DMITRYB
Can hap ax2/3 and/or cap ax operate in 5ghz-ac mode (wifi-5)
Sun Mar 17, 2024 11:47 am
Is it possible to for hap ax2/3 and/or cap ax operate in 5ghz-ac mode (wifi-5)? As additions to wap AC that are already installed or they can work only as wifi6? ROS 7.13+
holvoetn
Re: Can hap ax2/3 and/or cap ax operate in 5ghz-an mode (wifi-5)
Sun Mar 17, 2024 12:07 pm
802.11an = wifi4 ?
Can't test right now but normally it should be backwards compatible.
Anyhow, 5ghz-an is in the list of possible bands to be used.
DMITRYB
Sun Mar 17, 2024 12:13 pm
802.11an = wifi4 ?
Sorry my mistake :) "-ac" ofcource .... fixed. "-an" works out of the box ... it has separate interface for 2.4 but i dont want to buy 5 devices and then test backward conpatability on 5Hz interface.
The word "band" confuses me a lot. May be I do not undersand the wifi standards, but for me band is not equal to IEEE 802.11ac/IEEE 802.11ax.
erlinden
Re: Can hap ax2/3 and/or cap ax operate in 5ghz-ac mode (wifi-5)
Sun Mar 17, 2024 1:41 pm
Why?
Does it have to be fixed, the standard is backward compatible and will be used by older devices.
Band has to do with radio frequency.
holvoetn
Re: Can hap ax2/3 and/or cap ax operate in 5ghz-ac mode (wifi-5)  [SOLVED]
Sun Mar 17, 2024 1:52 pm
Ac works without any problems.
DMITRYB
Sun Mar 17, 2024 2:35 pm
Users browsing this forum: Ahrefs [Bot] and 1 guest
