ohilton576
API for Microsoft VBA
Sun Mar 17, 2024 10:57 pm
Hi, I have written a .net API for Microsoft Office (MsAccess VBA etc).
Everything works, and code is stable. but I am having problems with SET commands that require parameters.
e.g. This command will successfully change the system identity
Call objMikApi.Send("/system/identity/set", False)
Call objMikApi.Send("=name=D337MRF5", True)
But when I try to send a command that requires a parameter so that only one entry is changed (and not all of them), for instance the equivalent "/ip dhcp-server lease set block-access=yes [find address=192.168.5.133]", it does not seem to work.
e.g. This command will return a "!done", but does not block the dhcp lease
Call objMikApi.Send("/ip/dhcp-server/lease/set", False)
Call objMikApi.Send("=block-access=yes", False)
Call objMikApi.Send("[find address=192.168.5.133]", True)
I tried various syntax options that still returns "!done" but nothing works because the lease does not actually get blocked.
Call objMikApi.Send("find=address=192.168.5.133", True)
This returns "!done" but does not work either.
Call objMikApi.Send("=address=192.168.5.133", True)
Can someone possibly show me the correct syntax. Please. Struggling for days on this. Desperate.
Users browsing this forum: lurumoney and 3 guests
