Hi, I've an important task, the LAN network /24 is splitted in two parts, the first 127 addresses using the devault gateway with main routing table, the second half of the subnet should use another gateway, this i ssimple to obtain, I mangle the 192.168.0.128/25 addresses to use another routing table which I created.
Now the problem is that this second gateway is givng me an internal IP which may change in future, and by DHCP client I can't define the routing table it has to be assigned, where I can mangle the traffic. To solve the problem I had to create a static default route to the gateway which actually I see on the DHCP client datas, works, but how can I created it automatic if the gateway address change?
In the picture I show the differences between a dynamic route entry and a static one, it's the same also for 0.0.0.0/0 route. I can't uplead that scren because I'm afraid to activate it, I can loose the router remotely, I think you understood already
