I renamed to BBB DDD and so on the names and hostnames are random letters, and I removed all the keys from the wireguard peers
add fast-forward=no name=bridge165
add fast-forward=no name=bridgeBBB port-cost-mode=short
add fast-forward=no name=bridgeDDD port-cost-mode=short
add fast-forward=no name=bridgeDASH port-cost-mode=short
add fast-forward=no name=bridgeDB port-cost-mode=short
add fast-forward=no name=bridgeEEE port-cost-mode=short
add fast-forward=no name=bridgePPP port-cost-mode=short
add fast-forward=no name=bridgeKKK port-cost-mode=short
add fast-forward=no name=bridgeOSPF port-cost-mode=short protocol-mode=none
add fast-forward=no name=bridgeSupport port-cost-mode=short
add fast-forward=no name=bridgeTrunk port-cost-mode=short
set [ find default-name=ether8 ] comment="WAN LANCOM"
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no
/interface wireguard
add listen-port=13102 mtu=1420 name=wireguardBBB1
add listen-port=13103 mtu=1420 name=wireguardBBB2
add listen-port=13110 mtu=1420 name=wireguardBBBUsers
add listen-port=13123 mtu=1420 name=wireguardCCC
add listen-port=13124 mtu=1420 name=wireguardCCCUsers
add listen-port=13104 mtu=1420 name=wireguardDDD
add listen-port=13114 mtu=1420 name=wireguardDDDKallithea
add listen-port=13111 mtu=1420 name=wireguardEEE
add listen-port=13117 mtu=1420 name=wireguardEEESpiti
add listen-port=13118 mtu=1420 name=wireguardEEEUsers
add listen-port=13115 mtu=1420 name=wireguardFFF
add listen-port=13108 mtu=1420 name=wireguardGGG
add listen-port=13109 mtu=1420 name=wireguardGGGUsers
add listen-port=13101 mtu=1420 name=wireguardPPP
add listen-port=13113 mtu=1420 name=wireguardPPPUsers
add listen-port=13106 mtu=1420 name=wireguardKKK
add listen-port=13125 mtu=1420 name=wireguardKKKUsers
add listen-port=13116 mtu=1420 name=wireguardHHHHHHHpiti
add listen-port=13105 mtu=1420 name=wireguardOOO
add listen-port=13121 mtu=1420 name=wireguardPx1JJJ
add listen-port=13122 mtu=1420 name=wireguardRouterEEE
add listen-port=13120 mtu=1420 name=wireguardVh1JJJ
add listen-port=13119 mtu=1420 name=wireguardVh2JJJ
add listen-port=13107 mtu=1420 name=wireguardXXX
add listen-port=13112 mtu=1420 name=wireguardXXXUsers
/interface vlan
add interface=bridgeTrunk name=vlan165.0-2.5G vlan-id=1650
add interface=bridgeTrunk name=vlan165.5-DASH vlan-id=1655
add interface=bridgeTrunk name=vlan165.15-DB vlan-id=1215
add interface=bridgeTrunk name=vlan165.20-SUPPORT vlan-id=1220
add interface=bridgeTrunk name=vlan195.0-PPP vlan-id=1950
add interface=bridgeTrunk name=vlan195.1-KKK vlan-id=1951
add interface=bridgeTrunk name=vlan195.2-EEE vlan-id=1952
add interface=bridgeTrunk name=vlan205.0-BBB vlan-id=70
add interface=bridgeTrunk name=vlan210.1-DDD vlan-id=2101
add name=RomonExc
/ip vrf
add interfaces=wireguardDDD,wireguardDDDKallithea name=\
DDDVRF
add interfaces=wireguardFFF,wireguardHHHHHHHpiti name=\
FFFVRF
add interfaces=wireguardCCC,wireguardCCCUsers name=CCC
/interface sstp-client
add connect-to=mt1.PPP.gr name=mt1.PPP.gr port=4437 profile=\
default-encryption user=dcrouter01
/routing ospf instance
add disabled=no name=ospf-instance-BBB-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-PPP-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-OOO-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-KKK-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-XXX-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-GGG-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-EEE-1 router-id=127.165.0.1
add disabled=no name=ospf-instance-EEESpiti-1 router-id=127.165.0.1
/routing ospf area
add area-id=0.0.4.0 disabled=no instance=ospf-instance-BBB-1 name=\
ospf-area-BBB-1
add area-id=0.0.4.1 disabled=no instance=ospf-instance-BBB-1 name=\
ospf-area-BBB-2
add area-id=0.0.0.2 disabled=yes instance=ospf-instance-BBB-1 name=\
ospf-area-BBB-3
add area-id=0.0.2.0 disabled=no instance=ospf-instance-PPP-1 name=\
ospf-area-PPP-1
add area-id=0.0.3.0 disabled=no instance=ospf-instance-OOO-1 name=\
ospf-area-OOO-1
add area-id=0.0.5.0 disabled=no instance=ospf-instance-KKK-1 name=\
ospf-area-KKK-1
add area-id=0.0.6.0 disabled=no instance=ospf-instance-XXX-1 name=\
ospf-area-XXX-1
add area-id=0.0.7.0 disabled=no instance=ospf-instance-GGG-1 name=\
ospf-area-GGG-1
add area-id=0.0.8.0 disabled=no instance=ospf-instance-EEE-1 name=\
ospf-area-EEE-1
/system logging action
set 3 bsd-syslog=yes remote=10.165.20.15
add bridge=bridgeDASH interface=vlan165.5-DASH internal-path-cost=10 \
path-cost=10
add bridge=bridgeTrunk interface=ether1 internal-path-cost=10 path-cost=10
add bridge=bridgeDB interface=vlan165.15-DB internal-path-cost=10 path-cost=\
10
add bridge=bridgeSupport interface=vlan165.20-SUPPORT internal-path-cost=10 \
path-cost=10
add bridge=bridgeBBB interface=vlan205.0-BBB internal-path-cost=10 \
path-cost=10
add bridge=bridgeDDD interface=vlan210.1-DDD internal-path-cost=\
10 path-cost=10
add bridge=bridgePPP interface=vlan195.0-PPP \
add bridge=bridgeKKK interface=vlan195.1-KKK internal-path-cost=10 \
path-cost=10
add bridge=bridgeEEE interface=vlan195.2-EEE internal-path-cost=10 \
path-cost=10
add bridge=bridgeTrunk interface=sfp-sfpplus1 internal-path-cost=10 \
path-cost=10
add bridge=bridgeTrunk interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridgeTrunk interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridgeTrunk interface=ether5
add bridge=bridge165 interface=vlan165.0-2.5G
set udp-timeout=10s
set discover-interface-list=!RomonExc
add interface=ether8 list=RomonExc
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-address=10.170.0.2/32,192.168.80.0/24 \
client-listen-port=13101 endpoint-address=pc.PPP.gr endpoint-port=\
13101 interface=wireguardPPP persistent-keepalive=25s
add allowed-address=10.170.0.3/32 client-address=10.170.0.3/32 \
client-listen-port=13101 comment="p2p torhout" endpoint-port=13101 \
add allowed-address=0.0.0.0/0 endpoint-port=13102 interface=wireguardBBB1
add allowed-address=0.0.0.0/0 endpoint-port=13103 interface=wireguardBBB2
add allowed-address=10.175.2.2/30,10.210.0.10/32 client-address=10.175.2.2/30 \
client-endpoint=dcrouter01.PPP.gr client-keepalive=25s \
client-listen-port=13104 comment=DDD1 endpoint-port=13104 \
interface=wireguardDDD
add allowed-address=10.175.2.4/30,10.210.0.10/32 client-address=10.175.2.6/30 \
client-listen-port=13104 comment=DDD2 endpoint-port=13104 \
add allowed-address=10.175.2.10/30,10.210.0.10/32 client-address=\
10.175.2.10/30 client-endpoint=dcrouter01.PPP.gr client-keepalive=\
25s client-listen-port=13104 comment=DDD3 endpoint-port=13104 \
add allowed-address=0.0.0.0/0 client-address=10.175.2.14/30 client-endpoint=\
dcrouter01.PPP.gr client-keepalive=25s client-listen-port=13104 \
comment="DDD ergostasio" endpoint-port=13104 interface=\
wireguardDDD
add allowed-address=0.0.0.0/0 endpoint-port=13105 interface=\
wireguardOOO
add allowed-address=0.0.0.0/0 endpoint-port=13106 interface=wireguardKKK \
add allowed-address=0.0.0.0/0 endpoint-port=13107 interface=wireguardXXX \
add allowed-address=\
10.175.4.8/30,192.168.21.0/24,192.168.250.0/24,224.0.0.5/32 \
endpoint-port=13108 interface=wireguardGGG persistent-keepalive=25s
add allowed-address=10.175.4.12/30 client-address=10.175.4.14/30 \
client-listen-port=13109 comment=xarris endpoint-port=13109 interface=\
wireguardGGGUsers persistent-keepalive=25s
add allowed-address=10.175.4.16/30 client-endpoint=dcrouter01.PPP.gr \
client-keepalive=25s client-listen-port=13110 comment=\
"laptop" endpoint-port=13110 interface=wireguardBBBUsers
add allowed-address=0.0.0.0/0 endpoint-port=13111 interface=wireguardEEE \
add allowed-address=10.175.4.24/30 client-address=10.175.4.26/30 \
client-listen-port=13109 comment="xarris laptop" endpoint-port=13109 \
interface=wireguardGGGUsers
add allowed-address=10.175.4.28/30,192.168.43.0/24 endpoint-port=13112 \
interface=wireguardXXXUsers persistent-keepalive=25s
add allowed-address=10.175.4.32/30 client-address=10.175.4.34/30 \
client-listen-port=13109 comment="xarris tablet" endpoint-port=13109 \
add allowed-address=10.175.4.36/30 client-address=\
10.175.4.38/30,192.168.80.0/24,192.168.123.0/24 client-endpoint=\
dcrouter01.PPP.gr client-keepalive=25s client-listen-port=13113 \
comment=bbbbbbbbb endpoint-port=13113 interface=wireguardPPPUsers
add allowed-address=10.175.4.40/30 client-address=\
10.175.4.42/30,192.168.21.0/24,192.168.30.0/24 client-endpoint=\
dcrouter01.PPP.gr client-keepalive=25s client-listen-port=13109 \
comment="GGG mike laptop" endpoint-port=13109 interface=\
wireguardGGGUsers
add allowed-address=0.0.0.0/0 client-address=10.175.4.46/30 client-endpoint=\
dcrouter01.PPP.gr client-keepalive=25s client-listen-port=13114 \
comment="DDD ergostasio" endpoint-port=13114 interface=\
add allowed-address=0.0.0.0/0 comment="VVVVVVV thodora" endpoint-port=13115 \
interface=wireguardFFF persistent-keepalive=25s
add allowed-address=0.0.0.0/0 comment="HHHHHHH spiti" endpoint-port=13116 \
interface=wireguardHHHHHHHpiti persistent-keepalive=25s
add allowed-address=0.0.0.0/0 comment="HHHHHHH spiti" endpoint-port=13117 \
interface=wireguardEEESpiti persistent-keepalive=25s
add allowed-address=10.175.4.60/30 client-address=10.175.4.62/30 \
client-listen-port=13118 endpoint-port=13118 interface=\
wireguardEEEUsers
add allowed-address=0.0.0.0/0 endpoint-address=vh2mt.JJJ.com \
endpoint-port=13119 interface=wireguardVh2JJJ persistent-keepalive=\
25s
add allowed-address=0.0.0.0/0 endpoint-address=vh1mt.JJJ.com \
endpoint-port=13120 interface=wireguardVh1JJJ persistent-keepalive=\
25s
add allowed-address=0.0.0.0/0 endpoint-address=px1.JJJ.com endpoint-port=\
13121 interface=wireguardPx1JJJ persistent-keepalive=25s
add allowed-address=0.0.0.0/0 endpoint-address=router.EEE.com.gr \
endpoint-port=13122 interface=wireguardRouterEEE persistent-keepalive=\
25s
add allowed-address=0.0.0.0/0 endpoint-port=13123 interface=\
wireguardCCC persistent-keepalive=25s
add allowed-address=10.175.4.84/30 client-address=10.175.4.86/30 \
client-listen-port=13124 comment=maria endpoint-port=13124 interface=\
wireguardCCCUsers
add allowed-address=10.175.4.88/30 client-address=10.175.4.90/30 \
client-listen-port=13124 comment=tounda endpoint-port=13124 interface=\
wireguardCCCUsers
add allowed-address=10.175.4.92/30 client-address=10.175.4.94/30 \
client-listen-port=13125 comment="KKK spiti" endpoint-port=13125 \
interface=wireguardKKKUsers
add allowed-address=10.175.4.96/30 client-address=10.175.4.98/30 \
client-listen-port=13125 comment="KKK drapetsona" endpoint-port=\
13125 interface=wireguardKKKUsers
add address=10.160.0.10/24 disabled=yes interface=ether1 network=10.160.0.0
add address=10.165.0.1/24 interface=bridge165 network=10.165.0.0
add address=10.170.0.1/24 interface=wireguardPPP network=10.170.0.0
add address=10.165.5.1/24 interface=bridgeDASH network=10.165.5.0
add address=10.165.10.1/24 interface=bridgeDASH network=10.165.10.0
add address=10.165.15.1/24 interface=bridgeDB network=10.165.15.0
add address=10.165.20.1/24 interface=bridgeSupport network=10.165.20.0
add address=10.205.0.1/24 interface=bridgeBBB network=10.205.0.0
add address=10.175.0.1/24 interface=wireguardBBB1 network=10.175.0.0
add address=10.175.1.1/24 interface=wireguardBBB2 network=10.175.1.0
add address=127.165.0.1 interface=bridgeOSPF network=127.165.0.1
add address=185.70.76.135/24 disabled=yes interface=ether3 network=\
185.70.76.0
add address=10.210.0.1/24 interface=bridgeDDD network=10.210.0.0
add address=10.175.2.1/30 interface=wireguardDDD network=10.175.2.0
add address=10.175.2.5/30 interface=wireguardDDD network=10.175.2.4
add address=10.175.2.9/30 interface=wireguardDDD network=10.175.2.8
add address=10.175.2.13/30 interface=wireguardDDD network=10.175.2.12
add address=10.175.3.1/30 interface=wireguardOOO network=10.175.3.0
add address=10.195.0.1/24 interface=bridgePPP network=10.195.0.0
add address=10.195.1.1/24 interface=bridgeKKK network=10.195.1.0
add address=10.175.4.1/30 interface=wireguardKKK network=10.175.4.0
add address=10.175.4.5/30 interface=wireguardXXX network=10.175.4.4
add address=10.175.4.9/30 interface=wireguardGGG network=10.175.4.8
add address=10.175.4.13/30 interface=wireguardGGGUsers network=10.175.4.12
add address=10.175.4.17/30 interface=wireguardBBBUsers network=\
10.175.4.16
add address=10.195.2.1/24 interface=bridgeEEE network=10.195.2.0
add address=10.175.4.21/30 interface=wireguardEEE network=10.175.4.20
add address=10.175.4.25/30 interface=wireguardGGGUsers network=10.175.4.24
add address=10.175.4.29/30 interface=wireguardXXXUsers network=\
10.175.4.28
add address=10.175.4.33/30 interface=wireguardGGGUsers network=10.175.4.32
add address=10.175.4.37/30 interface=wireguardPPPUsers network=\
10.175.4.36
add address=10.175.4.41/30 interface=wireguardGGGUsers network=10.175.4.40
add address=10.175.4.45/30 interface=wireguardDDDKallithea network=\
10.175.4.44
add address=10.175.4.49/30 interface=wireguardFFF network=\
10.175.4.48
add address=10.175.4.53/30 interface=wireguardHHHHHHHpiti network=10.175.4.52
add address=10.175.4.57/30 interface=wireguardEEESpiti network=10.175.4.56
add address=10.175.4.61/30 interface=wireguardEEEUsers network=10.175.4.60
add address=10.175.4.65/30 interface=wireguardVh2JJJ network=10.175.4.64
add address=10.175.4.69/30 interface=wireguardVh1JJJ network=10.175.4.68
add address=10.175.4.73/30 interface=wireguardPx1JJJ network=10.175.4.72
add address=10.175.4.77/30 interface=wireguardRouterEEE network=10.175.4.76
add address=10.175.4.81/30 interface=wireguardCCC network=10.175.4.80
add address=10.175.4.85/30 interface=wireguardCCCUsers network=\
10.175.4.84
add address=10.175.4.89/30 interface=wireguardCCCUsers network=\
10.175.4.88
add address=10.175.4.93/30 interface=wireguardKKKUsers network=\
10.175.4.92
add address=10.175.4.97/30 interface=wireguardKKKUsers network=\
10.175.4.96
add address=185.70.76.105/24 interface=ether8 network=185.70.76.0
add address=10.160.0.1/24 interface=bridgeTrunk network=10.160.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=3m
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4,1.1.1.1
/ip firewall address-list
add address=pc.PPP.gr list=whitelist
add address=grafeio.EEE.com.gr list=whitelist
add address=mt1.PPP.gr comment=pc.PPP.gr list=whitelist
add address=aaaa.sn.mynetname.net comment=lte1 list=whitelist
add address=10.160.0.1 list=whitelist
add address=10.165.0.10 list=whitelist
add address=ims.otenet.gr list=ims.otenet.gr
add address=sip.supervoice.eu list=whitelist
add address=ssss.sn.mynetname.net comment=p2p list=unifiPPP
add address=fffff.sn.mynetname.net comment=p2p list=unifiPPP
add address=gggg.sn.mynetname.net comment="kliniki " list=\
unifiPPP
add address=hhhh.sn.mynetname.net comment="hasos" list=\
unifiPPP
add address=jjjj.sn.mynetname.net list=unifiPer
add address=192.168.80.0/24 list=customersSubnets
add address=192.168.123.0/24 list=customersSubnets
add address=kkkk.sn.mynetname.net comment=GGG5g list=whitelist
add address=llll.sn.mynetname.net comment="DDD ergostasio" \
list=whitelist
add address=192.168.3.0/24 list=customersSubnets
add address=10.195.2.0/24 disabled=yes list=customersSubnets
add address=dfgdfgdf.sn.mynetname.net comment=adamxl5g list=whitelist
add address=dsfgdsfgdsg.sn.mynetname.net comment=farmtheo5g list=whitelist
add address=dfghdfghdfgh.sn.mynetname.net comment=HHHHHHHspiti5g list=\
whitelist
add address=vh2mt.JJJ.com list=whitelist
add address=dfghdfghdfgh.sn.mynetname.net comment="EA VSV Router" list=\
whitelist
add action=fasttrack-connection chain=forward connection-state=\
established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=accept chain=input connection-nat-state="" connection-state="" \
in-interface=ether8 src-address-list=whitelist
add action=accept chain=input connection-nat-state="" connection-state=\
established,related in-interface=ether8
add action=accept chain=input connection-nat-state=dstnat connection-state="" \
in-interface=ether8
add action=accept chain=input comment=wireguard dst-port=\
13101-13125,23106,23112 in-interface=ether8 protocol=udp
add action=accept chain=input comment=pbs dst-port=8007 in-interface=ether8 \
protocol=tcp
add action=accept chain=input dst-port=\
80,8080,443,444,8089,8085,8086,8445,8446,3478 in-interface=ether8 \
protocol=tcp
add action=accept chain=input dst-port=8443 in-interface=ether8 protocol=tcp
add action=add-src-to-address-list address-list=blacklist25 \
address-list-timeout=5h chain=input dst-port=25 in-interface=ether8 log=\
yes log-prefix=blacklist25 protocol=tcp
add action=add-src-to-address-list address-list=blacklist \
address-list-timeout=5h chain=input disabled=yes dst-port=5514,21116 \
in-interface=ether1 log=yes log-prefix=blacklist protocol=udp
add action=drop chain=input in-interface=ether8 log=yes log-prefix=DROP
disabled=yes in-interface=ether3 src-address-list=whitelist
address-list-timeout=2h chain=input disabled=yes in-interface=ether3
add action=drop chain=input disabled=yes in-interface=ether3
add action=src-nat chain=srcnat out-interface=ether8 to-addresses=\
185.70.111.111
add action=masquerade chain=srcnat disabled=yes out-interface=ether8
add action=dst-nat chain=dstnat comment=dcHAP01 dst-port=\
80,443,8080,8443,8445,8089,8085,8086,8446 in-interface=ether8 protocol=\
tcp to-addresses=10.165.20.20
add action=dst-nat chain=dstnat comment=dcHAP01 dst-port=5514 in-interface=\
ether8 protocol=udp to-addresses=10.165.20.20
add action=dst-nat chain=dstnat comment=cloud.GGGbrewery.com dst-port=444 \
in-interface=ether8 protocol=tcp to-addresses=10.165.20.101
add action=dst-nat chain=dstnat dst-port=2055 in-interface=\
wireguardPPP protocol=udp to-addresses=10.165.20.25
add action=dst-nat chain=dstnat comment=dcpbs01 dst-port=8007 in-interface=\
ether8 protocol=tcp to-addresses=10.165.0.11
add action=dst-nat chain=dstnat comment="sstp dude" dst-port=4437 \
in-interface=ether8 protocol=tcp to-addresses=10.165.20.35
add action=dst-nat chain=dstnat comment="sstp dude" dst-port=500,4500,1701 \
in-interface=ether8 protocol=udp to-addresses=10.165.20.35
add action=masquerade chain=srcnat dst-address=176.12.105.210
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.178.1
add action=masquerade chain=srcnat dst-address=192.168.21.0/24 src-address=\
10.175.4.0/24
add action=masquerade chain=srcnat disabled=yes dst-address=192.168.8.0/24 \
src-address=10.175.4.28/30
add action=dst-nat chain=dstnat comment="p2p unifi udp" dst-port=\
3478,3475,3476 protocol=udp src-address-list=unifiPPP \
to-addresses=10.165.20.104
add action=dst-nat chain=dstnat comment="p2p unifi udp" dst-port=3476 \
protocol=udp src-address-list=unifiPer to-addresses=10.165.20.106
add action=dst-nat chain=dstnat comment=\
"gia tin xristina pou den pernage apo 13112" dst-port=23112 in-interface=\
ether8 protocol=udp to-ports=13112
"gia ton kafieri pou den pernage apo 13106" dst-port=23106 in-interface=\
ether8 protocol=udp to-ports=13106
add action=masquerade chain=srcnat comment="bazias to customers subnets" \
dst-address-list=customersSubnets src-address=10.175.4.38
add action=masquerade chain=srcnat comment="monedas to customers subnets" \
dst-address-list=customersSubnets src-address=10.175.4.62
/ip firewall raw
add action=drop chain=prerouting disabled=yes log-prefix=RawDrop \
src-address-list=blacklist
add action=drop chain=prerouting log-prefix=RawDrop src-address-list=\
blacklist25
add action=notrack chain=prerouting protocol=ospf
add action=notrack chain=output protocol=ospf
add action=drop chain=prerouting disabled=yes in-interface=ether3
add action=drop chain=output disabled=yes out-interface=ether3
/ip firewall service-port
set sip disabled=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=185.70.76.1 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address="" gateway=\
bridgeDDD@DDDVRF routing-table=DDDVRF scope=10 \
add disabled=yes distance=1 dst-address=10.210.0.0/24 gateway=\
bridgeDDD@DDDVRF pref-src="" routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.210.0.0/24 gateway=bridgeDDD \
pref-src="" routing-table=DDDVRF scope=10 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=\
10.175.2.14@DDDVRF pref-src="" routing-table=DDDVRF scope=10 \
add comment=xristina disabled=no distance=1 dst-address=192.168.43.0/24 \
gateway=10.175.4.30 pref-src="" routing-table=main scope=30 \
add disabled=no distance=1 dst-address=192.168.2.0/24 gateway=\
10.175.4.46@DDDVRF pref-src="" routing-table=DDDVRF scope=10 \
add disabled=no distance=1 dst-address=192.168.25.0/24 gateway=\
10.175.4.50%wireguardFFF pref-src="" routing-table=\
FFFVRF scope=30 suppress-hw-offload=no target-scope=10 \
vrf-interface=wireguardFFF
add disabled=no distance=1 dst-address=192.168.177.0/24 gateway=10.175.4.54 \
pref-src="" routing-table=FFFVRF scope=30 \
suppress-hw-offload=no target-scope=10 vrf-interface=wireguardHHHHHHHpiti
add check-gateway=ping disabled=no dst-address=10.100.0.0/16 gateway=\
10.175.4.74 routing-table=main suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address=172.28.0.0/22 \
gateway=10.175.4.78 pref-src=0.0.0.0 routing-table=main scope=30 \
10.175.4.82@CCC pref-src="" routing-table=CCC scope=30 \
suppress-hw-offload=no target-scope=10 vrf-interface=wireguardCCC
add disabled=no distance=1 dst-address=192.168.2.0/24 gateway=10.175.4.46 \
target-scope=10
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=10.175.2.14 \
target-scope=10
/ip service
set www disabled=yes
/ip traffic-flow
set active-flow-timeout=5m cache-entries=4M sampling-interval=1 \
sampling-space=1
/ip traffic-flow target
add dst-address=10.165.20.25 src-address=10.165.20.1
/routing ospf area range
add area=ospf-area-BBB-1 cost=200 disabled=yes prefix=192.168.78.0/24
/routing ospf interface-template
add area=ospf-area-PPP-1 disabled=no networks="127.165.0.1/32,10.170.0.\
0/24,10.160.0.0/24,10.165.0.0/24,10.165.5.0/24,10.165.10.0/24,10.165.15.0/\
24,10.165.20.0/24,10.195.0.0/24,10.195.1.0/24,10.205.0.0/24,10.210.0.0/24,\
10.175.4.64/32,10.195.2.0/24"
add area=ospf-area-OOO-1 disabled=no instance-id=1 networks=\
127.165.0.1/32,10.175.3.0/30,10.210.0.0/24,10.205.0.0/24
add area=ospf-area-BBB-1 disabled=no networks=\
127.165.0.1/32,10.175.0.0/24,10.205.0.0/24,10.165.0.11/24,10.165.20.40/24 \
priority=50
add area=ospf-area-BBB-2 disabled=no networks=\
127.165.0.1/32,10.175.1.0/24,10.205.0.0/24,10.165.0.11/24 priority=50
add area=ospf-area-KKK-1 disabled=no networks=\
127.165.0.1/32,10.175.4.0/30,10.195.1.0/24
add area=ospf-area-XXX-1 disabled=no networks=\
127.165.0.1/32,10.175.4.4/30,10.165.15.0/24,10.165.20.0/24,10.205.0.0/24
add area=ospf-area-GGG-1 disabled=no networks=\
127.165.0.1/32,10.175.4.8/30,10.175.4.12/30,192.168.80.0/24
add area=ospf-area-EEE-1 disabled=no networks="127.165.0.1/32,10.175.4.20/30\
,10.195.2.0/24,10.175.4.56/30,10.175.4.64/30,10.175.4.68/30,10.175.4.72/30\
,10.175.4.76/30,10.165.0.0/24"
/routing rule
add action=lookup disabled=no dst-address=10.175.2.0/24 table=DDDVRF
add action=lookup disabled=no dst-address=10.175.4.44/30 table=DDDVRF
add action=lookup-only-in-table disabled=yes dst-address=10.175.4.50/30 \
table=FFFVRF
add action=lookup-only-in-table disabled=yes dst-address=10.175.4.54/30 \
table=FFFVRF
add action=lookup-only-in-table disabled=no dst-address=192.168.1.0/24 \
src-address=10.210.0.10/32 table=DDDVRF
add action=lookup-only-in-table disabled=no dst-address=192.168.2.0/24 \
add action=lookup-only-in-table disabled=no dst-address=192.168.177.0/24 \
src-address=192.168.25.0/24 table=FFFVRF
add action=lookup-only-in-table disabled=no dst-address=192.168.25.1/24 \
src-address=192.168.177.0/24 table=FFFVRF
/snmp
set contact=aaaaaaa.PPP.gr enabled=yes location="Athens DC" \
trap-version=2
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Athens
/system identity
set name=aaaaaasffdf.PPP.gr
/system logging
add action=remote topics=critical
add action=remote topics=error
add action=remote topics=info
add action=remote topics=warning
add action=remote topics=health
add action=remote topics=wireguard
add disabled=yes topics=wireguard
/system note
set show-at-login=no
/system package update
set channel=testing
/tool romon
set enabled=yes
