I got my Mikrotik working with the L2TP without Ipsec
4011G has two switch chip bridge 0 and bridge 1 and 10g spf+
L2TP give me /29 public ip address to route to.
Do I need to by pass NAT for L2tp no IPSEC?
I add the route for 0.0.0.0/0 to the L2tp tunnel and L2TP tunnel has static ip for ip address so it doesn't use the default route
bridge is using 192.168.88.1/24 and bridge 1 is not being used but I want to connect to ports 6 to 10 but di i need to bride to Route port 1?
current i think bridge 0 is connected connect to port 1 which is route?
I want to switch ports since I have 6 pubic ip address i can use
