lukanite
DHCP inside VRF?
Mon Mar 11, 2024 12:17 pm
I'd like to set up a few VRFs, one per VLAN, with identical subnets. Each subnet is identical to accommodate devices that use a static IP, but should also let devices connect using DHCP.
It seems like I can do this in RouterOS 7.14 - I can go IP pool settings and create identical pools for each VLAN, then go to the DHCP server settings and create a server for each VLAN, each with their own IP pool (that are all the same IPs).
However, when I try to test it using a small number of IPs in each pool, the DHCP servers are not giving out the same IP address across the VRFs, and the pool is exhausted. I've tried turning off conflict detection and set Authoritative to no as well, to no avail.
Any suggestions?
Users browsing this forum: No registered users and 28 guests
