lnc1995
Container mounts will create a directory as container store
Wed Mar 20, 2024 3:28 am
OS Version : 7.14~7.15 Beta6
e.g.
/container/mounts/add name=etc_pihole src=disk1/etc dst=/etc/pihole
if src directory "etc" not exists,when the container start,it will auto create a folder,but its type is container store.So user can not use "Files" to add files to this folder.
Seems there's already a similar problem here :viewtopic.php?p=945488&hilit=openvpn+docker#p943450
And another problem,Winbox "Files" can not create a folder,If you use other software, such as WINSCP, the permissions of this folder will be incorrect and cannot be changed. But "CREATE FOLDER" is normal useful on the mobile APP.
Users browsing this forum: No registered users and 3 guests
