Mon Mar 04, 2024 3:34 pm
To be fair, judging from the frequency with which the issue is posted on the forum, it is not very clear.
Particularly for an AP, it can be confusing.
In a home setup, if there is a ISP modem, it has typically 4 LAN ports.
So, in the simplest possible setup, you have your desktop/or laptop connected to one of these LAN ports, and your AP would go to one of the other three ports, that would be understood as "ISP ethernet cable" and thus put into ether1 of the AP.
Then, since the 4 LAN ports of the ISP modem/router are in a bridge, the user will attempt connecting to the Mikrotik.
I don't think it would cost that much to Mikrotik to add a sentence *like*:
WARNING: Default factory setup sets ether1 as a WAN port and for security reasons access to the device settings from that port is prevented. Only use Winbox or browser when connected to any of the other ports (ether2-ethern), the device address on these other ports (NOT ether1) is 192.168.88.1 and a DHCP server is enabled leasing addresses in the 192.168.88.0/24 subnet.
jaclaz on Mon Mar 04, 2024 3:45 pm, edited 1 time in total.
