ericdriver
BGP VRF route leak
Wed Mar 06, 2024 11:52 am
I have route to 10.150.45.0/24(getting from BGP) in vrf vrfTest1.
I was able to leak this route into vrf vrfTest2.
However "Immediate Gateway" for this route in vrf vrfTest2 is unknown, the host in 10.150.45.0/24 is not reacheble.
When I create static route to 10.150.45.0/24 everythink works.
RouterOS v7.14, 7.15beta no changes
What is wrong?
nichky
Re: BGP VRF route leak
Wed Mar 06, 2024 12:15 pm
without adding a static route, can u ping the other end?
ericdriver
Wed Mar 06, 2024 12:27 pm
no, as I already mentioned "the host in 10.150.45.0/24 is not reacheble." Static route works, BGP route doesn't work
ericdriver
Wed Mar 06, 2024 1:54 pm
Just trying to change BGP to OSPF, everything works fine, it seems it is BUG
mrz
Wed Mar 06, 2024 3:41 pm
I would say that it is misconfiguration. VPNv4 requires at least LDP, otherwiseVPNv4 MPLS label cannot be resolved.
ericdriver
Thu Mar 07, 2024 6:49 am
I just need dynamic VRF-lite route leaking on the local router https://help.mikrotik.com/docs/pages/vi ... uteleaking
Is it working with BGP routes?
nichky
Thu Mar 07, 2024 7:26 am
VPNv4 works perfectly fine on v7
Users browsing this forum: ipv6muppet and 1 guest
