Drone
DHCP conflict
Mon Mar 04, 2024 11:03 am
Hello! Ive got lame question but cant find answer by myself.
What we got rb2011uas at 6.49.13. DHCP server with single pull 192.168.1.2-192.168.1.200. Some clients get addreses in ip-pool-used adreses even if its client offline and these addresses cause a dhcp server conflict. All leases are Dynamic. How can i cleare this table or ?Also is it possible to combine DHCP with few static IPs or they must be excluded manualy from pool.
erlinden
Re: DHCP conflict
Mon Mar 04, 2024 9:30 pm
Would need to see the config:
/export hide-sensitive file=anynameyoulike
Remove serial and any other private info en post in between code tags by using the </> button.
IP reservations should not be part of the DHCP scope.
JazzMaster
Re: DHCP conflict
Tue Mar 05, 2024 12:01 am
It should be easy to unscramble but we do need to see your config.
Drone
Re: DHCP conflict
Wed Mar 13, 2024 10:44 am
Thank you for your response!
Users browsing this forum: filou59, gabeluci, Google [Bot] and 21 guests
