dmconde
Issues with DNS on router
Tue Mar 19, 2024 12:50 pm
Hi all,
I am quite new on Mikrotik but have done some basic setups already with no issues. Doing a new one I am getting a problem on router itself to resolve DNS (only required for updates honestly); disabling the rule to block traffic from WAN ("defconf: drop all not coming from LAN") it works but, of course I don't want to remove it (have also tried to do !LAN instead of WAN but same result), Can you please help me? Here you can find my config:
# mar/19/2024 10:47:41 by RouterOS 6.49.13
# software id = **ELIDED**
# model = RB3011UiAS
add name=bridge_LAN
set [ find default-name=ether1 ] name=ether1-WAN1
set [ find default-name=ether2 ] name=ether2-WAN2
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface vrrp
add interface=bridge_LAN name=VRRP
add name=LAN
add name=WAN
add name=dhcp_pool_LAN ranges=20.1.0.50-20.1.1.254
add address-pool=dhcp_pool_LAN disabled=no interface=VRRP name=dhcp_LAN
/queue simple
add disabled=yes dst=ether1-WAN1 max-limit=10M/10M name=LimitWAN1 target=""
add bridge=bridge_LAN interface=ether6
add bridge=bridge_LAN interface=ether7
add bridge=bridge_LAN interface=ether8
add bridge=bridge_LAN interface=ether9
add bridge=bridge_LAN interface=ether10
add interface=bridge_LAN list=LAN
add interface=ether1-WAN1 list=WAN
add interface=ether2-WAN2 list=WAN
add address=20.1.0.2/23 interface=bridge_LAN network=20.1.0.0
add address=20.1.0.1/23 interface=VRRP network=20.1.0.0
add address=10.10.2.250/24 interface=ether1-WAN1 network=10.10.2.0
add address=10.10.1.250/24 interface=ether2-WAN2 network=10.10.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no interface=ether1-WAN1 use-peer-dns=no
add add-default-route=no disabled=no interface=ether2-WAN2
add address=20.1.0.0/23 dns-server=8.8.8.8,1.1.1.1 gateway=20.1.0.1
set servers=8.8.8.8,1.1.1.1
    invalid
    in-interface-list=WAN
    established,related,untracked
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=ether1-WAN1
add action=masquerade chain=srcnat out-interface=ether2-WAN2
add check-gateway=ping distance=1 gateway=1.1.1.1 target-scope=32
add check-gateway=ping distance=2 gateway=8.8.8.8 target-scope=32
add check-gateway=ping distance=4 gateway=10.10.1.1
add distance=1 dst-address=1.1.1.1/32 gateway=10.10.2.1 target-scope=31
add distance=1 dst-address=8.8.8.8/32 gateway=10.10.2.1 target-scope=31
/system clock
set time-zone-name=Europe/London
Thanks in advance
Reason: Elided PII; wrapped config in code block
dmconde
Re: Issues with DNS on router
Tue Mar 19, 2024 1:00 pm
Forgot to mention I have no issues to ping 8.8.8.8 using IP address instead of DNS name
CGGXANNX
Tue Mar 19, 2024 8:37 pm
The order of these two lines should be switched:
anav
Tue Mar 19, 2024 9:22 pm
Weird setup?
I see two WANs but are there any users or devices behind the router??
More weirdly trying to create a third WAN via VRF......... as noted I have no clue of the requirements for traffic flow here.
tangent
Wed Mar 20, 2024 7:08 am
No. Ordering is immaterial for rules in different chains.
CGGXANNX
Re: Issues with DNS on router  [SOLVED]
Wed Mar 20, 2024 8:06 am
Oh yeah I misread the chain value, that's because I've already seen that a
add action=accept chain=input comment="defconf: accept established,related,untracked" \
line was missing in front of the
one and thought that the line that followed was that line. To OP: you are missing the "accept established,related,untracked" rule above for the chain input that should be placed in front of the "drop all" rule. Currently the router can send packet out to WAN but there are no rules to accept the answer packet (except for ICMP, that's why ping with IP address still works). Adding the line
will make sure that answer packets are allowed in.
tangent
Wed Mar 20, 2024 8:57 am
Yes, this now I believe. :)
@dmconde, you might want to read my guide on the default configuration. It was that way on purpose. Dropping that rule was not a good idea.
dmconde
Wed Mar 20, 2024 9:20 am
thanks both! I actually created manually the firewall rules so didn't delete it :?
This is now working and, @tangent, had read now your guide and love it!!!
Users browsing this forum: sid5632 and 21 guests
