ko00000000001
RouterOS get uptime days
Tue Mar 19, 2024 7:15 am
RouterOS get uptime days code is:
put "Uptime: $[:if ([:len [:find [/system resource get uptime] "w"]] != 0) do={([:pick [/system resource get uptime] 0 ([:find [/system resource get uptime] "w"])] *7 + [:pick [/system resource get uptime] ([:find [/system resource get
 uptime] "d"] -1) ([:find [/system resource get uptime] "d"])])} else={[:pick [/system resource get uptime] ([:find [/system resource get uptime] "d"]-1) ([:find [/system resource get uptime] "d"])]}] days"
The output result is:
Uptime: days;Uptime: 18 days
I have a problem.
The output has more "Uptime: days;"
I don't want the output to have the "Uptime: days;" symbol.
Or is there a better way for people to do this?
loloski
Re: RouterOS get uptime days
Tue Mar 19, 2024 8:19 am
:put [/system/resource/get uptime
11w2d15:59:17
ko00000000001
Tue Mar 19, 2024 9:26 am
:put [/system/resource/get uptime]
11w2d15:59:17
Thank you reply.
I need the unit to be days.
diamuxin
Tue Mar 19, 2024 11:35 am
Try:
# rextended's function (thanks Master)
# Convert uptime to seconds
:global timetoseconds do={
    :local inTime $1
    :local wPos   [:find $inTime "w" -1]
    :local dPos   [:find $inTime "d" -1]
    :local itLen  [:find $inTime "." -1] ; :if ([:typeof $itLen] = "nil") do={:set itLen [:len $inTime]}
    :local itSec  [:pick $inTime ($itLen - 2) $itLen]
    :local itMin  [:pick $inTime ($itLen - 5) ($itLen - 3)]
    :local itHou  [:pick $inTime ($itLen - 8) ($itLen - 6)]
    :local itDay  0
    :local itWee  0
    :if (([:typeof $wPos] = "nil") and ([:typeof $dPos] = "num")) do={:set itDay [:pick $inTime 0 $dPos] }
    :if (([:typeof $wPos] = "num") and ([:typeof $dPos] = "num")) do={:set itDay [:pick $inTime ($wPos + 1) $dPos] }
    :if  ([:typeof $wPos] = "num")                                do={:set itWee [:pick $inTime 0 $wPos] }
    :local totitSec ($itSec + (60 * $itMin) + (3600 * $itHou) + (86400 * $itDay) + (604800 * $itWee))
    :return $totitSec
:local upd ([$timetoseconds [/system resource get uptime]] / 86400)
:put "Uptime: $upd days"
patrikg
Tue Mar 19, 2024 12:05 pm
Please use the code tag, to avoid Cool smile face when posting code pre formatted.
Key </>
diamuxin
Tue Mar 19, 2024 12:13 pm
Key </>
OK
rextended
Re: RouterOS get uptime days  [SOLVED]
Tue Mar 19, 2024 12:20 pm
My function timetoseconds is correct...
viewtopic.php?p=930465#p930465
but if already is v7.12.1 (and up) just simply...
:put "Uptime: $([:tonum [/system resource get uptime]] / 86400) days"
ko00000000001
Tue Mar 19, 2024 12:58 pm
That's great.
Effective and simple code.
Thank you.
kevinds
Long time Member
Long time Member
Wed Mar 20, 2024 8:52 pm
Thank you.
Keep in mind, as I have recently found out, after ~500 days it restarts back to 0d00:00:01.
rextended
Wed Mar 20, 2024 9:51 pm
kevinds
Long time Member
Long time Member
Wed Mar 20, 2024 9:52 pm
Exactly.
Users browsing this forum: Ahrefs [Bot] and 5 guests
