Hello everyone.
I'm planning on placing a CRS317 on the WAN side of things so that I can distribute the incoming connection to several routers. We have 16 static ips and plan on assigning some to a CCR2004 and a few to a couple CHRs. I've never put a switch on the WAN side and want to make sure I set it up securely. Naturally it will also need to be connected to the LAN side so that we can manage it, so I need to make sure the management isn't available on the WAN connections. Currently on the LAN side all management is available on VLAN 200. It would be nice to have the WAN switch management connected to that as well and only available on one port. This would be a trivial setup for me on an actual router, but I need some handholding since it's a switch. Any pointers? Thanks
