kvitek79
IPTV settings
Mon Mar 18, 2024 11:18 pm
I have very simple config. ether1 is WAN port and here comes internet and tv from ISP. Other ports combined into on bridge and on other2 sits TV (it allows media casting like youtube and music) and on ether4 sits TV-box. Looking on connections into Torch I see that iptv traffic is not marked. TV box can see channel list, syncing time and show recommendation from ISP (that means it has access to internet). I've upgrade to 7.14 so I have IGMP Proxy out of box. Here my config, did I miss something:
# 2024-03-18 23:02:05 by RouterOS 7.14.1
# software id = SHWC-BANU
# model = CRS109-8G-1S-2HnD
# serial number = D54E0D114A32
add admin-mac=08:55:31:62:27:46 auto-mac=no comment=defconf igmp-snooping=yes \
    igmp-version=3 mld-version=2 multicast-querier=yes name=bridge \
    port-cost-mode=short
set [ find default-name=ether1 ] mac-address=30:EB:25:24:6E:CC
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=estonia disabled=no distance=indoors frequency=2432 installation=\
    indoor mode=ap-bridge ssid=OhanaKii wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=1d10m name=defconf
/port
set 0 name=serial0
/interface bridge filter
add action=drop chain=output out-interface=wlan1 packet-type=multicast
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
    internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 \
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 \
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 \
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface detect-internet
set detect-interface-list=LAN
/interface ovpn-server server
set auth=sha1,md5
    192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.251 client-id=1:be:86:fb:f1:c9:a0 mac-address=\
    BE:86:FB:F1:C9:A0 server=defconf
add address=192.168.88.249 client-id=1:72:5b:69:25:b2:7e mac-address=\
    72:5B:69:25:B2:7E server=defconf
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
add action=accept chain=input in-interface=ether1 protocol=udp
add action=accept chain=forward in-interface=ether1 protocol=udp
add action=accept chain=input in-interface=ether1 protocol=igmp
add action=accept chain=forward in-interface=ether1 protocol=igmp
    invalid disabled=yes
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
/lcd
set time-interval=hour
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=ether1 upstream=yes
add interface=bridge
/system clock
set time-zone-name=Europe/Tallinn
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: Alek1234, Bing [Bot], Pilo2710 and 34 guests
