Mon Mar 18, 2024 9:18 pm
Hi, I encountered a problem eith my LTE6 router. It was completely set-up, fully working until something happened todays night. I don’t have any signal through ethernet from the device to my local network or even the pc directly. The blue light on the router is on, The antenna itself is mounted on the roof and i cannot reach it. If it would be possible to resolve this problem without me needing to rent a cart to get to the antenna then it would be a perfect solution.
