Lokamaya
Unifi Network Controller via Mikrotik Wireless Setup
Sat Mar 16, 2024 6:09 pm
Hi all,
This is my first experience working with the Mikrotik wireless LAN and Unifi network controller system. My setup is quite simple. I just want to give internet access to clients in different buildings, while managing the Unifi access point centrally. And I'm quite happy with the results.
Wireless devices:
- Mikrotik mANTBox as "ap bridge" for central
- Mikrotik SXT as "station bridge" for clients
Access Points:
- Unifi Cloud UCK G2 Plus
- USW 8 POE Switches
- Unifi access point (various versions)
Network diagram
When something goes wrong, login to client antenna (SXT) via WinBox and SSH to intended Unifi devices
On Winbox, open terminal and type:
/system/
ssh unifi-ip-address src-address=xst-ip-address user=unifi-ssh-user
Hope this help for those who want a similar setup.
anav
Re: Unifi Network Controller via Mikrotik Wireless Setup
Sat Mar 16, 2024 6:35 pm
The diagram labelling needs work.
How do vlans 1920,1930 just popup out of the blue ( actually red and orange) for example. They should be traceable back to the 750.
Its also not clear what is the management VLAN ( the vlan where every smart device should get its IP address from ). It would appear to be vlan99 but I fail to
see a vlan99 address on SXT1,2, MANT, or the two USW-8s???
Lokamaya
Mon Mar 18, 2024 1:29 am
Yes, Anav... need time to draw a complete diagram. Hopefully in the near future.
In short, there are two approaches: client have its own DHCP server, or everything is centralized. Currently I use the first approach on my setup.
Users browsing this forum: No registered users and 11 guests
