I plan to buy a Hex S (RB760iGS) wiht two switches (RB260GS) and one Cap AX (cAPGi-5HaxD2HaxD).
I would like to split network on each port to know who is connected on each port.
But I need all clients connected to the Cap can discuss with connected devices on one swtich.
The second switch, will be isolated of the local network. It's destined to have some ports open on the web.
To identify easily who client is connected or who client discuss which eatch other, I need to assign subnet of each router ethernet port. Or, each switch have his own DHCP Server to identify the network where is the equipment
In my attachment, you see the network map I would like to implement.
I would is it possible or if is a good practice to do that ?
I read some posts on this forum is not very recommended to use split bridge on each network but instead use vlan. But I would like if is true and if there is not a way to have multiple network ?
Other topics : viewtopic.php?p=1028402&hilit=multiple+dhcp#p1028402
or viewtopic.php?t=87458
