hadjieff508
Router OS v7 Dual WAN
Tue Mar 05, 2024 10:43 am
Hi.
Dual wan, not failower, Not load balance.
When disable this nat
Loss internet connection in this 10.10.9.0/24, 10.10.12.0/23
# RouterOS 7.13.4
# model = CCR2116-12G-4S+
set [ find default-name=ether1 ] comment=ISP-1
set [ find default-name=ether2 ] comment=ISP-2
set [ find default-name=ether4 ] comment=TR-2
set [ find default-name=ether5 ] comment=TR-3
set [ find default-name=ether11 ] comment="Old Network"
/interface vlan
add interface=ether4 name="LAN - Network" vlan-id=101
add interface=ether5 name="Mobile - Network" vlan-id=103
add interface=ether5 name="WLAN - Network" vlan-id=102
add name=LAN-Pool ranges=10.10.12.100-10.10.13.254
add name=WLan-Pool ranges=10.10.9.2-10.10.9.254
add name=Mobile-Pool ranges=10.0.0.2-10.0.1.254
add address-pool=LAN-Pool interface="LAN - Network" lease-time=8h name=LAN-DHCP relay=10.10.12.1
add address-pool=WLan-Pool interface="WLAN - Network" lease-time=8h name=WLAN-DHCP
add address-pool=Mobile-Pool interface="Mobile - Network" lease-time=8h name=Mobile-DHCP
/routing table
add disabled=no fib name=ISP-2
add disabled=no fib name=ISP-1
add address=10.0.0.1/23 interface="Mobile - Network" network=10.0.0.0
add address=10.10.9.1/24 interface="WLAN - Network" network=10.10.9.0
add address=ISP-2-ip interface=ether2 network=ISP-2-ip
add address=ISP-1-ip interface=ether1 network=ISP-1-ip
add address=192.168.0.254/16 interface=ether11 network=192.168.0.0
add address=172.16.10.1/30 interface="LAN - Network" network=172.16.10.0
add address=10.0.0.0/23 dns-server=8.8.8.8,8.8.4.4 gateway=10.0.0.1
add address=10.10.9.0/24 dns-server=192.168.1.105,192.168.1.101,192.168.1.102 gateway=10.10.9.1
add address=10.10.12.0/23 dns-server=192.168.1.105,192.168.1.101,192.168.1.102 gateway=10.10.12.1
set servers=8.8.8.8,8.8.4.4
add action=dst-nat chain=dstnat comment=Exchange dst-address=ISP-2-ip dst-port=443 protocol=tcp to-addresses=192.168.1.44 to-ports=443
add action=dst-nat chain=dstnat comment=KSMG dst-address=ISP-2-ip dst-port=25 protocol=tcp to-addresses=192.168.1.53 to-ports=25
add action=masquerade chain=srcnat out-interface=ether2 src-address=192.168.0.0/16
add action=masquerade chain=srcnat out-interface=ether1 src-address=192.168.0.0/16
add action=masquerade chain=srcnat out-interface=ether2 src-address=10.10.9.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=10.10.9.0/24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ISP-2-ip pref-src="" routing-table=ISP-2 scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ISP-1-ip pref-src="" routing-table=ISP-1 scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ISP-2-ip pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/routing rule
add action=lookup disabled=no dst-address=10.10.12.0/23 table=main
add action=lookup disabled=no dst-address=10.10.9.0/24 table=main
add action=lookup disabled=no dst-address=192.168.0.0/16 table=main
add action=lookup disabled=no src-address=192.168.1.160/32 table=ISP-1
add action=lookup disabled=no src-address=10.10.12.0/23 table=ISP-1
add action=lookup disabled=no src-address=10.10.9.0/24 table=ISP-1
add action=lookup disabled=no src-address=10.0.0.0/23 table=ISP-1
anav
Re: Router OS v7 Dual WAN
Wed Mar 06, 2024 1:12 am
Just need two rules for sourcenat.
Sourcenat is not a firewall function or a routing function!!!
alternatively you could
Where both active WAN interfaces are part of the WAN interface list membership./
You also seem to be missing the IP route for ISP1, main table.
Where the heck is subnet 192.168.1.0 coming from ??
if you didnt want failover or pcc, then what is it that you wanted?
It seems looking at routing rules you have some UNSTATED requirements.
which makes your config incomplete to be honest.
hadjieff508
Mon Mar 11, 2024 8:12 am
Temporary Kerio Control.
Users browsing this forum: Ahrefs [Bot] and 11 guests
