First here is my diagram:
With the above diagram, all 4 devices (3 routers and 1 PC) can PING each other, but when I forward port 3389 to the Internet, I encounter the following problem:
I use the following script on all 3 routers to forward ports:
Code: Select all
/ip firewall nat add action=dst-nat chain=dstnat dst-address-type=local dst-port=11010 protocol=tcp to-addresses=192.168.0.10 to-ports=3389
I tried another way that in addition to using the above script, I needed to add a srcnat with the following script to be able to use:
Code: Select all
add action=masquerade chain=srcnat comment="Internet" out-interface=all-ppp
add action=masquerade chain=srcnat comment="Hairpin" dst-address-list=lanAddresses src-address-list=lanAddresses
add action=masquerade chain=srcnat out-interface=bridgeLAN <<< here
Thank you for reading and looking forward to hearing your comments
