Dan5r
7.13 Capsman with vlans on ax, ac devices – dhcp offered but not bound
Fri Mar 15, 2024 9:43 pm
Hi
I am using a hAP ax² to run capsman and some cap ac’s using vlans, the ssid is showing up but when connecting the issue is the dhcp server is not binding the ip address, the status remains “offered” under leases, any help will be greatly appreciated,
[admin@controller] > export
#  by RouterOS 7.14.1
# software id = xxxxx
# model = C52iG-5HaxD2HaxD
# serial number = xxxxxxxx
add name=bridge-local vlan-filtering=yes
/interface vlan
add interface=bridge-local name=vlan-10-vip vlan-id=10
add interface=bridge-local name=vlan-20-guest vlan-id=20
add interface=bridge-local name=vlan-33-mgmt vlan-id=33
/interface wifi channel
add band=2ghz-ax disabled=no name=ch-2-ax width=20mhz
add band=2ghz-n disabled=no name=ch-2-n width=20mhz
add band=5ghz-ax disabled=no name=ch-5-ax skip-dfs-channels=all width=20/40/80mhz
add band=5ghz-ac disabled=no name=ch-5-ac skip-dfs-channels=all width=20/40mhz
/interface wifi datapath
add disabled=no name=data-vip vlan-id=10
add client-isolation=yes disabled=no name=data-guest vlan-id=20
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=sec-vip
add authentication-types=wpa2-psk,wpa3-psk disabled=no ft=yes ft-over-ds=yes name=sec-guest
/interface wifi configuration
add channel=ch-2-ax country="United Kingdom" datapath=data-vip disabled=no mode=ap name=cfg-2-vip-ax security=sec-vip ssid=wifi6-vip
add channel=ch-2-n country="United Kingdom" datapath=data-vip disabled=no mode=ap name=cfg-2-vip-n security=sec-vip ssid=wifi6-vip
add channel=ch-5-ax country="United Kingdom" datapath=data-vip disabled=no mode=ap name=cfg-5-vip-ax security=sec-vip ssid=wifi6-vip
add channel=ch-5-ac country="United Kingdom" datapath=data-vip disabled=no mode=ap name=cfg-5-vip-ac security=sec-vip ssid=wifi6-vip
add channel=ch-2-ax country="United Kingdom" datapath=data-guest disabled=no mode=ap name=cfg-2-guest-ax security=sec-guest ssid=wifi6-guest
add channel=ch-2-n country="United Kingdom" datapath=data-guest disabled=no mode=ap name=cfg-2-guest-n security=sec-guest ssid=wifi6-guest
add channel=ch-5-ax country="United Kingdom" datapath=data-guest disabled=no mode=ap name=cfg-5-guest-ax security=sec-guest ssid=wifi6-guest
add channel=ch-5-ac country="United Kingdom" datapath=data-guest disabled=no mode=ap name=cfg-5-guest-ac security=sec-guest ssid=wifi6-guest
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg-5-vip-ax configuration.country="United Kingdom" .manager=local .mode=ap disabled=no
set [ find default-name=wifi2 ] configuration=cfg-2-vip-ax configuration.manager=local .mode=ap disabled=no
add configuration=cfg-5-guest-ax configuration.mode=ap disabled=no mac-address=xA:A9:8A:xx:20:xx master-interface=wifi1 name=wifi3
add configuration=cfg-2-guest-ax configuration.mode=ap disabled=no mac-address=xA:A9:8A:xx:20:xx master-interface=wifi2 name=wifi4
add name=dhcp_pool0 ranges=10.55.55.2-10.55.55.254
add name=dhcp_pool1 ranges=172.16.10.2-172.16.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool3 ranges=10.33.33.2-10.33.33.30
add name=dhcp_pool4 ranges=192.168.50.2-192.168.50.254
add name=dhcp_pool5 ranges=172.16.10.2-172.16.10.254
add name=dhcp_pool6 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool7 ranges=10.33.33.2-10.33.33.30
add address-pool=dhcp_pool4 interface=bridge-local name=dhcp-bridge-local
add address-pool=dhcp_pool5 interface=vlan-10-vip name=dhcp-vlan-10
add address-pool=dhcp_pool6 interface=vlan-20-guest name=dhcp-vlan-20
add address-pool=dhcp_pool7 interface=vlan-33-mgmt name=dhcp-vlan-30
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=wifi1 pvid=10
add bridge=bridge-local interface=wifi2 pvid=10
add bridge=bridge-local interface=wifi3 pvid=20
add bridge=bridge-local interface=wifi4 pvid=20
set udp-timeout=10s
/interface bridge vlan
add bridge=bridge-local tagged=bridge-local,ether2,ether3 vlan-ids=10
add bridge=bridge-local tagged=bridge-local,ether2,ether3 vlan-ids=20
add bridge=bridge-local tagged=bridge-local,ether2,ether3 vlan-ids=33
/interface wifi capsman
set enabled=yes interfaces=vlan-33-mgmt package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=none disabled=no
add address=172.16.10.1/24 interface=vlan-10-vip network=172.16.10.0
add address=192.168.20.1/24 interface=vlan-20-guest network=192.168.20.0
add address=10.33.33.1/27 interface=vlan-33-mgmt network=10.33.33.0
add address=192.168.50.1/24 interface=bridge-local network=192.168.50.0
/ip dhcp-client
add interface=ether1
add address=10.33.33.0/27 dns-server=10.33.33.1 gateway=10.33.33.1
add address=172.16.10.0/24 dns-server=172.16.10.1 gateway=172.16.10.1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
add address=192.168.50.0/24 dns-server=8.8.8.8 gateway=192.168.50.1
set allow-remote-requests=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=controller
/system note
set show-at-login=no
/tool romon
set enabled=yes
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Majestic-12 [Bot] and 25 guests
