keyfersk8
low signal client in CAPSMAN?
Mon Mar 18, 2024 9:54 pm
By default, the registration table clients disconnect when passing -80 db, I used my access list with 2 rules: accept (-90..120) and reject (-120..-91), but it continues to reject my connections who are between 80 and 90
/caps-man access-list
add action=accept signal-range=-90..120
add action=reject signal-range=-120..-91
karlisi
Re: low signal client in CAPSMAN?
Tue Mar 19, 2024 11:17 am
IMHO below -80 most of disconnection are caused by signal loss, not by access rules
holvoetn
Tue Mar 19, 2024 11:26 am
Correct.
If using access rules, use 80 as limit.
hinata
Tue Mar 19, 2024 11:35 am
Thanks for the info
keyfersk8
Thu Mar 21, 2024 3:30 pm
I have clients connected to 2GHz and 5ghz on my MAntbox 52 15s with <86db without losses and disconnections applying access rules from each AP , but when I apply CAPsMAN it is the problem
Is the problem CAPsMAN? any extra configuration?
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 42 guests
