miku
No internet traffic. Tips needed
Fri Mar 15, 2024 11:06 pm
I have a problem with routing to the internet. It is about the route indicated by the red arrow. Green arrows show operating connections with the current HAP AC Lite configuration. I am asking for advice what I should change in the configuration so that the red route start to work.
Current hAP config attached.
# 2024-03-15 20:26:17 by RouterOS 7.15beta6
# software id = XXXXXXXXX
# model = RB952Ui-5ac2nD
# serial number = XXXXXXXXX
add add-dhcp-option82=yes comment="Interfejsy LAN" dhcp-snooping=yes name=\
    bridge_lan protocol-mode=none
add comment="Interfejs LTE" name=bridge_lte protocol-mode=none
add admin-mac=E4:xx:xx:xx:xx:xx auto-mac=no comment="Interfejs Neostrada" \
    fast-forward=no name=bridge_neo protocol-mode=none
/disk
set usb media-interface=none media-sharing=no slot=usb
add comment="Interfejsy WAN" name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk comment="Profil dla sieci bezprzewodowej" \
    disable-pmkid=yes group-ciphers=tkip,aes-ccm mode=dynamic-keys name=\
    p36_play_profile supplicant-identity=MikroTik unicast-ciphers=\
    tkip,aes-ccm
add authentication-types=wpa2-psk disable-pmkid=yes mode=dynamic-keys name=\
    p36_profile supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=client-mode band=\
    2ghz-b/g/n channel-width=20/40mhz-eC comment="WiFi 2.4Ghz" country=poland \
    disabled=no disconnect-timeout=5s distance=indoors frequency=2462 \
    installation=indoor l2mtu=1598 name=wlan2G security-profile=p36_profile \
    ssid=x36 wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-Ceee comment="WiFi 5GHz" country=poland disabled=no \
    frequency=auto installation=indoor l2mtu=1598 mode=ap-bridge name=wlan5G \
    security-profile=p36_play_profile ssid=x36play wmm-support=enabled \
    wps-mode=disabled
/interface wireless manual-tx-power-table
set wlan2G comment="WiFi 2.4Ghz"
set wlan5G comment="WiFi 5GHz"
/interface wireless nstreme
add comment="Pula dhcp LAN" name=dhcp_lan_pool ranges=\
    192.168.99.180-192.168.99.220
add comment="Pula dhcp NEO" name=dhcp_neo_pool ranges=\
    192.168.1.101-192.168.1.169
add address-pool=dhcp_lan_pool allow-dual-stack-queue=no always-broadcast=yes \
    bootp-support=dynamic comment="Serwer dhcp  dla LAN" interface=bridge_lan \
    lease-time=10m name=dhcp_lan
add address-pool=dhcp_neo_pool allow-dual-stack-queue=no always-broadcast=yes \
    bootp-support=dynamic interface=bridge_neo name=dhcp_neo
/queue simple
add comment="Pomiar ruchu przez interfejs LTE (patrz mangle)" max-limit=\
    100M/100M name=qRuchLTE packet-marks=traffic_lte queue=\
    ethernet-default/ethernet-default target=bridge_lan total-limit-at=100M \
    total-max-limit=100M total-queue=ethernet-default
/routing table
add comment="Tablica routingu przez Neostrade" disabled=no fib name=\
    viaNeostrada
/ip smb
set enabled=no interfaces=bridge_lan
add bridge=bridge_lan comment=defconf interface=ether2 trusted=yes
add bridge=bridge_lan comment=defconf interface=ether3 trusted=yes
add bridge=bridge_lan comment=defconf interface=ether4 trusted=yes
add bridge=bridge_lan comment=defconf fast-leave=yes interface=wlan5G \
    trusted=yes
add bridge=bridge_lte interface=ether5
add bridge=bridge_lan interface=ether1 trusted=yes
add bridge=bridge_neo edge=no-discover fast-leave=yes interface=wlan2G
set udp-timeout=10s
set discover-interface-list=none lldp-mac-phy-config=yes lldp-max-frame-size=\
    yes lldp-med-net-policy-vlan=1
/ip settings
set rp-filter=loose tcp-syncookies=yes
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=WAN
add comment=defconf interface=bridge_lan list=LAN
add interface=bridge_lte list=WAN
add interface=bridge_neo list=LAN
/interface wireless access-list
add comment=neostrada.lan interface=wlan2G mac-address=AC:xx:xx:xx:xx
/interface wireless cap
set bridge=bridge_lan discovery-interfaces=bridge_lan interfaces=wlan2G
/interface wireless sniffer
set memory-limit=200 receive-errors=yes
/interface wireless snooper
set receive-errors=yes
add address=192.168.188.10/24 comment="Router LTE" interface=bridge_lte \
    network=192.168.188.0
add address=192.168.99.1/24 interface=bridge_lan network=192.168.99.0
add address=192.168.1.10/24 comment="Router TP-Link" interface=bridge_neo network=192.168.1.0
add address=127.0.0.1 interface=lo network=127.0.0.1
/ip cloud
set update-time=no
/ip dhcp-server alert
add comment="Wykryto obcy serwer DHCP" disabled=no interface=bridge_neo \
    on-alert=":local sysname [/system identity get name];\r\
    \n:local mac \$\"mac-address\";\r\
    \n:local interf [/interface bridge host get [/interface bridge host find w\
    here mac-address=\$mac] on-interface];\r\
    \n\r\
    \n:log warning \"Unknown DHCP server on interface: \$interface (IP: \$addr\
    ess, MAC: \$mac, interface: \$interf)\"" valid-server=E4::xx:xx:xx:xx
/ip dhcp-server config
set accounting=no
add address=192.168.1.0/24 comment="Network tp-link" dns-server=\
    192.168.1.10 domain=.lan gateway=192.168.1.10
add address=192.168.99.0/24 comment="Network hAP" dns-server=\
    192.168.99.1 domain=.lan gateway=192.168.99.1 netmask=24 ntp-server=\
    192.168.188.1
set allow-remote-requests=yes cache-max-ttl=3d cache-size=4096KiB servers=\
    192.168.188.1,192.168.1.1
/ip dns adlist
add file=adhosts_20240309.txt ssl-verify=no
/ip dns static
add address=192.168.99.1 comment="Router hAP" name=router.lan
add address=192.168.188.1 comment="Router LTE" name=lte.lan
add address=192.168.1.1 comment="Router Neostrada" name=neostrada.lan
add address=192.168.99.100 comment="TV" name=telewizor.lan
/ip firewall address-list
add address=192.168.99.100 disabled=yes list=list_via_neo
add address=192.168.99.99 disabled=yes list=list_via_neo
add address=192.168.99.220 disabled=yes list=list_via_neo
add action=jump chain=forward comment="jump to kid-control rules" \
    jump-target=kid-control
    established,related,untracked
    invalid
add action=accept chain=input comment="defconf: accept ICMP" \
    in-interface-list=LAN protocol=icmp
add action=accept chain=input comment="Accept DNS request" dst-port=53 \
    in-interface-list=LAN protocol=udp
add action=accept chain=input comment="Accept NTP response" in-interface-list=\
    WAN protocol=udp src-port=123
    "Accept discovery requests from loopback" connection-state=new dst-port=\
    5678 in-interface=lo protocol=udp
add action=accept chain=input comment="Answers from DNS at LTE" \
    connection-state=new in-interface=bridge_lte protocol=udp \
    src-mac-address=48::xx:xx:xx:xx
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    in-interface-list=!LAN log=yes log-prefix="drop not from LAN"
    connection-state=new in-interface-list=WAN log=yes log-prefix=\
    "drop all from WAN not DSTNATed "
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
# add action=accept chain=forward comment="Accept bridge_neo -> internet" \
    # disabled=yes dst-address=!192.168.0.0/16 log=yes log-prefix=\
    # "Accept bridge_neo -> internet" src-address=192.168.1.0/24
    # disabled=yes dst-address=192.168.1.0/24 log=yes log-prefix=\
    # "Accept internet -> bridge_neo" src-address=!192.168.0.0/16
    connection-state=invalid
add action=accept chain=output comment="Accept NTP request" dst-port=123 \
    out-interface-list=WAN protocol=udp
/ip firewall mangle
add action=mark-packet chain=prerouting comment=\
    "Mark traffic to LTE" dst-address=!192.168.0.0/16 in-interface=\
    bridge_lte new-packet-mark=traffic_lte passthrough=yes
    "Mark traffic from LTE" in-interface=bridge_lte new-packet-mark=\
    traffic_lte passthrough=yes src-address=!192.168.0.0/16
add action=mark-connection chain=prerouting comment=\
    "Mark new connections toward Neostrada" connection-mark=no-mark \
    connection-state=new dst-address=!192.168.0.0/16 new-connection-mark=\
    conn_to_neo passthrough=yes src-address-list=list_via_neo
add action=mark-routing chain=prerouting comment=\
    "Mark routing toward Neostrada" connection-mark=conn_to_neo dst-address=\
    !192.168.0.0/16 new-routing-mark=viaNeostrada passthrough=no \
add action=mark-packet chain=forward comment=\
    "Mark traffic to Neostrada" connection-mark=conn_to_neo \
    dst-address=!192.168.0.0/16 log-prefix="do neostrady " new-packet-mark=\
    traffic_neo out-interface=bridge_lan passthrough=yes src-address=\
    192.168.0.0/16
    "Mark traffic from Neostrada" connection-mark=conn_to_neo \
    dst-address=192.168.0.0/16 in-interface=bridge_lan new-packet-mark=\
    traffic_neo passthrough=yes src-address=!192.168.0.0/16
/ip hotspot profile
add comment="Default LTE" disabled=no distance=10 dst-address=0.0.0.0/0 \
    gateway=192.168.188.1%bridge_lte pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add disabled=no distance=20 dst-address=0.0.0.0/0 gateway=\
    192.168.1.1%bridge_neo pref-src="" routing-table=main scope=30 \
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
    192.168.1.1%bridge_neo pref-src="" routing-table=viaNeostrada scope=30 \
/ip smb shares
set [ find default=yes ] directory=/flash/pub
add directory=usb1/media name=media read-only=yes valid-users=guest
/ipv6 nd
/routing rule
add action=lookup-only-in-table comment="Traffic toward neostrada" \
    disabled=no dst-address="" interface=bridge_neo routing-mark=viaNeostrada \
    table=viaNeostrada
/system clock
set time-zone-name=Europe/Warsaw
/system ntp client
set enabled=yes mode=multicast
/system ntp client servers
add address=lte.lan
/system package update
set channel=testing
/system scheduler
add interval=30s name=updateLEDs on-event="/system/script/run lteSignal2Led" \
    policy=read,write,test start-date=2024-03-07 start-time=23:09:49
Users browsing this forum: questmajor and 9 guests
