i'm facing a very strange issue here. i do have a wifi network managed by capman and 3 wap ac in cap mode.
all is working good from any devices except apple ones.
When it comes to connect an iphone, its not recognizing the PSK, even if i'm sure its correct.
A workaround is scanning the network QRCODE generated on another device, that trik will make the iphone connecting to the network.
anyway, the trick is one shot. if that iphone device leave the netork, and come back in the range lets say 24h later it will need to scan the qr again to reconnect to the network.
is it anyone facing similar issues? here my capsman conf
Code: Select all
[admin@RouterOS] > /interface/wifi/capsman/ print
enabled: yes
interfaces: bridge-wifi-tunnel
ca-certificate: auto
require-peer-certificate: no
package-path:
upgrade-policy: suggest-same-version
generated-ca-certificate: WiFi-CAPsMAN-CA-789A180E26B0
generated-certificate: WiFi-CAPsMAN-789A180E26B0
[admin@RouterOS] > /interface/wifi/configuration/ print
Flags: X - disabled
0 name="cfg-wifi2-2GHZ" ssid="Mao-Fi" country=Italy multicast-enhance=enabled security=sec1
security.connect-priority=0
interworking=interworking1 datapath=datapath-wifi2-tunnel channel=2_Ghz steering=steering1
1 name="cfg-wifi2-5GHZ" ssid="Mao-Fi" country=Italy multicast-enhance=enabled security=sec1
interworking=interworking1 datapath=datapath-wifi2-tunnel channel=5_Ghz_AC steering=steering1
[admin@RouterOS] > /interface/wifi/security/ print
Flags: X - disabled
0 name="sec1" authentication-types=wpa2-psk,wpa3-psk passphrase="***" connect-priority=0
[admin@RouterOS] > /interface/wifi/interworking/ print
Flags: X - disabled
0 name="interworking1" network-type=private internet=yes venue=residential-private ipv4-availability=single-nated ipv6-availability=not-available domain-names=mao.onl wan-status=up
[admin@RouterOS] > /interface/wifi/datapath/print
Columns: NAME, BRIDGE
# NAME BRIDGE
0 datapath-wifi2-tunnel bridge-wifi-tunnel
[admin@RouterOS] > /interface/wifi/channel/ print
Flags: X - disabled
0 name="5_Ghz_AC" band=5ghz-ac
1 name="2_Ghz" band=2ghz-n
[admin@RouterOS] > /interface/wifi/steering/ print
Flags: X - disabled
0 name="steering1" neighbor-group=dynamic-Mao-Fi-538252a9 rrm=yes wnm=yes
[admin@RouterOS] > /system/
backup console device-mode history leds logging ntp resource rtrace script watchdog export reset-configuration shutdown ssh-exec telnet
clock default-configuration health identity license note package routerboard scheduler upgrade check-installation reboot serial-terminal ssh sup-output
[admin@RouterOS] > /system/package/ print
Columns: NAME, VERSION, BUILD-TIME, SIZE
# NAME VERSION BUILD-TIME SIZE
0 routeros 7.14 2024-02-29 11:44:44 9.3MiB
admin@RouterOS] > /interface/wifi/actual-configuration/ print
0 name="cap-wifi1" mac-address=18:FD:74:D2:45:7E arp-timeout=auto radio-mac=18:FD:74:D2:45:7E
configuration.ssid="Mao-Fi" .country=Italy .multicast-enhance=enabled
security.authentication-types=wpa2-psk,wpa3-psk .passphrase="***" .connect-priority=0
interworking.network-type=private .internet=yes .venue=residential-private .ipv4-availability=single-nated .ipv6-availability=not-available .domain-names=mao.onl .wan-status=up
datapath.bridge=bridge-wifi-tunnel
channel.band=2ghz-n
steering.neighbor-group=dynamic-Mao-Fi-538252a9 .rrm=yes .wnm=yes
1 name="cap-wifi2" mac-address=18:FD:74:D2:45:7F arp-timeout=auto radio-mac=18:FD:74:D2:45:7F
channel.band=5ghz-ac
2 name="cap-wifi3" mac-address=18:FD:74:D2:40:3D arp-timeout=auto radio-mac=18:FD:74:D2:40:3D
channel.band=2ghz-n
3 name="cap-wifi4" mac-address=18:FD:74:D2:40:3E arp-timeout=auto radio-mac=18:FD:74:D2:40:3E
4 name="cap-wifi5" mac-address=18:FD:74:D2:46:6B arp-timeout=auto radio-mac=18:FD:74:D2:46:6B
channel.band=2ghz-n
5 name="cap-wifi6" mac-address=18:FD:74:D2:46:6C arp-timeout=auto radio-mac=18:FD:74:D2:46:6C
[admin@RouterOS] >
