Hi Forum members,
I went through all messages regarding this topic and tried to remove all possible causes of the issue.
Basically, i'm getting entries in the logs each 30sec :
"login failure for user admin from MIKROTIK_IP_ROUTER_ADDRESS via winbox"
"login failure for user admin from ONE_LAYER_ABOVE_MIKROTIK_IP_ROUTER_ADDRESS via winbox". The router trying to connect is my local ISP router triple play router and there is no 8291 port redirection on it.
The Dude is not activated, I have removed ssh from the list of services and admin account is disabled.
I'm truly stuck...
Thanks for any help or advice.
Laurent
