Here's the 6.49.10 config export from an SXTsq 5ac:
Code: Select all
# mar/10/2024 01:07:08 by RouterOS 6.49.10
# software id = XXX
# model = RBSXTsqG-5acD
# serial number = XXX
/interface mesh
add name=mesh1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-n/ac country="united states3" disabled=no frequency=5805 mode=wds-slave radio-name=sq1 skip-dfs-channels=all ssid=mesh wds-default-bridge=mesh1 wds-mode=dynamic-mesh
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/interface mesh port
add interface=wlan1 mesh=mesh1
add address=10.28.99.253/24 interface=mesh1 network=10.28.99.0
/system clock
set time-zone-name=America/New_York
/system identity
set name=sq1
/system routerboard settings
set cpu-frequency=auto
/tool romon
set enabled=yes
Here's a snippet of the log from 7.14, it disconnects every 60 seconds:
Code: Select all
11:32:44 wireless,info 2C:C8:1B:CF:01:D3@wlan1: connected, signal strength 3, is AP, wants WDS
11:32:44 system,info,account user admin logged out by romon E4:8D:8C:50:0A:5E via winbox
11:33:01 system,info,account user admin logged in by romon E4:8D:8C:50:0A:5E via winbox
11:33:03 system,info,account user admin logged in from 10.1.1.149 via local
11:33:44 wireless,info wlan1: 2C:C8:1B:CF:01:D3 is new WDS master
11:33:44 wireless,info 2C:C8:1B:CF:01:D3@wlan1: disconnected, no beacons received, signal strength 2
11:33:44 wireless,info wlan1 2C:C8:1B:CF:01:D3 was WDS master
11:33:47 system,info,account user admin logged out by romon E4:8D:8C:50:0A:5E via winbox
11:33:47 system,info,account user admin logged out from 10.1.1.149 via local
11:33:47 wireless,info 2C:C8:1B:CF:01:D3@wlan1: connected, signal strength 3, is AP, wants WDS
11:34:05 system,info,account user admin logged in by romon E4:8D:8C:50:0A:5E via winbox
11:34:06 system,info,account user admin logged in from 10.1.1.149 via local
11:34:47 wireless,info wlan1: 2C:C8:1B:CF:01:D3 is new WDS master
11:34:47 wireless,info 2C:C8:1B:CF:01:D3@wlan1: disconnected, no beacons received, signal strength 1
11:34:47 wireless,info wlan1 2C:C8:1B:CF:01:D3 was WDS master
11:34:50 wireless,info 00:0C:42:C3:60:C3@wlan1: connected, signal strength -35, is AP, wants WDS
11:34:50 wireless,info 2C:C8:1B:CF:01:D3@wlan1: connected, signal strength 3, is AP, wants WDS
11:34:51 system,info,account user admin logged out by romon E4:8D:8C:50:0A:5E via winbox
11:34:51 system,info,account user admin logged out from 10.1.1.149 via local
11:35:09 system,info,account user admin logged in by romon E4:8D:8C:50:0A:5E via winbox
11:35:10 system,info,account user admin logged in from 10.1.1.149 via local
Code: Select all
Just for clarity: I upgraded directly from 6.49.10 to 7.14 without changing anything from the configuration above. When I downgrade to 6.49.10 - again without changing anything, the mesh works fine.
