovpn - improved system stability when using HW encryption on ARM64 devices (introduced in v7.13);
*) ovpn - limit the maximum length for "push-routes" up to 1400 characters;
*) package - added "size" property;
*) package - reduced "wireless" package size for ARM, ARM64, MIPSBE, MMIPS devices;
*) package - reduced package size for SMIPS;
*) poe-out - driver optimization for AF/AT controlled boards;
*) poe-out - fixed "power-cycle" for CRS354-48P-4S+2Q+ device (introduced in v7.13);
*) poe-out - improved 802.3at classification and measurement accuracy;
*) poe-out - improved cable test for hAP ac3 and hAP ax3 devices;
*) poe-out - improved PoE out reliability on routers with a single PoE out interface;
*) port - fixed support for USB/serial adapters (introduced in v7.13);
*) port - removed bogus serial port on RB750Gr3, RB760iGS and RBM11G devices;
*) ppp - added support for "WISPr-Session-Terminate-Time" RADIUS attribute;
*) ppp - log an error when IPv6 DHCP pool is exhausted;
*) ptp - added "aes67" and "smpte" profiles;
*) ptp - added configurable "domain" and "priority2" parameters;
*) ptp - added support for Management message forwarding in BC;
*) ptp - fixed "default" and "g8275.1" profiles go into "slave" instead of "uncalibrated" state;
*) ptp - fixed default values for "802.1as" profile;
*) ptp - fixed flags in Announce message;
*) ptp - fixed potential error in packet exchange;
*) ptp - make clock go into grandmaster state if slave port goes down;
*) qos-hw - fixed "tx-queue7-packet" counter;
*) route - fixed gateways of locally imported vpnv4 routes;
*) route - improved route print "count-only" process speed;
*) route - improved stability on route table lookup;
*) route-filter - added option to set "isis-ext-metric";
*) route-filter - fixed AS path matchers when input and output chains are used;
*) routerboard - added "reset-button" support for RBwAPR-2nD device;
*) sfp - added support for modules requiring single byte I2C read transactions;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on CCR2004-16G-2S+ in rare cases;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on RB4011 in rare cases;
*) sfp - improve high-power SFP module initialization;
*) sfp - improved combo-sfp handling for CRS328-4C-20S-4S+;
*) sfp - improved link establishment for RB4011 devices;
*) smb - added option to specify SMB service mode as "auto";
*) sms - fixed SMS inbox for FG621-EA modem (introduced in v7.13);
*) sms - fixed SMS sending from WinBox and WebFig (introduced in v7.13);
*) sms - improved system stability when working with SMS;
*) sms - increased SMS read timeout;
*) snmp - added "bgpLocalAs" and "bgpIdentifier" OID reporting;
*) snmp - fixed "bgpPeerFsmEstablishedTime" OID reporting;
*) snmp - hide "MikroTik" in LLDP MIB when branding with hide SNMP option is used;
*) snmp - updated timeout log;
*) ssh - improved SSH performance on ARM, MIPS, MMIPS, SMIPS and TILE devices;
*) ssh - refactored SSH service internal processes;
*) sstp - added support for "aes256-gcm-sha384" encryption;
*) sstp - improved system stability for PPC devices;
*) supout - added PTP section;
*) switch - fixed Ethernet disable/enable for CRS310-8G+2S+ devices;
*) switch - fixed reserved multicast receive on Atheros-8327, QCA8337 switches for R/STP bridge;
*) switch - improved 100G interface stability for 98DX4310 and 98DX8525 switches;
*) switch - minimise potential packet overflows on CRS354;
*) system - changed build time format according to ISO standard;
*) system - expose "lo" and "vrf" interfaces;
*) system - fixed "cpu-frequency" for CRS3xx ARM devices;
*) system - improved memory allocation for ARM64 devices;
*) system - improved RAM allocation for L009UiGS-RM;
*) system - improved system stability when processing packets in FastPath (introduced in v7.13);
*) system - properly assign destination port for HTTP/S connections initiated by the router (introduced in v7.13);
*) system - properly close HTTP/S connections initiated by the router;
*) system - provide more precise "total-memory" value for ARM devices;
*) system - provide more precise "total-memory" value under "System/Resources" menu for L009 and hAP ax lite routers;
*) tftp - improved invalid request processing;
*) timezone - updated timezone information from "tzdata2023d" release;
*) tr069 - don't duplicate cellular info in "X_MIKROTIK_5G" nodes when connected in NR SA mode;
*) tr069 - fixed bandwidth test;
*) tr069-client - show 5G signal info in X_MIKROTIK_5G nodes only for 5G NSA bands;
*) traffic-flow - use 64bit counters for v9 and IPFIX flows;
*) traffic-generator - improved system stability when receiving bogus traffic;
*) usb - show "Supermicro CDC" adapter as Ethernet interface;
*) vlan - fixed non-running VLAN interface after failed MTU change;
*) vrf - prevent VRF interface name collision with interface lists;
*) vxlan - fixed underlying tunnel reusing routing marks of encapsulated packets;
*) webfig - fixed routing table filter under "IP/Routes" menu;
*) webfig - fixed setting the user's password;
*) webfig - fixed showing WireGuard peers;
*) webfig - improved stability when adding new entries under "IP/Routes" menu;
*) wifi - added "station-pseudobridge" interface mode;
*) wifi - fixed issue with setting country profile (introduced in v7.13.1);
*) wifi - improved handling of CAP connections in dual CAPsMAN scenario;
*) wifi - increased value for SAE retransmit period to 3s to improve WPA3 compatibility with IoT client devices;
*) wifi - use "Latvia" as the default value for "country" property;
*) wifi - use correct CAP identity for interface name provisioning after it has been changed by remote-cap/set-identity;
*) wifi-qcom - enable display of regulatory information on L11,L22 devices;
*) wifi-qcom - fixed new connections, when maximum supported number of MAC addresses behind connected station-bridges is reached;
*) wifi-qcom - improve system stability for L11, L22 devices;
*) wifi-qcom - improved memory allocating process;
*) wifi-qcom - improved regulatory compliance for L11, L22 devices;
*) wifi-qcom - improved system stability when using FastPath (introduced in v7.13);
*) winbox - added "accept-protocol-version" parameter to the L2TP server settings;
*) winbox - added "mode-button" and "switch" menus for L41G-2axD&FG621-EA;
*) winbox - added "Name" parameter under "Tools/Netwatch" menu;
*) winbox - added "page-refresh" setting to the Graphing settings;
*) winbox - added "Port Cost Mode" setting under "Bridge" menu;
*) winbox - added "VRF" parameter under "Tools/Ping" menu;
*) winbox - added "x25519" argument for "DH Group" parameter under "IP/IPsec/Profiles" menu;
*) winbox - added missing "Protocol" arguments under "IPv6/Firewall" menu;
*) winbox - added missing monitoring properties under "WireGuard/Peers" menu;
*) winbox - added Preboot Etherboot settings to the System/RouterBOARD/Settings menu;
*) winbox - do not show USB settings for CRS devices that does not need it;
*) winbox - fixed "Bridge Cost" range under "Interfaces/VPLS" menu;
*) winbox - fixed "Password" button under "Quick Set" menu;
*) winbox - improved connection speed and reliability;
*) winbox - improved route table automatic refresh process for static routes;
*) winbox - improved status values under "System/PTP" menu;
*) winbox - improved system stability with large packets;
*) winbox - include "te-tunnel" parameter in VPLS interface monitor;
*) winbox - properly validate "passthrough-subnet-size" in the LTE APN settings;
*) winbox - remove "Root Bridge ID" property under "Bridge/MSTIs" menu;
*) winbox - removed "sfp all" option from combo port settings;
*) winbox - renamed "Wireless Table" menu to "Wifi";
*) winbox - show "routing-table" column under IP/Route menu by default;
*) winbox - show all columns under "Routing/PIM SM/Static RP" menu by default;
*) wireguard - do not allow to use multiple WireGuard interfaces on the same "listen-port";
*) wireguard - optimised and improved WireGuard service logging;
*) x86 - fixed VLAN tagged packet transmit for igb (introduced in v7.12);
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
massinia
Re: v7.14 [stable] is released!
Thu Feb 29, 2024 5:19 pm
Huge changelog, congratulations for the excellent work 👏
rushlife
Thu Feb 29, 2024 5:35 pm
awesome, thx for your hard work
baragoon
Thu Feb 29, 2024 5:37 pm
Yahoooo, thank you
pe1chl
Thu Feb 29, 2024 5:40 pm
Remember this:
Notice - Starting from RouterOS version 7.13, significant changes have been made to the RouterOS wireless packages. This is done due to a new product development which will require more disk space for hardware drivers so we had to split it in order to maintain old products alongside the new ones. More wireless packages are yet to come.
1. When upgrading by using "check-for-updates", all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always.
2. Drivers for older wireless and 60GHz interfaces, as well as the wireless management system CAPsMAN, are now part of a separate "wireless" package instead of being a part of the bundle package. This package can be uninstalled if not needed.
3. The existing "wifiwave2" package has been divided into distinct packages: "wifi-qcom" and "wifi-qcom-ac", and the necessary utilities for WiFi management are now included in the RouterOS bundle. RouterOS and "wifi-qcom-ac" packages alongside each other now fit into 16MB flash memory.
Also note that upgrading beyond 7.12.1 can cause issues on ARM devices with "16MB flash", especially for devices that actually have only 15.3MB flash.
So be extra careful when upgrading such a device (e.g. hAP ac2), especially when you cannot easily netinstall it (remote location).
Dish
Thu Feb 29, 2024 5:45 pm
I have the following wireguard bth info in the log on a hap ax lite LTE 6 and an RB 5009. With version 7.13
was everything OK. A new configuration of Wiregurad BTH does not bring any changes.
bp0
Thu Feb 29, 2024 5:55 pm
What causes this message regarding a backup-routerboot upgrade?
edit: Device is RB960PGS (hEX PoE) r2.
morphema
Thu Feb 29, 2024 5:57 pm
I'm getting endless messages 'Handshake for peer did not complete after 5 seconds, retrying (try 2)' in log.
infabo
Long time Member
Long time Member
Thu Feb 29, 2024 6:22 pm
Note: I spotted several lines in the changelog that where already in 7.13.x releases. So changelog looks longer than it actually is.
Matta
Thu Feb 29, 2024 6:37 pm
I still cannot ugrade hAP Lite from 7.13 to 7.14 (7.6MiB required, 7.5MiB free, although it's only few kilobytes that are actually missing).
Manual upgrade also won't pass, missing those few kb to upload wireless package.
sszbv
Trainer
Trainer
Thu Feb 29, 2024 6:45 pm
Look out when upgrading a CCR2004-1G-2XS-PCIe.
I've got one here that is gone into a reboot loop, even after powering down and up again.
It can be bad luck, but I'm not going to upgrade the rest of them until I know how to get it running again.
Update:
I got the board working again after resetting it to defaults with the reset solder pads.
nmt1900
Thu Feb 29, 2024 6:55 pm
Somewhat unbelievably... while 7.13.5 took 14,4 MB of space in hap ac2 - 7.14 has seem to got smaller as used space indicates now 14,3 MB (that with legacy wireless package).
Upgrade took almost 3 minutes which is longest for that device so far...
mirolm
Thu Feb 29, 2024 7:14 pm
Old wireless package got smaller but how it is with wifi-qcom-ac? Anyone knows if it is possible to upgrade to 7.14 and how much flash space will be left free afterwards?
GreySer
Thu Feb 29, 2024 7:16 pm
All ethernet interfaces on the CHR machine on the VDSINA hosting are missing. I checked the installation process twice, the ethernet is always lost. I installed 7.13.5, the ethernet is back.
nmt1900
Thu Feb 29, 2024 7:17 pm
What causes this message regarding a backup-routerboot upgrade? Screenshot from 2024-02-29 09-48-58.png
What device this is?
holvoetn
Thu Feb 29, 2024 8:26 pm
Since 7.14 there is a lot more verbose logging w.r.t. Wireguard in general, not only BTH.
It's in the change log.
But if you ask me, there should also be an 'off' switch for this logging ... haven't found it yet.
Joseph
Thu Feb 29, 2024 8:28 pm
Upgrade done!
I hope it will be better than 7.13... it was a nightmare...
7.13.2 and 7.13.4 has broken file save on NAS. I don't know how and why but I observed that in two different locations.
holvoetn
Thu Feb 29, 2024 8:48 pm
So far upgraded successfully (home and lab gear):
RB5009
AX2
AX3
AX Lite LTE
Map
Minor comment:
log file on AX Lite LTE shows something weird:
19:36:54 script,warning USB device count: 2 >> 3 .id=*1;device=1-0;name=xHCI Host Controller;speed=480;vendor=Linux 5.6.3 xhci-hcd;.id=*2;device=2-0;name=xHCI Host Controller;speed=5000;vendor=
Linux 5.6.3 xhci-hcd;.id=*3;device=1-1;name=FG621 Module;speed=480;vendor=Fibocom
19:37:16 script,warning LTE inteface count: 0 >> 1
But everything works.
w0lt
Long time Member
Long time Member
Thu Feb 29, 2024 8:55 pm
In Logging, select info, then add wireguard to it, then add the negative sign to wireguard.
holvoetn
Thu Feb 29, 2024 9:08 pm
Can you elaborate please ? I don't seem to get it right.
BTW same with DNS and NTP logging. It's being SWAMPED now with messages.
holvoetn
Thu Feb 29, 2024 9:13 pm
Hmmm ... there HAS to be a way to SHUT DOWN the verbosity of those logs.
This is NOT practical like it is now.
tom3f
On hapAC2 with wifi-qcom-ac i have 164KiB left. That is very bad :( but it works for now.
Larsa
Thu Feb 29, 2024 9:23 pm
I've upgraded a couple of lab routers and I'm getting the exact same status flooding from all passive WireGuard peers, ie those defined without endpoint addresses. This applies to both IPv6 and IPv4 peers. And yeah, I know how to mute it but that is beside the point.
rushlife
Thu Feb 29, 2024 9:28 pm
+1, the same by me
Larsa
Thu Feb 29, 2024 9:42 pm
Something fishy is going on with passive WireGuard peers since it seems they are all trying to establish an active connection to the destination address 0.0.0.0, port 0. The WireGuard debug log is flooded with entries like: "wireguard, debug: WG-xxxx: ... Sending handshake initiation to peer (0.0.0.0:0)"
Znevna
Thu Feb 29, 2024 10:04 pm
You have packets flying towards those peers.
Stop the packets, the flooding will stop. Or hide the messages.
strods
Thu Feb 29, 2024 10:21 pm
The comment from w0lt was correct. In order to disable specific topic logs, go to System/Logging and open, for example, "info" topic. Add "!wireguard" to it. All info logs, except WireGuard, will be logged now.
Yes, these are new logs, nothing changed in the WireGuard behavior. Same actions simply were not logged before.
Larsa
Thu Feb 29, 2024 10:24 pm
@strods, what about "Sending handshake initiation to peer (0.0.0.0:0)" from passive peers? Btw, IMO flooding standard "info" with misleading error messages sends wrong signals.
> @Znevna: You have packets flying towards those peers. Stop the packets, the flooding will stop. Or hide the messages.
Nope, totally silent according to the packet sniffer. Also, it logs 'initial handshake,' not 'handshake reply.
gerab
Thu Feb 29, 2024 10:27 pm
In addition to the logs issue, one of a few WG peers lost its public key. The one I found when I started to investigate the loss of connection was not the same one I put there about a week ago.
rushlife
Thu Feb 29, 2024 10:29 pm
Thx, It worked nicely.
Avnn
Thu Feb 29, 2024 10:33 pm
D53G-5HacD2HnD
After updating from 7.13.5 to 7.14, "Loopback" interface appeared in the interface list. I don't see anything about this in changelog...
What is that loopback?
infabo
Long time Member
Long time Member
Thu Feb 29, 2024 10:37 pm
Larsa
Thu Feb 29, 2024 11:04 pm
Regarding "wireguard, debug: Sending handshake initiation to peer (0.0.0.0:0)" on passive peers.
This is just pure speculation and I might be completely wrong; but after some troubleshooting it seems that MNDP might trigger passive WireGuard peers to attempt to establish a connection despite the absence of an endpoint address, hence why the dest-addr is set to 0.0.0.0:0.
EDIT:
IMO if it turns out to be the issue, the root cause should be addressed to avoid these (potentially misleading) error messages in the info and debug channels.
braveheartleo
Thu Feb 29, 2024 11:12 pm
I'd like to know, is v7.14rc4 testing and v7.14 stable the same release, except maybe changing the version number and channel? Should I upgrade from v7.14rc4 to this?
fragtion
Thu Feb 29, 2024 11:15 pm
Same problem here. I lost all ethernet devices on one of our CHR after upgrading to 7.14. Provider is running virtualizor
I tested, and v7.13.5 works. 7.14rc1 was the last revision of 7.14rc that sees the nic.
To recover, I had to mount linux livecd and mount /dev/vda2, then create a downgrade directory (mountpoint/disk/downgrade), copy routeros,wireless,container packages to this directory, and then boot back into routeros, enable ftp server, then fetch from download directory to root directory, and finally /system/package/downgrade
I presume it's this "RedHat VirtIO Network device"
I'm just glad I found a way to recover this vm...thanks to a combination of my vps provider having the right recovery/console tools, and routeros being linux based and supporting ftpd+fetch
So this one's stuck on 7.14rc1 until we get a fix, hopefully soon :)
Jotne
Thu Feb 29, 2024 11:20 pm
Simple answer yes. RC are not ment for production, do upgrade.
accarda
Thu Feb 29, 2024 11:37 pm
I have noticed an issue with IP tunnel interfaces and VRF.
When creating such interface it does not get instantiated in the proper VRF.
At startup I get an error in the log: failed to set vrf for interface <IP tunnel if>, please check if selected vrf instance is enabled.
VRF is enabled and I have also a VLAN and a L2TP interfaces that are properly working in the same VRF, so it seems more an issue with IP tunnel interfaces and VRF with new Ros 7.14.
Switching back to 7.13.5 solves the issue, all interfaces work fine with the VRF.
bp0
Thu Feb 29, 2024 11:38 pm
sorry, RB960PGS (hEX PoE) r2.
usx
Thu Feb 29, 2024 11:46 pm
No immediate problems noticed after upgrading the following from 7.13 (no patch version upgrades applied):
- RBmAP2n ("mAP 2n") x2
- RBD25G-5HPacQD2HPnD ("Audience")
- 2011UiAS-2HnD
- hAP RB951Ui-2nD ("hAP")
- RB4011iGS
- hEX 750G r3 ("hEX")
aindless
Fri Mar 01, 2024 12:26 am
Thanks for the update, amazing memory usage on my ax3 ! With the previous firmware had like 250-300 mb free and now it stays at 500 mb free !!!
sajt
Fri Mar 01, 2024 12:29 am
After upgrading a ccr1009 and a ccr1036 EOIP and IPIP interfaces, tho under the the ip/vrf menu did appear in the correct vrf, in reality the addresses and directly connected networks became part of the "main" vrf.
Downgrading to 7.13.5 solved the issue.
SkyBeam
Fri Mar 01, 2024 1:20 am
Unfortunately I had to downgrade to 7.12.1 again.
After 7.14 installation all my SFP 1G base T (copper) links stayed in non-running state. Same effect as for all 7.13.* revisions. Working just fine again after downgrading to 7.12.1. Interestingly none of my SFP+ modules (1x DAC, 1x LC single-mopde) was affected, they did just run fine.
Device: CRS310-1G-5S-4S+
I was able to get the interface running by disabling auto negotiation as mentioned by somebody else. But would have to set this manually on both ends.
carl0s
Fri Mar 01, 2024 1:34 am
It's a big one. Thank you. I've been waiting for 7.14 to release. I think I am ready to spend some time on wifi-qcom and wifi-qcomac now with capsman
gze100
Fri Mar 01, 2024 1:44 am
Can confirm this, the bug was introduced with 7.14rc2 and is still there. I opened a support ticket for that. They asked me to create and download a supout.rif file. You may create it, but you cannot download it without ethernet interfaces. So that didn't really help. Will wait for a better idea. Guest tools are also no longer recognized, so that must have been substantial changes between 7.14rc1 and the releases after that. Unfortunately I couldn't find anything in the release notes, that would help for a better understanding of that problem.
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 2:49 am
On 7.14 wifi clients can connect to 2.4ghz SSID but DHCP runs into a timeout (and even with static IP no communication possible). Once wifi 5ghz is online (after initial DFS), clients can connect to 5ghz and get IP instantly. But nothing suspicious in the logs.
Then I switched "protocol-mode=rstp" to "protocol-mode=none" on default bridge. Suddenly DHCP and everything else started working on 2ghz as well.
Hmmm
Another observation:
I installed container package yesterday (7.13.5) just for trying the iperf3 container from tangent. ROS reported about 400kb of free disk space on Chateau LTE16 with wifi-qcom-ac and container installed. After the upgrade from 7.13.5 to 7.14 the free space shrinked down to 80kb. I did notice - but did not give much attention. After about 2h running on 7.14 I decided to reboot once again -> BRICKED. Device did not come up again. Netinstall to the rescue. Just ROS with wifi-qcom-ac and no containers, keep configuration. No config lost, device up and running. But 272kb free disk left and I don't even have container package installed this time. I mean WTF. This is getting less on every release.
jordanp123
Fri Mar 01, 2024 3:48 am
I noticed that on two L009's I have that VRF's quit working. I had a VRF for a Wireguard VPN service and after upgrade it doesn't seem to function anymore. Downgraded back to 7.13.5 and its back to working normally.
own3r1138
Long time Member
Long time Member
Fri Mar 01, 2024 5:14 am
It wasn't applied after the update to v17.14.
thedix
Fri Mar 01, 2024 5:22 am
I can confirm this is fixed on RB1100AHx4 as well.
On 7.13.5 I had ping losses and reboots when formatting and writing a big file to the microSD slot via Winbox.
On 7.14 I was able to successfully write a file larger than 400 MB.
Thank you!
marcin21
Fri Mar 01, 2024 5:30 am
Warning!
CCR2004-pcie doesn't come back after upgrade. it's crazy what You do at mikrotik, to release fw *STABLE* that bricks cloud core unit.
looks like boot-loop.
HOW to get it working back on remote location!???
jordanp123
Fri Mar 01, 2024 5:33 am
It seems the issue is that even when the interface of the VPN is added to the VRF via ip->VRF list, the wireguard VPN interface isn't dynamically added to the VRF it was assigned when IP route assignments come up. 7.13.5 It works and behaves as expected, but in this case all wireguard interfaces so matter if they're added to a different VRF or not are dynamically assigned to the main vrf.
thedix
Fri Mar 01, 2024 5:35 am
Thank you!
But now on 7.14 the read speed is awful on microSD slot.
About 2-3 Mbps, this is not good.
Could you fix it?
scotth
Fri Mar 01, 2024 5:47 am
MLAG and VRRP still don’t play well together. As aVRRP on an MLAG bridge and when the master changes response on the MLAG up address will fail.
Xand
Fri Mar 01, 2024 6:48 am
Hi, I have hAP ac^2 with wifi-qcom-ac (installed both with netinstall 7.13).
WIFI interfaces are off. I don't keep any files (there is only 1% free free space anyway).
Ever since I upgraded to 7.14 beta the router keeps rebooting with kernel failure (OOM condition detected). Mostly if I try to download / install new version. Sometimes it just happens out of the blue.
Previously, after several reboots on the loop I managed to upgrade to another beta and later rc3. But it just does not want to update to RC4 / stable.
Should I just ditch wifi-qcom-ac? I am not sure what the issue is.
UPD
I disabled wifi-qcom-ac and the router successfully updated to 7.14 stable. Then I enabled again wifi-qcom-ac and rebooted. No kernel issue / OOM so far. Let's see how it will go.
accarda
Fri Mar 01, 2024 7:34 am
In addition to the bug reported about IPIP interfaces not working correctly with VRF, also IP service does not work fine with VRF anymore.
I have IP service www on VRF and does not respond to requests anymore, while all is fine with 7.13.5
Jotne
Fri Mar 01, 2024 7:47 am
Why did you upgrade a remote location, just some hour after a new release?
You should wait 14 days, read the forum, and then you maybe should upgrade.
Also if its a remote location, you should have an equal local device to test it on first.
Rox169
Fri Mar 01, 2024 8:15 am
ROS 7.14 working on:
HAP AX3
HAP AX2
HAP AC3
HAP AC2
CUBE 60 AC
WAP 60
SXT
Rox169
Fri Mar 01, 2024 8:19 am
could you please explain me why I have new interface lo - Loopback?
Znevna
Fri Mar 01, 2024 8:21 am
Read the changelog.
ccl13
Fri Mar 01, 2024 8:35 am
Run into issues after upgraded to 7.14 from 7.13.4. The network is not working. WinBox shows all 0 for all interfaces. Switches on the network are all flipping RSTP and it was quite hard to see what actually is happening. Because I need the network working, I downgraded to 7.13.5 and it works fine now. Suspecting similar issue with one of the recent update which screwed up STP too.
gigabyte091
Fri Mar 01, 2024 8:45 am
RB5009, ax3, CRS310, cAP ax updated without a problem for now, Container and UPS works. CRS310 took 3 and a half minute to upgrade... Other devices minute or so.
oskarsk
Fri Mar 01, 2024 8:55 am
Which version you had on CCR2004-1G-2XS-PCIe, before you did update to 7.14 ?
normis
Fri Mar 01, 2024 9:27 am
Those changes are only in the new 7.14 version, but you have the old one. So you don't yet have the smaller package size. You must upgrade using Netinstall. From then on you will no longer have the issues.
Rox169
Fri Mar 01, 2024 9:37 am
What is it good for? The lo interface?
sch
Fri Mar 01, 2024 9:47 am
@fragtion
Could you please clarify if your VPS provider has made any updates?
holvoetn
Fri Mar 01, 2024 9:48 am
Best explanation I could find around here:
viewtopic.php?p=943761#p943761
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 9:58 am
Best explaination is here: https://en.wikipedia.org/wiki/Localhost
Rox169
Fri Mar 01, 2024 10:01 am
Thank you...until now I did not need it but I have to see it now. It would be better to fix Netwatch/sending notification than add new interface for nothing...
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 10:02 am
The SSID is "jupiter" for both wifis. When I only enable 2.4ghz iface, clients connect but receive no IP address (stuck at "obtaining IP address..."). Reproducible on several devices.
Then I change the SSID to "jupiter2". Suddenly all clients connect to AP and can obtain an IP.
Now I am completely clueless.
grusu
Fri Mar 01, 2024 10:03 am
I think it's time to rewrite the documentation for the smb service.
Thanks!
morphema
Fri Mar 01, 2024 10:18 am
Thank you, it works. Considering how bizarre it works, I'm curious about the reason for enabling this rule by default.
nmt1900
Fri Mar 01, 2024 10:50 am
deleted
pe1chl
Fri Mar 01, 2024 10:58 am
Defaults are not applied by updates. Once you have made a setting it will be saved and restored at reboot, you need to change it to 30 seconds yourself when you want that. New installations will get the new default.
pe1chl
Fri Mar 01, 2024 11:00 am
Warning!
Well, I would call it quite irresponsible to install a freshly released 7.xx version at a remote location within a day after release, especially when the same issue was already reported in the release topic...
Also, as mentioned many times before, the label "stable" refers to the stability of the release process, not to the stability of operation.
When you require stability of operation, always wait for the 7.xx.1 version and do not install it within a week of release.
BWC
Fri Mar 01, 2024 11:05 am
AWS sent me a notification that there is a new ROS Image available, does this mean updates will work now without the Instance type t3 -> t2 -> t3 limbo when freshly deployed?
https://aws.amazon.com/marketplace/pp/p ... gn6js6av54
--Michael
mbovenka
Fri Mar 01, 2024 11:07 am
Interesting. That's not what I am used to (working mostly with the Big C @$dayjob). Defaults do get changed there when upgrading. I guess there is something to be said for both approaches.
bratislav
Fri Mar 01, 2024 11:13 am
Have you bothered to actually read the page from the link provided?
https://wiki.mikrotik.com/wiki/Manual:R ... bootloader
sszbv
Trainer
Trainer
Fri Mar 01, 2024 11:35 am
It was 7.13 on mine (with 7.8 firmware).
Needed a reset to defaults to get it to work again.
See image for first bootlog
ljb
Fri Mar 01, 2024 11:45 am
I too had an issue with CHR ethernet adapters disappearing after updating from 7.13.5 to 7.14 on a production server times two. 7.14 is supposed to be stable realease? I was prepared with a week old snapshot and suddenly my adapters reappeared.
Chupaka
Fri Mar 01, 2024 11:50 am
I have Neighbor Discovery enabled on all interfaces, and weird errors stopped appearing for me when I disabled keep-alive on passive peers
Chupaka
Fri Mar 01, 2024 11:52 am
You mean, you have a VM and you don't test upgrades by making a copy of your VM before upgrading the router in production? %)
gze100
Fri Mar 01, 2024 11:54 am
@fragtion
That has nothing to do with the VPS provider, I have the same problem running a selfhosted xcp-ng installation which worked without any problems since 2 two years until the release of 7.14rc2. You can reproduce the issue easily as follows.
Set up an CHR installation up to 7.14rc1 and configure it as you like. Check, that everything is working as intended. Do a snapshot of the vm with the tools of your hypervisor. Do a /system/package/update/install to a newer release, reboot and boom here you are without any ethernet interfaces. Check /interfaces/ethernet. You will probably see nothing. Rollback to your snapshot, that you have preferred before and voilà everything is working again without any issue. The problem is not outside the vm, it is inside of the CHR image. Users have reported problems with KVM based installations, I have XEN running, the problem is just the same.
gze100
Fri Mar 01, 2024 11:59 am
7.14 cannot be considered stable, at least not for the CHR image. I have the same issue with all ethernet interfaces disappearing after updating to 7.14rc2 or newer. I did a rollback to 7.14rc1 in my testing environment. In production I still run 7.13.5.
marcin21
Fri Mar 01, 2024 12:02 pm
its distant but not yet on production. frankly speaking it's because I've got problem on it with tagged VLAN, and according to changelog
that issue was addressed in this release. So if it was placed in
STABLE branch
i thought that it's gone through beta and RC, so it wont blow up but it did.
mikrotik You are really making my effort more interesting that it should be.
marcin21
Fri Mar 01, 2024 12:05 pm
7.13.5 as I have on hosting x86.
why you make it so hard to belive stable branch is something that is considered STABLE???
are You testing it on recent devices or just letting ppl like me to be betatester???
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 12:16 pm
Downgrading to 7.13.5 fixes the issue also on SSID "jupiter. But still I don't know what causes this. I would suspect RSTP changes - but how can I pin that out?
jimmer
Fri Mar 01, 2024 12:23 pm
Hi All,
I have upgraded two devices to RouterOS 7.14 one from 7.13 (RB3011iUAS-RM) and the older RB2011iUAS-RM from 7.12
No issues with either per se but the RB2011 MIPSBE based unit reported this in the logs after upgrade:
2024-03-01 14:30:16 system,info,critical Optimal nand stability requires a backup-routerboot upgrade.\r
2024-03-01 14:30:16 system,info,critical Universal package can be found here:\r
2024-03-01 14:30:16 system,info,critical https://wiki.mikrotik.com/wiki/Manual:R ... D_settings
Noticed that it has an escaped character at the end, Routerboot was 7.12 and I upgraded it to 7.14
As seen below:
[jim@bradfield-rb2011-gw] > system/routerboard/print
routerboard: yes
model: RB2011UiAS
serial-number: 763307XXXXX
firmware-type: ar9344
factory-firmware: 3.33
current-firmware: 7.14
What limited information I can find for this alert appears to reference rather confusingly protected mode (which I dont use on anything) and a firmware from 6.4x but nothing relating to 7, I have never seen this pop up on any previous 7 release and the 2011 has been through just about every version from 7.1.5 onwards.
Any thoughts? is this a MIPSBE architecture bug?
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 12:25 pm
After upgrading to 7.14 again - the issue is gone!!! Magic. Pretty speechless.
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 12:27 pm
Here some interesting info for the ones that are interested into "Free HHD Space":
ROSE SMB must be really awesome stuff to justify this reduction of free disk space...shrug
DarkNate
Fri Mar 01, 2024 12:36 pm
Still not BQL for RouterOS? I still see poor bufferbloat/CPU usage issues under stress testing. Come on MikroTik, just add BQL support already.
normis
Fri Mar 01, 2024 12:57 pm
We can't "Add stuff", we can only "Make stuff"
kalamaja
Fri Mar 01, 2024 1:08 pm
Thank you, Mikrotik, for upgrading AWS CHR image from 6.x to 7.14: https://aws.amazon.com/marketplace/pp/p ... gn6js6av54
Hopefully it has fixed the problem that on T3 instances 7.x upgrades were failing.
DarkNate
Fri Mar 01, 2024 1:12 pm
Then make it, or simply allow official ONIE support on your hardware, we'll flash any OS of choice and get over RouterOS.
sergejs
Fri Mar 01, 2024 1:16 pm
--Michael
yes
biomesh
Long time Member
Long time Member
Fri Mar 01, 2024 1:29 pm
Upgraded ccr2004-16g-2s+, rb5009, crs318, crs317, cap ac, crs112 and chr with no real issue. This is from a mixture of 7.13 and 7.14rc versions.
I did see the odd firmware version text display issue I saw with a previous rc to release version on the ccr, but it just seems to be cosmetic.
Everything else was fine.
tommyd
Fri Mar 01, 2024 1:33 pm
On the all routers (from various vendors) I ever configured you can configure as many loopback interfaces you want, attach them to vrfs and use for various things i.e. iBGP. It does not seem to be case there. and What is a VRF interface
holvoetn
Fri Mar 01, 2024 1:35 pm
...and What is a VRF interface
A bit lazy, aren't we ?
https://help.mikrotik.com/docs/pages/vi ... eId=328206
Jotne
Fri Mar 01, 2024 1:38 pm
In large organisation with lots of routers (and switches) its normal to set IP on loop back interface so they are more easy to handle.
A route may have many IP, so what should you use to connect to SSH to it? Setting a range of IP like 10.111.111.0/24, you can access first
router with IP 10.111.111.1, second with 10.111.111.2 etc. Same goes for what IP should be used to send the log from, the loopback IP,
since it always the same and as mention by other always UP.
So for SSH/Telnet/SNMP/Syslog/web access etc loopback IP are nice to have.
wispmikrotik
Fri Mar 01, 2024 1:43 pm
Some kind of mechanism to import/export routes from one vrf to another within same router --> Thanks!
baragoon
Fri Mar 01, 2024 1:51 pm
Upgraded 10 CHRs without issue... what I did wrong? :-)
infabo
Long time Member
Long time Member
Fri Mar 01, 2024 1:59 pm
Are you in love with Mikrotik hardware so much? So there is a thing by Mikrotik you can't complain about? Wow
gze100
Fri Mar 01, 2024 2:10 pm
I don't know, but maybe you can tell us a little about your environment. That could help microtik narrow down the problem.
baragoon
Fri Mar 01, 2024 2:22 pm
I don't have detailed HV information, I'm only a client. I only know that some VMs are run on ProxMox (7.3-6, 7.4-17, 7.4-16, 8.1.4) but have no idea about server or NIC models.
Paternot
Forum Veteran
Forum Veteran
Fri Mar 01, 2024 2:25 pm
It never is. A new default doesn't overwrite something already set up. This is done on purpose, because the old value worked, and there is a chance the new value will mess with some weird user config.
If someone upgrades to the new version and do a factory reset, the new value will be applied. If someone just upgrades, the old value is kept.
gze100
Fri Mar 01, 2024 2:41 pm
Thanks, that's quite a bit. Do you use any special functions within your CHR routers? How many interfaces do you have connected to them? Can you print the output of the /system/resources/pci section to the thread so we can see what resources are in the VM.
elico
Fri Mar 01, 2024 2:51 pm
These logs should be in a debug and not an info level.
elico
Fri Mar 01, 2024 2:56 pm
What notifications and I don't understand if it's sending or not.
As far as I know to send a notification from netwatch you need to write a script, so what exactly is wrong?
elico
Fri Mar 01, 2024 2:58 pm
OK what hypervisor? Worked fine on Hyper-V.
/system/resource/pci/print
Columns: DEVICE, VENDOR, NAME, IRQ
#  DEVICE   VENDOR                 NAME                                                             IRQ
0  00:00.0  Intel Corporation      440BX/ZX/DX - 82443BX/ZX/DX Host bridge (AGP disabled) (rev: 3)    0
1  00:07.0  Intel Corporation      82371AB/EB/MB PIIX4 ISA (rev: 1)                                   0
2  00:07.1  Intel Corporation      82371AB/EB/MB PIIX4 IDE (rev: 1)                                   0
3  00:07.3  Intel Corporation      82371AB/EB/MB PIIX4 ACPI (rev: 2)                                  0
4  00:08.0  Microsoft Corporation  Hyper-V virtual VGA (rev: 0)                                      11
baragoon
Fri Mar 01, 2024 3:00 pm
 0  00:00.0  Intel Corporation  440FX - 82441FX PMC [Natoma] (rev: 2)
 1  00:01.0  Intel Corporation  82371SB PIIX3 ISA [Natoma/Triton II] (rev: 0)
 2  00:01.1  Intel Corporation  82371SB PIIX3 IDE [Natoma/Triton II] (rev: 0)
 3  00:01.2  Intel Corporation  82371SB PIIX3 USB [Natoma/Triton II] (rev: 1)
 4  00:01.3  Intel Corporation  82371AB/EB/MB PIIX4 ACPI (rev: 3)
 5  00:02.0  unknown            unknown (rev: 2)
 6  00:03.0  Red Hat, Inc.      Virtio memory balloon (rev: 0)
 7  00:05.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
 8  00:0a.0  Red Hat, Inc.      Virtio block device (rev: 0)
 9  00:12.0  Red Hat, Inc.      Virtio network device (rev: 0)
10  00:13.0  Red Hat, Inc.      Virtio network device (rev: 0)
11  00:14.0  Red Hat, Inc.      Virtio network device (rev: 0)
12  00:1e.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
13  00:1f.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
 8  00:12.0  Red Hat, Inc.      Virtio network device (rev: 0)
 9  00:13.0  Red Hat, Inc.      Virtio network device (rev: 0)
10  00:14.0  Red Hat, Inc.      Virtio network device (rev: 0)
11  00:15.0  Red Hat, Inc.      Virtio network device (rev: 0)
12  00:16.0  Red Hat, Inc.      Virtio network device (rev: 0)
13  00:1e.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
14  00:1f.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
15  01:01.0  Red Hat, Inc.      Virtio SCSI (rev: 0)
 #  DEVICE   VENDOR
 1  00:01.0  Red Hat, Inc.
 2  00:02.0  Red Hat, Inc.
 3  00:02.1  Red Hat, Inc.
 4  00:02.2  Red Hat, Inc.
 5  00:02.3  Red Hat, Inc.
 6  00:02.4  Red Hat, Inc.
 7  00:1f.0  Intel Corporation
 8  00:1f.2  Intel Corporation
 9  00:1f.3  Intel Corporation
10  01:00.0  Red Hat, Inc.
11  02:00.0  Red Hat, Inc.
12  03:00.0  Red Hat, Inc.
13  04:00.0  Red Hat, Inc.
10  00:1e.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
11  00:1f.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
 #  DEVICE   VENDOR
 5  00:02.0  unknown
 7  00:04.0  Red Hat, Inc.
 8  00:05.0  Intel Corporation
 9  00:06.0  Red Hat, Inc.
10  00:07.0  Red Hat, Inc.
11  00:08.0  Red Hat, Inc.
12  00:09.0  Red Hat, Inc.
13  00:0a.0  Red Hat, Inc.
14  00:0b.0  Red Hat, Inc.
12  01:01.0  Red Hat, Inc.      Virtio SCSI (rev: 0)
11  00:1e.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
12  00:1f.0  Red Hat, Inc.      QEMU PCI-PCI bridge (rev: 0)
 #  DEVICE   VENDOR
 2  00:07.0  Intel Corporation
 3  00:07.1  Intel Corporation
 4  00:07.3  Intel Corporation
 5  00:07.7  VMware
 6  00:0f.0  VMware
 7  00:11.0  VMware
 8  00:15.0  VMware
 9  00:15.1  VMware
10  00:15.2  VMware
11  00:15.3  VMware
12  00:15.4  VMware
13  00:15.5  VMware
14  00:15.6  VMware
15  00:15.7  VMware
16  00:16.0  VMware
17  00:16.1  VMware
18  00:16.2  VMware
19  00:16.3  VMware
20  00:16.4  VMware
21  00:16.5  VMware
22  00:16.6  VMware
23  00:16.7  VMware
24  00:17.0  VMware
25  00:17.1  VMware
26  00:17.2  VMware
27  00:17.3  VMware
28  00:17.4  VMware
29  00:17.5  VMware
30  00:17.6  VMware
31  00:17.7  VMware
32  00:18.0  VMware
33  00:18.1  VMware
34  00:18.2  VMware
35  00:18.3  VMware
36  00:18.4  VMware
37  00:18.5  VMware
38  00:18.6  VMware
39  00:18.7  VMware
40  03:00.0  VMware
41  0b:00.0  VMware
42  13:00.0  VMware
43  1b:00.0  VMware
0  00:00.0  Intel Corporation  440FX - 82441FX PMC [Natoma] (rev: 2)           0
1  00:01.0  Intel Corporation  82371SB PIIX3 ISA [Natoma/Triton II] (rev: 0)   0
2  00:01.1  Intel Corporation  82371SB PIIX3 IDE [Natoma/Triton II] (rev: 0)   0
3  00:01.2  Intel Corporation  82371SB PIIX3 USB [Natoma/Triton II] (rev: 1)  11
4  00:01.3  Intel Corporation  82371AB/EB/MB PIIX4 ACPI (rev: 3)               9
5  00:02.0  unknown            unknown (rev: 2)                                0
6  00:03.0  Red Hat, Inc.      Virtio network device (rev: 0)                 11
7  00:04.0  Red Hat, Inc.      Virtio memory balloon (rev: 0)                 11
all 10 instances, some with single, some with up to 5 ethernet interfaces
Guscht
Fri Mar 01, 2024 3:10 pm
7.14 runs good, but WUS DIS????
Endless log-spam
baragoon
Fri Mar 01, 2024 3:14 pm
WUS DIS????
search this topic...
holvoetn
Fri Mar 01, 2024 3:24 pm
Some default debug filters not being applied to log entries.
I saw them for wireguard, DHCP, DNS, NTP. All silent now.
gze100
Fri Mar 01, 2024 3:29 pm
It seems that at least one is running under VMware, the others under KVM. Another user reports that Hyper-V is working. Amazon has updated their CHR image as well, as I noted in this thread. I don't know what they are using in their cloud. I'd also appreciate more feedback from other users to see if it's limited to Xen-based VMs or if KVM and XEN both have issues with it. I'm not sure about that yet. With KVM-based installations, there seem to be working and non-functioning ones. There might be an implication to the Linux kernel of the KVM host. Let's see what feedback we get on this.
pe1chl
Fri Mar 01, 2024 3:35 pm
Well, IMHO it is just a bug. When a wireguard interface is passive, and it receives "interesting traffic to send", it should just do nothing.
It appears the code to setup a connection is triggered, even though it is passive. That is just wrong.
pe1chl
Fri Mar 01, 2024 3:38 pm
Please explain what you mean. Logging for "debug" is disabled by default, and always has been.
Did you create a log rule for "debug" and does it behave different now?
holvoetn
Fri Mar 01, 2024 3:50 pm
Example which wasn't there before moving from 7.14rc3 to 7.14.
That's debug, isn't it ?
I also saw NTP debug, dns, dns packet (which for me also classifies as debug), ...
All that wireguard info stuff, interesting as it may be for some, is for me also debug info.
I did not have a prior debug rule in log. So it's the system which behaves differently now.
deathandtaxes
Fri Mar 01, 2024 4:33 pm
I'm unable to update my hap ac2 with wifi-qcom-ac package to 7.14 due to disk space. I can uninstall wifi-qcom-ac and upgrade to 7.14, but cannot then add wifi-qcom-ac due to disk space.
I've reverted back to 7.13.5.
mseidler
Fri Mar 01, 2024 4:34 pm
So far so good, but what happens in Webfig when you look for the BTH Wireguard Peers. Page is continously rebuilding the list of peers (every 2 or 5 seconds).
merlinthemagic7
Fri Mar 01, 2024 4:35 pm
--Michael
yes
Please clarify if this means ONLY new 7.14 AWS T3 instance can be updated going forward.
We did a few tests:
1) Updating an existing AWS T3 running 7.8 straight to 7.14. Failed with "LoaE01".
2) Created a new AWS T3 7.14 and tried "updating" to 7.14-rc4. Failed with "LoaE01".
3) Changing an existing AWS T3 running 7.8, to T2 then updating straight to 7.14. Works, change back to T3, still works but requires the work around t3<=>t2.
If we need to rebuild all instances that were deployed with <7.14 so be it, but trying to understand why downgrading to the last RC bricks the instance like before. Cant find mention of a fix for the T3 hypervisor in the change log, so i guess it is possible it was added after rc4.
Just trying to understand if we should spend the time and rebuild all our CHR instances now or if there maybe a bug that still needs ironing out.
Kevo
Fri Mar 01, 2024 7:05 pm
I've updated my CHR instance in ProxMox and had no issues with the upgrade so far. I am just using this router as a basic home router with NAT and a couple of containers, so nothing special configured on the ethernet ports. I am running cake as well.
BrateloSlava
Fri Mar 01, 2024 7:13 pm
Good afternoon.
Today, when trying to update one hAP ac2 from 7.13.5 to 7.14, I received this out of memory error.
After which I conducted two experiments with installing ROS via Netinstall.
Two packages are installed on the router:
- routeros-7.14-arm.npk
- wifi-qcom-ac-7.14-arm.npk
In the first case, only the system package was installed via Netinstall, and the WiFi driver package was installed through additional installation into an already installed system.
In the second case, both packages were installed via Netinstall.
Conclusion: if you want to save “more” free space, install all packages via Netinstall.
sbr
Fri Mar 01, 2024 7:27 pm
I just upgraded to 7.14 and got the same. Wireguard is DEAD
DL7JP
Fri Mar 01, 2024 8:48 pm
Updated RB1100AHx4, RB2011iL, CRS125-24G-1S, hAP ac^2 and hAP ac from 7.13.5 to 7.14. w/o problems; the first three run Wireguard, all fine, nothing unusual in the logs.
notanial
Fri Mar 01, 2024 9:02 pm
A new wg configuration from scratch did the trick. I've deleted peer and wg interface and created new wg interface and peer, reassigned ip and set again interface in fw rules
Lenry
Fri Mar 01, 2024 9:04 pm
my hap ac3 upgraded to 7.14 during the night.
since then a logging rule (wireguard,info) spamming the log about "Handshake for peer did not complete" for a client that doesn't connect. which is fine, but the rule is disabled, has been for a long time. I even deleted it since, but it still spams the log.
t0mm13b
Fri Mar 01, 2024 9:26 pm
Upgraded Chateau LTE12 to v7.14, bit shocked to see the storage size plummet from 420k approx to this.
wifi-qcom-ac and routeros?
Irony was lost when I migrated from wireless package to this wifi-qcom-ac
pbr3000
Fri Mar 01, 2024 9:50 pm
Read the first messages from this topic. It's a function, but can be disabled.
holvoetn
Fri Mar 01, 2024 9:59 pm
It should be disabled as default.
So should the other messages spamming the log.
hargen
Fri Mar 01, 2024 10:22 pm
Regarding the "Handshake for peer did not complete" log messages from WireGuard... I confirmed that these were coming from my passive peer entries where I had configured a persistent keepalive. The keepalive configuration was the "trigger". Removing that keepalive stopped the messages. The remote client can still have its own keepalive configured, and should if it is connecting outward and/or inward through a connection-tracking firewall, and the client-side keepalive should be sufficient to keep the connection tracking active.
It could be argued that it is a WireGuard (or MiktoTik) bug to be attempting a keepalive when no endpoint is configured and no connection exists. But removing the keepalive configuration is an easy workaround without disabling the logging of other WireGuard,info events.
Znevna
Fri Mar 01, 2024 10:40 pm
Sounds familiar, Oh wait.
viewtopic.php?p=1059847#p1059847
viewtopic.php?p=1059520#p1059520
One could argue that having keepalive set for what you call "passive peers" is a little ... you know?
Larsa
Fri Mar 01, 2024 10:45 pm
@hargen: I can confirm that it works, but one has to wait for 20 attempts before receiving the message "Handshake for peer did not complete after 20 attempts, giving up," and then it goes silent. If you re-enable "Keep alive" it starts all over again.
Well spotted in finding the root cause. Hopefully, R&D fixes this bug in the next beta. And yeah, I consider it a true bug, especially if a passive node that lacks an endpoint address still attempts to initiate an outbound connection.
Great job!
nmt1900
Fri Mar 01, 2024 11:19 pm
That might explain why I was not seeing this flood while I have passive Wireguard peers configured - I did not have persistent keepalive enabled on them as it did not make sense to me to have keepalive set on "responder" side (even if this kind of configuration is technically possible).
dcbcr
Sat Mar 02, 2024 12:33 am
Hello dude, escuse me, me too, after install my wireguard connections Dead, i use it for a simple vpn with proton service, but fail after it, are you sure for this think, the error is for the update 7.14?.
Can u help about the solution please, i try to downgrade but is imposible to do it.
U got a solution?
Thanks, good day....
sirbryan
Sat Mar 02, 2024 1:49 am
I have passive peers without keepalive configured and I still saw a bunch of these. They weren't incessant, but they randomly came up in clusters. I ended up filtering them in the log settings for now.
Neolo
Sat Mar 02, 2024 2:20 am
Log is flooded with SA Query timeouts. Clients have terrible experience using wifi. What is going on??
Does anyone even work on this long lasting issue? Persists in all versions, including 7.14.
gigabyte091
Sat Mar 02, 2024 6:51 am
BTH not working after update to 7.14... App keep saying connecting... And I can see handshake timeout error...
Kanzler
Sat Mar 02, 2024 7:43 am
@gigabyte091,
Have you tried deleting BTH and recreating it?
ErfanDL
Sat Mar 02, 2024 8:03 am
This update is full of bugs, I have to reset hAP Lite every 2 hours to reach normal speed.
gigabyte091
Sat Mar 02, 2024 8:33 am
@gigabyte091,
No, BTH worked every update until now...
ngalfas
Sat Mar 02, 2024 8:54 am
Same here. All peers lack any persistent keepalive setting, all disabled.
The log is full for handshakes did not complete.
I even thought maybe DUDE-snmp is causing peer to be called, disabled some polling. No effect. Still tries to initiate handshakes with peers, with or without endpoints.
erlinden
Sat Mar 02, 2024 9:09 am
What is going on??
In my experience it all comes down (or goes up) with good configuration. Had to do some tweaking, enabling debug logging for wireless did provide a lot of useful information (specifically identifying the iPhone 11 having difficulties with both WPA2-PSK and WPA3-PSK enabled). If you search for SA Query on this forum you will find more information.
Guscht
Sat Mar 02, 2024 10:13 am
I dont have a Keepalive configured, but a Gateway-Check "Ping" under routes for a few Wireguard-Peers.
Was never a problem till now...
I had to edit the "Connect Priority" thing.. It will make your WiFi vulnerable to the MacStealer'-attack.
MT screwed up the WiFi totally and the network is unuseable with this "security" feature turned on (default). And left you either with an unusable network or a vulnerable network - good job MT... viewtopic.php?t=198228#p1016424
jhbarrantes
Sat Mar 02, 2024 11:29 am
Hi guys,
an error detected with devices using "fash" as disk: command to reset device and then run script with "run-after-reset" option doesn't see flash drive. Autocomplete doesn't work and input the name of the file doesn't work either in 7.14.
/system reset-configuration keep-users=yes run-after-reset=
If anyone confirms, I will open a support ticket.
Thanks!
optio
Long time Member
Long time Member
Sat Mar 02, 2024 11:47 am
I'm using same device as yours, but continued to use "wireless" package and actually gain 36KiB (500KiB -> 536KiB free) after upgrading from 7.13.5 to 7.14.
infabo
Long time Member
Long time Member
Sat Mar 02, 2024 11:51 am
The gain was minimal. The default package increased ins same size as wireless package shrunk down.
t0mm13b
Sat Mar 02, 2024 12:15 pm
Ran a wifi scan on 2.4Ghz to check the frequency and compare with between phone and laptop - chateau seized up and had to cut the power as connectivity was lost, replugged into mains again, storage went to 0 so have zero free space - have opened support ticket to find out how to clean up (what I suspect was probably a temp file in /tmp somewhere or a core dump)
urbinek
Sat Mar 02, 2024 12:35 pm
Nice work, but when Capsman and vlans will work in similar fasion as previously?
Mesquite
Sat Mar 02, 2024 1:08 pm
Moral of story, never load up a 7.X.0 version, always at least wait for 7.X.1 or 7.X.2 :-)
optio
Long time Member
Long time Member
Sat Mar 02, 2024 1:55 pm
Had similar issues with 7.13.x thats why I give up on new ac drivers and continue to use legacy, maybe your configuration is smaller and you are able to use ac on 7.13, but I doubt that as newer ROS releases arrives that you will able to continue to use it on this device unless some changes on ROS are made to offload storage (more packages).
t0mm13b
Sat Mar 02, 2024 2:15 pm
I fear, that since the introduction of the wireless package vs wifi-qcom-ac et al, implies that certain 16Mb storage devices with wireless are getting deprecated in favour of the newer drivers, and newer models.
End result is they will get left behind with a version of v7 nd not eligible for newer upgrades. They may well stop dev efforts on the wireless package completely, its going to happen soon.
Unless they do something about the wifi-qcom-ac drivers themselves which chews up more space.
Am looking at a possibility of doing a netinstall to try again from scratch.
markonen
Sat Mar 02, 2024 2:27 pm
7.14 completely disabled my WireGuard-based OOB management network.
The root cause seems to be that all wg interfaces are stuck in the main VRF even if you've specified another VRF for them.
Downgrading to 7.13.5 brought them back to the custom VRF and brought back the network.
pe1chl
Sat Mar 02, 2024 3:20 pm
Unfortunately they are not even doing THAT.
The reasonable move would be to declare 7.12.1 to be a long-term version that is supplied with security updates for a year or two, so in the meantime we can replace our 16MB ARM devices.
But no, in the event that a critical security vulnerability is found in 7.12.1 those devices immediately become useless.
arainbow
Sat Mar 02, 2024 3:21 pm
On my CHR system on Vultr, after upgrading from version 7.13.5 to 7.14, the Ethernet card disappeared. This issue had never occurred with previous upgrades, so I didn't have a backup. I had to log in to the console to create a backup, then boot into another Linux CD to copy the backup out. I attempted to downgrade to 7.13.5, trying various methods to incorporate the 7.13.5 npk file, but during the downgrade, it showed that it didn't recognize the installation package. I then tried to install a fresh version of 7.14, but the Ethernet card still didn't appear. Eventually, I had no choice but to reinstall 7.13.5 and restore the configuration.Fortunately, I succeeded.
Matta
Sat Mar 02, 2024 3:34 pm
How the hell did you update hAP Lite ? I'm missing few kilobytes to be able to squeeze in ROS and wirless package.
bratislav
Sat Mar 02, 2024 4:00 pm
With some obvious storage space issues and rose storage with btrfs and nfs kernel modules being a separate package, as it should be IMHO, I wonder why other pretty large file system kernel modules such as cifs, smb3, ntfs3 had to be added in the base routeros bundle making install next to impossible on some older but still supported devices...
mirolm
Sat Mar 02, 2024 4:34 pm
I can second that - sure samba and filesystem support is usefull and fun, BUT for me their place is not in the core. Whoever needs them can easily install a package and get the job done.
Package separation is not a bad thing. True it brings complexity in development. For me ROS should have the main router functionality there, and everything that is not needed for a simple router should be a package.
Core + wifi - cap
Core + routing - router
Core + vpn - ....
Core + ntp + filesystems - ...
Get a slim core that can fit in all routers and combine that with packages to enable other functionality would be the best. Maybe it is time to build core depending of the hardware it is used into - i find really strange to have a bunch of stuff in a cap hardware like hap ac2 which people usually use for simple home router and will never touch them. They just stay there and take valuable space.
radio303
Sat Mar 02, 2024 5:48 pm
I had so much hopes that 'reduced size' in the changelo means that 7.14 will install. But no, not enough disk space, still. Any hope that the default packages will be slimmed down?
osc86
Sat Mar 02, 2024 6:12 pm
Confirmed, downgraded back to 7.13.5 for now. Did you file a ticket?
I hope it's limited to only wireguard interfaces.
emunt6
Sat Mar 02, 2024 7:35 pm
Warning!
This is the exact reason why Mikrotik need implement OOB (Out of Band Management - IPMI/Redfish) interface - Its subsystem that independent from main OS, where you can remotely recover/reinstall/reboot the hardware. The same as the SNMP-card in the UPS system.
"Netinstall" is not a solution for "off-site" recovery.
diamuxin
Sat Mar 02, 2024 8:15 pm
+1, the same by me
+1
is very, very annoying especially with road-warrior type wireguard connections.
npeca75
Sat Mar 02, 2024 8:25 pm
it will be much MUCH better for MT to name this release v8
after all, wireless packages are radically changed, ROS does not fit anymore on old devices, many bugs, etc ...
anybody who work with relative stable 7.12.2, and blindly push update button, will be in big big trouble
so, please MT
move this version to v8
it does not seems right that this version have same V7 name with so many breaking changes
Znevna
Sat Mar 02, 2024 8:38 pm
v7 stable but >90% functional when?
Znevna
Sat Mar 02, 2024 9:04 pm
+1, the same by me
+1
Disable wireguard logging and stop bitching.
infabo
Long time Member
Long time Member
Sat Mar 02, 2024 9:06 pm
People will still hit the upgrade button YOLO
vsn
Sat Mar 02, 2024 9:37 pm
Hello, after install on hap ac2 7.14 I have no free space. (with 7.13.1 it was about 2%) ; now, when I make some change and restart Mikrotik, the changes miss, even deleting unused FW rules, disabling resource gaphing and queue
MK just should separate some other packages which usually home users dont use (as. dot1X, PPP; MPLS and Radius)
Rox169
Sat Mar 02, 2024 9:42 pm
so, please MT
I have 10 years old SXT with 7.14 and 3,7MB free
vsn
Sat Mar 02, 2024 10:41 pm
[/quote]
[/quote]
But its without package qcom-ac , which is only reason for me update to 7.13+
With netistall on different MK (cap ac) its. Also 97% disk used.
ColinSlater
Sun Mar 03, 2024 12:58 am
Can report that I've just upgraded my RB4011 (RB4011iGS+5HacQ2HnD)... everything seems to be working fine.
The upgrade process very kindly installed the WIRELESS package for me (very kindly as this is my home router and therefore, I do use the WiFi function on it).
Will report back again if I find any issues along the way.
doka
Sun Mar 03, 2024 2:33 am
expose "lo" interface
I guess, you don't need anymore work around "absense" of loopback and create bridge "Loopback" and can assign loopback address directly on the lo interface, i.e.
NOT REQUIRED:
/interface bridge add name=Loopback
/ip address add address=x.x.x.x/32 interface=Loopback
while it will be just enough
/ip/address/add address=x.x.x.x/32 interface=lo
Rox169
Sun Mar 03, 2024 6:15 am
Mine AC2 is OK, do netinstall....
infabo
Long time Member
Long time Member
Sun Mar 03, 2024 6:34 am
vsn runs wifi-qcom-ac on hAP ac2
BBCWatcher
Sun Mar 03, 2024 6:59 am
I've upgraded my hAP ac3 and hAP ac2 from 7.13.5 to 7.14. The hAP ac3 is fine. For the hAP ac2 I used netinstall. Free onboard flash space (with wifi-qcom-ac instead of wireless) is down to about 356 KiB (versus 7.13.5 at around 635 KiB). It was too tight before IMHO and now really too tight. I'm considering reverting the hAP ac2 to 7.13.5 since 356 KiB is so uncomfortably close to the "cliff edge."
I appreciate the RouterOS development team's work to expand the support for Wave 2 Wi-Fi to devices such as the hAP ac2. The 802.11r/k/v support is especially appreciated. However, if RouterOS is to grow then it seems vital to keep base RouterOS "skinny" (down around 10MiB) and allow less popular features (particularly those not needed for the boot process itself) to reside in secured/paired USB-attached (and eventually network-attached) storage. That'd solve the space constraint issue on 15.3/16MiB devices for years to come.
macak
Sun Mar 03, 2024 9:38 am
Updated/upgraded inplace (no netinstall) from 13.5 to 14
1. RB 450Gx4 (capsman) + OVPN Server + two Internet interfaces (just ethernet and PPPoE to Orange.pl) + config for Orange TV + VLANS (quite complcated config).
2. CAP AX (x3) (caps)
3. HAP AX2 standalone + OVPN client (max speed close to AP is around 800Mbps over air, over cable around 900Mbps)
4. HAP AC stanalone + OVPN client (I'm thinking about replace)
5. HAP AX Lite LTE + OVPN client
6. mAP 2nd lite. (acting as travel securuty router PC ->mAP -> LTE router over WiFi -> OVPN -> to server, one virtual one static WiFi).
All updates over packages menu without issues. (of course export + backup before!)
So far
OVPN much much more stable! Thanks (Gx4 is'nt ARM64, but over a day stable connection in my case! Thanks).
Other - looks very stable in my case.
Two feature requests:
1. BTH client feature to knock interface before connection.
2. Improve the registration view. Still there is no CAP where user is logged in. So You shoult think radio 12... this is CAP at garden or room.
One hardware request. :-)
1. New mAP lite with AX chipset (same size as Map2nd lite) + normal USB port to connect to the phone will be perfect as emergency/trip gateway.
You are the best!.
jhbarrantes
Sun Mar 03, 2024 10:07 am
Indeed, joining to the wish list: mAP Lite AX: usb-c + PoE-IN + gigabit port + 2,4 wifi ax in a modern ARM architecture. And the magnet, don’t forget the magnet!
That will be an amazing swiss knife to carry on with you while traveling.
Regards!
holvoetn
Sun Mar 03, 2024 10:24 am
mAP AX in mAP Lite package, don't think so.
Thermal issues.
mAP package/size, maybe... that would be very sweet.
massinia
Sun Mar 03, 2024 10:48 am
This is my hap ac2 with wifi-qcom-ac and also docker package:
How do you have 356 KiB with only ros and wifi-qcom-ac using netinstall?
Install all packages with netinstall.
t0mm13b
Sun Mar 03, 2024 11:37 am
Fingers crossed that MT can opensource their code to allow for improvements - or open up the bootloader to allow for likes of openwrt etc to be easily installed on the devices. More likely until hell freezes over :)
pe1chl
Sun Mar 03, 2024 11:51 am
I am not asking for any policy changes, only for long-term support of the 7.12.x version.
Lenry
Sun Mar 03, 2024 11:54 am
+1
it IS disabled
now everyone has to explicitly disallow WG logging. Sorry, but I fail to see this as "improve and optimise"
Znevna
Sun Mar 03, 2024 12:49 pm
If you have to disallow it isn't disabled. Logic, right?
Same as dhcp leases info and other random crap that gets logged by default, which, wait for it, YOU CAN DISABLE (hide..).
I'd rather have logs that I can disable instead of no logs at all.
Don't be lazy.
Or bitch to MikroTik to improve the improvement and move it to 'debug' instead of 'info'.
LESHIYODESSA
Sun Mar 03, 2024 4:10 pm
What am I doing wrong? Why does an error occur with NFS.
hAP ax³ (7.14) + rose-storage-7.14-arm64
update Did I understand correctly that they forgot to update the documentation? The code is now like this — /disk set usb1 nfs-sharing=yes
https://help.mikrotik.com/docs/display/ ... rage-iSCSI
Amm0
Sun Mar 03, 2024 4:36 pm
Apparently, my configs with NFS got migrated to nfs-sharing=yes at some point – seem to work as I didn't notice till just now. But doc do show nfs-export=yes...
And docs and CLI's "F1 help" still don't describe the options for ROSE. And docs do not mention the "dynamic /ip/smb" entries created by smb-export=yes smb-sharing=yes in ROSE /disk settingin versions after ROSE SMB being moved to main package. In fact docs now have incorrect information re SMB:
RouterOS also supports older SMB without ROSE package - SMB with legacy protocol support.
fornuftFTW
Sun Mar 03, 2024 5:08 pm
Help, this update broke my containers. I just get "execve: No such file or directory" in the log on both of my containers when I try to start them.
Here are the relevant settings:
The containers are on a USB drive that seems to be working fine. What's the error, how can I get them working again?
splastunov
Re: v7.14 [stable] is released!
Sun Mar 03, 2024 5:50 pm
The same problem here.
I have several xcp-ng (XEN) servers with different host OS version running multiple CHRs.
After upgrade to 7.14 CHR can not detect any network interfaces, but in list for IRQs I can see vif0-q0-rx, vif0-q0-tx.
The latest "working" version is 7.13.5.
After rolling back to 7.13.5 and restoring from a backup, the CHR starts working normally
krafg
Sun Mar 03, 2024 5:52 pm
My R11e-LTE-US keeps on boot loop. I Can't upgrade to this version.
This version creates a weird loopback interface that keeps running but LTE2 never boots up.
Downgrading to 7.13.5 problem solved.
LTE firmware is up to date on both LTE interfaces and RouterBOARD firmware keeps on 7.13.5 on all devices.
Tested on LtAP. I also have an RBM33G to do the tests.
Regards.
frank333
Sun Mar 03, 2024 7:01 pm
on rbm11 scripts with fetch still do not work, I have reverted to 7.12.1
Amm0
Sun Mar 03, 2024 7:30 pm
Interesting...
*) lte - added "at-chat" support for Sierra Wireless EM9293 5G modem;
But it's not listed on: https://help.mikrotik.com/docs/display/ROS/Peripherals
Does the Sierra EM9293 support reading RSRQ, RSRP, etc.? Previous generations Sierra modems only support reading "RSSI" via RouterOS.
Chupaka
Sun Mar 03, 2024 7:57 pm
Re: wireguard... Why the heck it's always "try 2"? Not try 3, 4, 5... All 20 attempts are try 2 :)
infabo
Long time Member
Long time Member
Sun Mar 03, 2024 7:58 pm
try 2 connect
zentavr
Sun Mar 03, 2024 8:10 pm
> *) x86 - fixed VLAN tagged packet transmit for igb (introduced in v7.12);
Unfortunately this had not been fixed. My VLANs at IGB and x86 not work at all :(
diamuxin
Sun Mar 03, 2024 8:37 pm
+1
That a passive peer (without endpoint) constantly tries to perform a handshake, transmitting data to nothing, just because it has a 0.0.0.0.0/0 in the allowed address, which is what is happening. This behavior is irregular, and is a bug to be fixed.
Znevna
Sun Mar 03, 2024 8:40 pm
Take it up to the wireguard devs. It's not something for MikroTik to fix.
holvoetn
Sun Mar 03, 2024 8:43 pm
Wireguard behavior is not the problem.
The all of a sudden excessive logging is.
This is debug and by default it should be off.
Same with dns, ntp, dhcp... I've seen it all pass by.
jhbarrantes
Thermal issues.
Also good! I'm big fan of these two mini routers. Specially mAP (not mini version) saved me when doing netinstall froma laptop that doesn't have ethernet port. And mAP-Lite was for quite a long time my guests wifi network, and it works flawlesly.
Don't mind ot see these improvements on a mAP either, if thermal issues arise on such a small gadget, regarding mAP-Lite.
Regards!
sajt
Sun Mar 03, 2024 8:56 pm
No, in my experience it affects eoip and ipip tunnels too.
diamuxin
Sun Mar 03, 2024 10:22 pm
Exactly, I think the same.
monotsc
Sun Mar 03, 2024 10:52 pm
what kind of NIC you have ? my i350,i210/i211 on 7th gen intel working again after 7.12/7.13 bug
Znevna
Sun Mar 03, 2024 11:03 pm
You seem to be contradicting yourself. Which one is it?
Neolo
Sun Mar 03, 2024 11:11 pm
Connect Priority 0/1 does not help in any way. I set it on all APs and still see those SA timeouts in the log.
Cha0s
Sun Mar 03, 2024 11:41 pm
Can you post an example?
I don't see any difference (besides wireguard) on my logs with v7.14.
What has been annoying to me is the inclusion in the logs of the full edit command of each and every action done via cli/winbox a few versions back (I think in 7.11?).
Especially when editing large scripts, the whole log window can get filled just with one action.
We went from vague and useless logs like this:
device changed by admin
To excessively verbose and practically still useless (who can read this without copying it to notepad - since it doesn't even fit in any screen resolution) like this:
device changed by winbox-3.40/tcp-msg(winbox):admin@x.x.x.x (
/interface set ether9 disabled=no l2mtu=1596 mtu=1500 name=ether9; /interface ethernet set [ find ]
advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full
arp=enabled arp-timeout=auto auto-negotiation=yes combo-mode=auto disabled=no fec-mode=off l2mtu=1596
loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1500
name=ether9 rx-flow-control=off sfp-rate-select=low tx-flow-control=off; /queue interface set ether9
(I've added the break lines - it's even worse in the log window in a single line)
Instead of logging the relevant change only so with one glance in the logs you know who did what you get this mess that eventually no one will actually read.
The end result is the same as with the old vague logs. You don't know what the user actually did unless you know by heart every single configuration that has been done previously on the router.
Yes you get the full command run but not the actual change.
Did he change the mtu? the loop-protect? the advertise rate? You cannot know, because it includes every single option instead of only what the user actually changed at that given time.
diamuxin
Sun Mar 03, 2024 11:44 pm
I am not contradicting myself (if you had tried it you would understand). I keep insisting that it makes no sense for the passive peer without endpoint to constantly try to handshake, it's a debugging problem not a wireguard interface problem. If you don't understand it is your problem.
pe1chl
Sun Mar 03, 2024 11:45 pm
I actually think that logging of changes is great! Especially when you have an external log server, you can check when something was changed and by whom.
Cha0s
Sun Mar 03, 2024 11:47 pm
Yes, but only log the actual change, not every single argument that /interface/set takes and the user didn't touch.
Znevna
Sun Mar 03, 2024 11:50 pm
Yet again, that behaviour described by you is not a MikroTik problem, but a WireGuard "problem", not something that MikroTik should address.
What MikroTik is doing with the logs provided by WireGuard is a MikroTik problem.
You seem the be the one not understanding .. something. Sorry, probably not your fault.
Cha0s
Sun Mar 03, 2024 11:53 pm
Upon further testing, when running commands from the command line it only logs the relevant parts
e.g.:
[admin@MikroTik] > /interface/set ether9 disabled=yes
Logs the following:
device changed by winbox-3.40/tcp-msg(winbox):admin@x.x.x.x/terminal/action:0 (/interface set ether9 disabled=yes; /interface ethernet set [ find ] disabled=yes; /queue interface set ether9)
That's useful (even though I still find it a bit excessive, it is readable/usable).
But when doing the same exact action (disabling the interface) from WinBox it logs every argument even though it wasn't even touched.
device changed by winbox-3.40/tcp-msg(winbox):admin@x.x.x.x (/interface set ether9 disabled=yes l2mtu=1596 mtu=1500 name=ether9; /interface ethernet set [ find ] advertise=10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full arp=enabled arp-timeout=auto auto-negotiation=yes combo-mode=auto disabled=yes fec-mode=off l2mtu=1596 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mtu=1500 name=ether9 rx-flow-control=off sfp-rate-select=low tx-flow-control=off; /queue interface set ether9)
Now that's useless. You don't know what the user actually did, unless you already know what the interface status was before and what settings it had.
infabo
Long time Member
Long time Member
Mon Mar 04, 2024 12:15 am
Nope. That is what I am pointing out for years already. Winbox touches everything - now you even have the proof logged 🤣. Even can add arguments that were not there before (in the export). Dumbly saving of all form values - even if they are default values. Thats why I do not use winbox, because I dont like side effects.
anav
Mon Mar 04, 2024 3:30 am
Nope, that simply means MT has to fix winbox.
holvoetn
Mon Mar 04, 2024 8:44 am
viewtopic.php?p=1059747#p1059747
NTP, DNS, DHCP, ... all debug info now all of a sudden visible in log files.
sch
Mon Mar 04, 2024 9:22 am
Please contact support and add the supout.rif file from your system.
gze100
Mon Mar 04, 2024 9:55 am
All ethernet interfaces on the CHR machine on the VDSINA hosting are missing. I checked the installation process twice, the ethernet is always lost. I installed 7.13.5, the ethernet is back.
I have the same problem and opened a support ticket for that. Today I got the following information from the mikrotik Support: "We have managed to reproduce the issue locally in our labs and look forward to fixing it on upcoming RouterOS versions, unfortunately, I cannot provide a release date now."
nmt1900
Mon Mar 04, 2024 10:40 am
Can we be sure if Winbox saves/overwrites all this values or they are just "read out" to be saved in log message? If values are actually overwritten then it is possible for them to change if defaults are changed (and therefore applied?) after upgrade to newer version and that can also bring unwanted side-effects with it. If it is just related to logging then it just is misleading and confusing - but unwanted in both cases...
infabo
Long time Member
Long time Member
Mon Mar 04, 2024 10:42 am
Nobody has issues with 2.4ghz wlan with/without capsman?
Kanzler
Mon Mar 04, 2024 10:44 am
@infabo,
What exactly issues?
mkx
Mon Mar 04, 2024 10:57 am
If values are actually overwritten then it is possible for them to change if defaults are changed ...
That would require support in winbox ... either "winbox default config" (which would then depend on winbox version) or winbox would be able to read (and interpret) device's default config (which means building in interpreter of default config ... which winbox currently may not have, changing of settings may not depend on ability to parse and interpret random configuration lines).
But even if winbox would support it somehow, we'd be in same dilemma: do we apply defaults to a particular setting just because default changed? The argument behind leaving config on running device is that "don't fix it if it ain't broken" and that applies both to winbox and upgrade process.
What IMO could be done is that winbox would be able to show defaults (if applicable) so one could apply them by hand if deemed fit.
pe1chl
Mon Mar 04, 2024 11:09 am
Well that can be debated, probably it was too much effort to keep the before-state and compare it with the after-state and log only the changed values. Would all take extra code, and we already are short on storage space.
Without that, I like it that they added this logging because it provides some traceability of changes made, and alerts to changes made outside of the admin's intention.
pekr
Mon Mar 04, 2024 11:10 am
The comment from w0lt was correct. In order to disable specific topic logs, go to System/Logging and open, for example, "info" topic. Add "!wireguard" to it. All info logs, except WireGuard, will be logged now.
Yes, these are new logs, nothing changed in the WireGuard behavior. Same actions simply were not logged before.
Default system logging should be made non intrusive not allowing one topic excessive logging imo. I see the point of info topic being accustomed by using !wireguard condition as wrong aproach.
pe1chl
Mon Mar 04, 2024 11:15 am
Yes, that would be valuable. Sometimes it is difficult to find what the default value is for a parameter that has been changed at some time, and a separate widget near every field to "reset to default" could be nice.
(of course when the default is "empty field" or "unset field" that is already available)
However a more useful, and probably more difficult to implement, feature would be to reset some category of settings to default.
E.g. the whole configuration of the firewall (for IP and IPv6). Or the whole configuration of wireless. Or the whole configuration of LAN (IP address and range, DHCP server and pool).
That would more likely not be a winbox feature but rather some change in the defaults script on the router.
pe1chl
Mon Mar 04, 2024 11:20 am
I agree with that. This is just a log that should have been suppressed in the code (don't ever log connection attempts when the interface is configured as passive, even when there is outgoing traffic)
Also I think (and have suggested before, as others also did) that the whole structure of logging and topics needs an overhaul.
There should be a unique ID to every message the system can log and that you can filter as a topic (so you can suppress this particular message without suppressing all other info,wireguard messages at the same time). Lacking that, it would be useful when the logging configuration allows addition of a "regexp" that you can use to filter (include/exclude) messages based on matching on the message content.
infabo
Long time Member
Long time Member
Mon Mar 04, 2024 11:22 am
@infabo,
see viewtopic.php?p=1060364#p1059669
PS: issue re-appeared. Not gone.
Kanzler
Mon Mar 04, 2024 11:24 am
@infabo,
I don't observe such a problem on the hAP AC3 + wifi-qcom-ac
Cha0s
Mon Mar 04, 2024 11:48 am
Apparently the problem is that Winbox, while it knows what has changed on each window (since each modified field becomes blue), when you hit apply, it sends EVERYTHING, instead of only the options that have changed.
As I said, through CLI, the new logging, is how one would expect it, so the problem is actually with winbox, instead of logging.
It doesn't need to keep track of anything with the before and after state and compare anything. I don't think you understood what I said.
If you only log the exact option that was changed each given time, then you know exactly what was changed. ie: I disabled interface ether9.
If you log every option (those that were changed alongside those that were not changed) then you don't know exactly what was changed. ie: was the change the mtu size? the rate? was the interface disabled? You have no idea, since all options are being logged at once.
There's no need to keep track of anything and compare nothing, if you JUST log what was changed only on each given action, instead of everything.
So to fix this, just make winbox update only changed fields instead of every field, and logging will follow without any code change there.
And presumably that's a client side only fix, so space restraints are not an issue either.
Cha0s
Mon Mar 04, 2024 11:50 am
I've installed 7.14 on multiple routers with multiple archs and I cannot confirm this behavior on any of them.
Except for wireguard where I had to exclude it from being logged as it spammed the log window.
pe1chl
Mon Mar 04, 2024 12:07 pm
Probably when using CLI it will also log everything when you send it everything...
The winbox GUI presents you with a panel with all possible settings, reads the existing values in it and then you can change them and submit the whole thing. There is no way to submit individual fields.
So this before/after thing could be done inside winbox. But it could introduce new issues when there are two winbox sessions open at the same time (two admins) and changes are being made to the same item. As it is now, the last one wins. With the above solution, the result could be ambiguous.
tdabasinskas
Mon Mar 04, 2024 12:34 pm
I've upgraded two RB5009UPr+S+IN to v7.14. All good with one, but, for some reason, the second one has issues with containers: existing containers cannot be started and new ones cannot be created. Couldn't find anything in the log for why.
infabo
Long time Member
Long time Member
Mon Mar 04, 2024 12:37 pm
Well, you've reverse engineered Winbox? cool
Znevna
Mon Mar 04, 2024 12:55 pm
Can you provide the output of
/system/logging/print
sanity check.
Cha0s
Mon Mar 04, 2024 1:01 pm
Of course it will. That's the whole point. Log the stuff you change, not EVERYTHING. If you change 100 options, then by all means log all those 100 options.
That is useful when auditing the logs.
To see who changed what. As it stands now, you don't know what user X changed out of the 100 options that it currently logs when done via Winbox.
WinBox already knows exactly which fields has been changed before you hit apply.
Each field you edit becomes blue (or red if you input an invalid value).
So Winbox already HAS this information, and sending every option even if it hasn't been changed is a design decision.
No ambiguity at all.
What happens currently if an other admin changes something on the same window you are working on at the same time?
Winbox just updates the fields that you haven't changed dynamically on your window as well.
If you then hit apply your change will get applied, along with whatever the other admin already changed (and has changed on your window too).
Weather winbox sends all options or just the options you changed, the last one always wins.
If winbox windows didn't dynamically and instantly update on each and every change made by anyone logged in, you would have a point. But as it works right now, the last one already always wins regardless if winbox sends everything or only the stuff that changed.
The point here is this:
Do you disagree that logging EVERY option when it hasn't been changed, is excessive or not?
The how or why is a MikroTik problem not ours. Do you disagree with the core of my argument?
shyrwall
Mon Mar 04, 2024 1:06 pm
Warning!
CCR2004-pcie doesn't come back after upgrade. it's crazy what You do at mikrotik, to release fw *STABLE* that bricks cloud core unit.
looks like boot-loop.
HOW to get it working back on remote location!???
Same. And it also causes a kernel panic in the host everytime it "reboots".
shyrwall
Mon Mar 04, 2024 1:34 pm
Warning!
Dumbest I've heard. Can't even imagine Cisco or Juniper putting out a stable release that bricks the product.
1. Stable should mean they tested it on all their products that supports upgrading to that version.
2. If the issue was mentioned for a beta version then of course it should be fixed before releasing a stable version.
3. If the problem was known and not fixed the software should not allow the upgrade.
Side note. The ccr2004-pcie should not even have been released with a reset button that needs you to open the server up.
pe1chl
Mon Mar 04, 2024 2:07 pm
But you pay 3 times the money for a comparable product. Your decision.
shyrwall
Mon Mar 04, 2024 2:23 pm
They can only compete in the home to small business segment and for nice special features like wireguard. For other areas they're not cheap anymore. Bought a new Cisco Nexus router/switch a month ago, 48 x 10/25Gbps + 6 40/100Gbps ports. Closest Mikrotik comes is the CRS512 which is more expensive and has less ports.
Also if comparing product to product I don't think there is another company having a product like the ccr2004-pcie but I think I should atleast be able to upgrade to a version with stable in it's name without bricking it :D
pe1chl
Mon Mar 04, 2024 3:19 pm
I agree with that, but at the same time I recommend to always research the status of a new release before blindly installing it.
When Microsoft releases a new version everyone is talking about issues and how to force remaining on the old version, but when MikroTik releases a new version lots of people just click "upgrade" and then later come here to complain. However the issue with CCR2004-PCIe was already reported here and still people install it.
Remember a "stable" version is just an "rc" version combined with a planned release data of next version. It is not widely field-tested and issues will appear immediately. That is why I recommend waiting for .1 version when it is important for you.
chrisfr
Mon Mar 04, 2024 4:49 pm
with CRS-305 from 7.13.1 with rose-storage package and container package to 7.14, the switch doesn't start (boot loop).
i Netinstall to 7.14, reinstall RoseStorage and Container package. After that, when i try to upgrade to 7.15 beta, i have the same issue (boot loop).
Maybe it's a storage issue ?
I will NetInstall again to 7.14, be carefull if your have the same setup ..
Edit : i did a test without rose-storage and container package and the upgrade is fine, so this could confirm a space issue when those packages are installed
Znevna
Mon Mar 04, 2024 5:06 pm
There's a new stable in the beta channel.
Archous
Tue Mar 05, 2024 2:09 am
In addition to the bug reported about IPIP interfaces not working correctly with VRF, also IP service does not work fine with VRF anymore.
I have IP service www on VRF and does not respond to requests anymore, while all is fine with 7.13.5
Came here to reply the same issue is happening to us where we have IP services in VRF.
jbl42
Tue Mar 05, 2024 2:21 am
Updated the RB5009 in my home and several RB4011 in the lab from 7.13.5 to 7.14. No peculiarities so far, except the known bridge-MTU-change-on-reboot fixed in 7.15rc
Yes, a button/switch would be nice.
We solved this for our lab unit by drilling a small hole in the slot sheet metal, gluing in a small push-button and wiring it up to the reset solder pads.
On Linux, it can also be "soft" reset issuing
sudo echo "1" > /sys/bus/pci/devices/<id>/remove
sudo echo "1" > /sys/bus/pci/rescan
The <id> can be retrieved with
lspci
command
jbl42
Tue Mar 05, 2024 2:35 am
That's interesting. The cheapest Switchzilla Nexus with 48 x 10/25Gbps + 6 40/100Gbps I'm aware of is more than 10'000€...
Which Nexus model did you buy for less than a CRS518?
peri
Tue Mar 05, 2024 2:54 am
After upgrading a ccr1009 and a ccr1036 EOIP and IPIP interfaces, tho under the the ip/vrf menu did appear in the correct vrf, in reality the addresses and directly connected networks became part of the "main" vrf.
Downgrading to 7.13.5 solved the issue.
I have the same question.
3dfx
Tue Mar 05, 2024 9:14 am
After upgrading to v7.14 I lost connectivity between OpenVPN server and clients in Ethernet mode. The connection is established normally and automatic routes are created, but still peers are inaccessible.
Anyone experiencing similar behaviour?
Edit: It's the same with v7.15beta4. Reverting back to v.7.13.5 solves the issue for me.
AndiiiHD
Tue Mar 05, 2024 9:34 am
- changed default "fan-min-speed-percent" from 0% to 12%;
- improved fan control on CRS3xx and CCR1016-12S-1S+r2;
I have no fan control at all after this 7.14 update. The fan of my CRS310-1G-5S-4S+IN runs with annoying maximum speed and reports ~+-13000rpm regardless which settings i put in the health settings menu. CPU temp was 39°C and Board around 33°C with default settings for the temperature control.
Only a full rollback to 7.13.5 and loading the backup solved it immediately. Please have a look into this.
Znevna
Tue Mar 05, 2024 2:48 pm
Hey @MikroTik, for a small fee and donated hardware I can test all these releases on all the equipment you send me, before going public with that release.
So that you know, we can avoid crappy releases like these?
Deal?
We can even put togheter some testing "laboratory" over the internet with other clients to make it more entertaining.
But you have to pitch in and stop relying on actual deployed hardware by those users to test these releases.
pe1chl
Tue Mar 05, 2024 5:29 pm
I have seen (in the past) photos of a "test lab" that they use to test new versions.
The main problem is that they test mainly with "default config" so many other configs and features are not tested...
(and they never discovered that storage is running out on 15.3MB devices because in default config it does not yet happen)
Znevna
Tue Mar 05, 2024 6:00 pm
A fan going 13000RPM for no reason is easy to spot*, by noise or monitoring data.
"Hey there's something wrong in this chart, memory usage is way higher after one hour, something must be leaking"
"Hey this fan didn't spin that fast before the update"
"oh we have two devices that aren't reporting stats, they look bricked mmmbad"
"oh hey these CHRs are offline, hmm."
NAAAAAAH PUSH IT LIVE IT'S FINE.
kaber
Tue Mar 05, 2024 6:29 pm
RBSXTsqG-5acD become nonresponsive and started bootlooping after upgrade from 7.13.4 to 7.14. Had to hard reset back to 6.49.10.
wfburton
Tue Mar 05, 2024 7:07 pm
Can't use any version in the 7.13 branch.
CRS309-1G-8S+
Both processors run at 60% and the time. Just took notice a few days ago and tried all versions in the 7.13 branch. Same thing cpu 60%
Had to move to 7,14 to get the processors to run normal, about 1%
Can't post in 7.13 since it's locked.
infabo
Long time Member
Long time Member
Tue Mar 05, 2024 9:23 pm
wfburton, I've read the changelog for you:
*) system - fixed "cpu-frequency" for CRS3xx ARM devices;
nmt1900
Tue Mar 05, 2024 9:38 pm
If that is true, it explains quite a lot of these "issues" we always see when new release comes out. One other thing might contribute to "breakages" as well - RouterOS does not seem to have any control over how objects can be handled i.e. you can add the bridge or any other non-physical interface and build many things around it and then you still can just delete this object outright which can leave many things in broken state - if I deal with Fortigate then I can only remove objects after all other references to it are already removed (interface is not in any firewall policies or have any other related objects attached to it).
catengineer
Tue Mar 05, 2024 11:19 pm
On my RB5009UPr+S+IN the upgrade went fine.
Only one strange thing, after reboot my active interfaces without POE devices were red, "PoE out status: short circuit"...
pe1chl
Wed Mar 06, 2024 11:39 am
Then you probably upgraded from a quite old version. Always mention your previous version.
You can go to interfaces->ethernet and open each interface and set PoE to "off" where you do not require it.
pe1chl
Wed Mar 06, 2024 11:45 am
I think they are hoping that putting out beta and rc versions results in reports from users in the field about new problems.
What surprises me is that the replies on those topics are not very actively read, and it often happens that some people reported an issue in that topic, it is not fixed before the "stable" release, and then MikroTik employees say "well, you should have made a ticket, we cannot read all those replies".
I would think that reading all those tickets is much more work than reading forum replies, because the ticketing system is closed so you cannot know if the issue you report has already been reported by someone else. The forum at least allows you to see that it is a problem already reported so you do not need to make another full report.
That is true, but I have never encountered a situation where that lead to real problems.
Usually what you see is that an object that references a deleted object gets some nasty comment associated with it, it becomes non-functional, and you can still delete that object. Also, when you do an export you get a reference starting with "*".
When I make an export after lots of changes I usually check if there is any "*" in it.
JanezFord
Wed Mar 06, 2024 12:54 pm
Upgraded successfully the following: bunch of CCR1009 devices, chr, 4011 and 5009
Crashed horribly with reboot loop (needed to netinstall): wAP-AC-LTE6 kit. (arm). Works fine for now with fresh 7.14 install.
JF.
nmt1900
Wed Mar 06, 2024 1:49 pm
Yes but we can not be sure about all possible side effects of these inconsistencies might have with any possible combinations of correct or incorrect base configurations anybody might have. Object with inconsistencies can be deleted but not everyone is able or interested in sanity checking for these inconsistencies - which might have a potential to introduce post-upgrade breakages. We have inherent weakness here and can not be sure what "under-the-hood" problems could possibly be introduced by that.
savage
Wed Mar 06, 2024 2:19 pm
Well...
Whilst I am happy and grateful to FINALLY have a v7 AMI on AWS... Reading this thread, I'll skip on 7.14
Amm0
Wed Mar 06, 2024 2:39 pm
All you get is a broken config, not "inherent weakness". RouterOS, as general practice, never deletes config you added. e.g. if you delete something like a VLAN, you don't want the DHCP server necessarily being removed (and that then begs question should /ip/pool linked to dhcp-server be delete too?). Often you delete some "parent" config, to only then add some replacement back & easier to rewire the "dependent" items to new parent.
Now... RouterOS could have more features/helpers that "dynamically" add config — like BTH which add dynamic firewall rules and other config based on "one action" – but this config added is marked with with a "D" – dynamic – so make perfect sense the system cleans up dynamic items it added (if later deleted). But items when admin add config via winbox/cli ("statically"), should stay in the config – even if with an invalid reference to something – until user removes.
ali321
Wed Mar 06, 2024 7:59 pm
How do i delete loop back interface? i am not interested in
savage
Wed Mar 06, 2024 8:00 pm
Can't. And ditto. If I need a loopback, I'll create one :)
infabo
Long time Member
Long time Member
Wed Mar 06, 2024 8:24 pm
Do you fear the loopback? Don't install/use a Linux OS - you always have a loopback interface available. I did not know that I need to have angst.
holvoetn
Wed Mar 06, 2024 8:26 pm
Don't even use Windows then ... or whatever device having an IP stack.
spippan
Wed Mar 06, 2024 8:31 pm
it was, is and always will be there
now MT is just exposing it to use it.
what is all the struggle with a Lo available? don't get it.
DeviceLocksmith
Thu Mar 07, 2024 1:41 am
Well, I would call it quite irresponsible to install a freshly released 7.xx version at a remote location within a day after release, especially when the same issue was already reported in the release topic...
Also, as mentioned many times before, the label "stable" refers to the stability of the release process, not to the stability of operation.
When you require stability of operation, always wait for the 7.xx.1 version and do not install it within a week of release.
Then you have not worked with Cisco enough. I've hit bugs which brought down both RPs/Supervisors and got them into bootloop. Don't even get me started on having to slide the line card out of chassis to access console on some Cisco boxes, which triggers spanning-tree convergence. Not something you want if that is in your core.
shyrwall
Thu Mar 07, 2024 10:32 am
Didn't say Cisco/Juniper don't have tons of bugs but I've never come across a "recommended release" that does not allow the product to boot after upgrade. Especially now in recent years when there's an impact/compability check etc before upgrading.
pe1chl
Thu Mar 07, 2024 11:37 am
Ok but that is where you are going wrong. The MikroTik release tag "stable" does not make it a "recommended release".
Even "long-term" doesn't do that. You need extra research to know if a certain release is recommended for installation.
rushlife
Thu Mar 07, 2024 2:16 pm
I am using CAPSMAN for AP and "station-pseudobridge" for some wireless clients and with ros 7.14 on client side is there packet loss. And pretty masive packet loss. Around 10% with small packet and more in some cases with larger (1200 and above). Careful with that. Reverting to ROS on client side 7.13.5 solved this whole situation.
infabo
Long time Member
Long time Member
Thu Mar 07, 2024 2:50 pm
Same situation here. I have some legacy ROS wireless clients in "station-pseudobridge" and these cause massive issues only since 7.14. I guess RSTP or something. But nothing in the logs. And I did not find out how to log/debug it.
rushlife
Thu Mar 07, 2024 3:11 pm
..unfortunately I have not did some more research, things had to be sorted right away and I did not have any more time to testing almost anything. I didn't even make a couple of supouts. F*ck
I did noticed one thing, MIPSbe client in pseudobridge (connected with 802.11n mode) have all massive packet loss. On other hand, client in pseudobridge with ARM architecture and connected to 802.11ac network works fine. No loss whatsoever.
fikkar2
Thu Mar 07, 2024 4:04 pm
If this is what Mikrotik definition of "stable" really is, please modify winbox UI on "Check For Updates" so we can have option to pick wich version that we want to install/upgrade to. Currently, winbox UI only give us option to upgrade to the latest version. Even worse for arm device, we only have version 7.X (latest) as an option.
Please mikrotik provide us with option to upgrade not only to the latest version but also to couple of version (if not all versions) before it.
pe1chl
Thu Mar 07, 2024 4:26 pm
I agree with that. There should be more options in upgrade, and more release tags. E.g. for v7 there should be an option "long-term" that corresponds to 7.12.1
Versions after that should be considered "experimental" for now.
jonmansey
Thu Mar 07, 2024 7:24 pm
Just upgraded to v7.14 with wifi-com-ac on a hAP ac3, the 2.4GHz wifi is down reporting "failed to select channel". Under WiFi Channel Frequency, I tried no setting, setting a range 2412-2462, and setting specific channels eg 2412, all with the same result. After enabling, it sits there with "selecting channel" in the status field, and after about 30 sec or 1min, it shows in red "failed to select channel". Country is set to United States. The 5GHz radio is working fine.
Downgraded to 7.13.5, all back to normal.
johnson73
Thu Mar 07, 2024 9:39 pm
Router RB962UiGS-5HacT2HnT, Version 7.14 - problems with the 5Ghz wifi module!
I changed different channels, including auto mode, wifi jerks, connects to the Internet very slowly, traffic drops every little while. Everything is ok with 2.4Ghz. Default settings for the router. It was restarted 2 times and without changes. And it's not really clear why the red Led light flashes all the time?
After long tests, update to ver. 7.15bet4. Started working with this version, but - Intel card AX210, which is new, does not see 5Ghz wifi, if there are default settings 20/40/80Mhx XXXX. If I change to 20/40/80 Ceee, then everything works. My ISP line speed is 600Mbit. It is impossible to get more than 350 Mbit from 5Ghz wifi.
Dario1982
Thu Mar 07, 2024 11:51 pm
Following units upgraded and running fine since one week
RB5009UPr+S+IN
CAP AC w/ wifiwave2 driver
HAP AC2 w/ wifiwave2 driver
RBSXTR (sxt lte6) ==> confirmed the fix for LTE LEDs.
Rb5009 used as CAPSman with multiple vlan and dual WAN configuration and Cap and hAP used as AP only.
I share the concern that for devices with 16MB memory the space is becoming a trouble considering that 7.14 takes more space that 7.13.x.
In my case is not about other packages because 16MB units are used only as AP so with very basic configuration, but still not ideal if not addressed.
I’m confident that the Mikrotik team will keep it under control, but I think that sharing a concern here is somehow right.
infabo
Long time Member
Long time Member
Fri Mar 08, 2024 12:21 am
Yeah, they keep an eye. About 600kb free on 7.13.5, ~260kb avail on 7.14 and ~60kb on 7.15beta4. See the direction it is going?
Dario1982
Fri Mar 08, 2024 12:34 am
Exactly why I said that expressing the concern is due from the customers.
dbmillar
Trainer
Trainer
Fri Mar 08, 2024 12:51 am
Ahhh i've just had the same thing happen :/
baragoon
Fri Mar 08, 2024 7:52 am
Well, the first victim RB750Gr3 runs fine with 7.14 around a week, but after today's planned reboot didn't comes up... at remote site without people
Smoerrebroed
Fri Mar 08, 2024 1:43 pm
For a few days, I've been noticing freezes/crashes on one of my cAP ax. Not sure what's going on there. Log on CAPsMAN only says "disconnected abc@aa:bb:cc:dd:ee:ff, connection interrupted". Powercycling brings the device back for a couple more hours. This certainly didn't happen on 7.13.5. Any ideas?
ColinSlater
Fri Mar 08, 2024 2:19 pm
Have upgraded my hAP ax2 (running as CAP, controlled via CAPsMAN from my RB4011) to 7.14 without any problems.
TOD
Fri Mar 08, 2024 4:05 pm
After upgrade CHR from 6.49.10 to 7.14.0 router unexpectedly rebooted on the end of the day.
CHR in VMware Cloud virtualization (ESXi 7.0 U2 / 7.0.2).
There were no crashes prior to this incident (in about 3 years of operation on 6.48.x - 6.49.x).
// SUP-146320
diamuxin
Fri Mar 08, 2024 5:19 pm
SOLVED in 7.15beta6
*) wireguard - do not attempt to connect to peer without specified endpoint-address
Several users have already reported that this situation was abnormal. Thanks MikroTik.
BR.
sirbryan
Fri Mar 08, 2024 5:35 pm
On my CRS354 I went from the ancient, pre-March 2024 release of 7.13.5 all the way up to 7.14 and saw the same thing on a bunch of ports that have otherwise been working fine for months.
infabo
Long time Member
Long time Member
Fri Mar 08, 2024 6:08 pm
Yes, I switched to "testing" branch first time in years. 7.13 was already tough to swallow and then 7.14. Now I go YOLO as testing branch has the fixes first. LOL
Znevna
Fri Mar 08, 2024 6:27 pm
Every channel feels like YOLO with MikroTik, that's why it's so exciting to manage MikroTik devices.
pe1chl
Fri Mar 08, 2024 6:42 pm
Well, I bought a couple of RB5009UPr+S+IN this week and they came with 7.8 and did not issue this message.
When I upgraded them to 7.12.1 (my "recommended version" for now) they did.
So at least for that model the message was added between those versions. Probably the status was always there, it just wasn't reported.
t0mm13b
Fri Mar 08, 2024 8:41 pm
cries into his 16Mb flash
:D
t0mm13b
Fri Mar 08, 2024 9:23 pm
*) package - reduced "wireless" package size for ARM, ARM64, MIPSBE, MMIPS devices;
FYI - rebooted device, system refused to come back online as there was 0 bytes.
Ran a netinstall which cleared out the space by reformatting flash drive.
This is result
Can someone please confirm my suspicion that when a device gets power cut off (intentionally or unintentionally) that it dumps some temporary file somewhere and does not get cleaned up.
More likely core dump which was what killed the storage space?
elvtechnology
Fri Mar 08, 2024 10:15 pm
In addition to the logs issue, one of a few WG peers lost its public key. The one I found when I started to investigate the loss of connection was not the same one I put there about a week ago.
I had the same issue. The public key got changed after upgrading to 7.14 and I lost remote access.
elvtechnology
Fri Mar 08, 2024 10:46 pm
I've used a Mikrotik LTE device to provide OOB management for remote sites. You can even Netinstall this way provided you have prepared this in advance and have a way to power cycle the device which can also be done remotely with the right hardware.
So while it might not be ideal, there are ways to workaround this, and it has a number of other advantages.
drdre
Fri Mar 08, 2024 11:26 pm
Have an RB750UP and experienced the same issue. IP stack appears to have some sort of regression, although unable to determine root cause. I was able to connect to router via winbox, but not much else was working (dhcp client or server not giving or receiving IP address).
Downgrade to 7.13.5 fixed the issue.
elvtechnology
Fri Mar 08, 2024 11:29 pm
Can you check the log for the remote device?
elvtechnology
Fri Mar 08, 2024 11:35 pm
Disabling logging isn't actually the responsible action here, as you can miss important entries, but there might not be a better interim solution. But in any case it should be temporary.
elvtechnology
Fri Mar 08, 2024 11:37 pm
Yet it is something that Mikrotik *have* fixed in an upcoming BETA. 🤷‍♂️
No need to be so passive agressive. You're just making a fool of yourself and causing trouble.
Znevna
Fri Mar 08, 2024 11:49 pm
Oh wow, I'm ashamed because I was wrong on the internet.
rofl.
I don't know what the behaviour is on other wireguard clients under that scenario, maybe it is something MikroTik broke or maybe they used ancient sources and it was something that got fixed in more recent wireguard sources, who knows.
Those logs belong to 'debug' and not 'info' anyway, and that's on MikroTik.
If me looking as a fool is causing you trouble, you can skip my comments, or even put me on ignore I think. Cheers.
jsadler
Sat Mar 09, 2024 6:19 am
Has anyone had any issues with BFD running on VLAN interfaces since 7.14? - I've noticed an issue but I'm yet to further test / troubleshoot.
t0mm13b
Sat Mar 09, 2024 10:27 am
Regarding previous reply above,
Free space on device is now reported as decreased
I am not fully aware of the innards of router os - LInux 5.6.3 though - that's approx 4years old though.
Is there some swapping going on? temporary files created?
In space of 13 hours approx, it went from 212Kb to 156Kb - all functionality loaded into RAM right?
Leaving it as open ended question - where did it go?
mkx
Sat Mar 09, 2024 10:59 am
Do you have graphing enabled? It may consume some permanent storage space and starts from 0 after netinstall (upgrade doesn't wipe it though).
Do you have any address lists being built up? If entries don't have timeout set, they are considered permanent and thus stored in permanent configuration database (increasing storage requirements).
I'm pretty sure there are other activities which (initially? during first few days of operation?) use up additiobal flash space.
catengineer
Sat Mar 09, 2024 1:31 pm
I regularly upgrade my devices, and this has been happening since the second last release. No big upgrade jump.
t0mm13b
Sat Mar 09, 2024 1:43 pm
No graphing enabled.
Address lists - definitely - good call out, Thanks for reminding me, have some others that are on timeouts too.
Thanks for the tip.
artemlight
Sat Mar 09, 2024 2:09 pm
Yet another bricked hAP ac2 at the remote location while upgrading from 7.13.4
No containers, old wifi package 'wireless'.
Had to flash remotely, giving instructions to parents over the phone. But finally it works.
I want to point out that after the failed update Mikrotik went into netboot mode on its own, and I didn't have to explain to my mom how long she need to hold down the Reset button =)
Maybe it makes sense to implement emergency firmware download from usb flash. In any case it is more realistic than development of OOB - and will be sufficient in most cases.
And if it's only about the amount of free flash - I think it's enough just to check it before performing an upgrade. Any pre-installation failure looks better than the router being bricked.
Santi70
Sat Mar 09, 2024 5:53 pm
Upgraded Chateau LTE12 to v7.14, bit shocked to see the storage size plummet from 420k approx to this.
wifi-qcom-ac and routeros?
Irony was lost when I migrated from wireless package to this wifi-qcom-ac
This is result
Keeping track of storage since I updated it and it has not changed, I have the graphics active but in memory
holvoetn
Sat Mar 09, 2024 6:12 pm
No cleanup due to power cut: that's possible.
But dumping a file AFTER a power cut ? That would be ... magic!
infabo
Long time Member
Long time Member
Sat Mar 09, 2024 6:14 pm
Yet another bricked hAP ac2 at the remote location while upgrading from 7.13.4.
It seems like MikroTik is aiming to enter the brick industry. They have been increasingly producing more bricks lately.
k2dI5umrD9VO
Sat Mar 09, 2024 8:50 pm
I have a total of ten devices I manage (mixed) with some examples being a CCR, CRS, hAP ac and ax models, a single Audience. All of these devices with the exception of the CCR and CRS are very simple configurations (no QoS, no VLANs, etc.) All of the devices are configured to auto-update by checking weekly for new ROS releases in the stable branch.
Everything has successfully updated to v7.14 except for the hAP ac2 and lower models. I had one hAP ac2 brick itself after the upgrade and resetting it didn't bring it back to life. Fortunately I had a hAP ax3 on-hand spare to swap it with. The other hAP ac2 and lower models I'm managing I've had to pause auto-updates on (and just in time.) Bottom-line in my opinion, the ac2 and lower models will never be upgraded again and I'm considering them EOL after 7.13.x.
The way I see it, the hAP ac2 and lower models have what, 16MB of memory? And we're now on ROS releases that are only going to grow in overall size since we now have ROS and QCOM Wi-Fi packages to contend with. On mine, I now have ROS, QCOM and ZeroTier packages needing to be installed/upgraded.
Users browsing this forum: bbd and 10 guests
