zippogo
secure guest network
Wed Mar 20, 2024 3:53 pm
Hey Guys,
i want to configure a guest network. Currently i have a production network with a dns and a dhcp server. i bought 3 cAP ax and using them just fine as an AP. now i wanted to configure a guest network for people to have only an internet connection. I want both networks to be seperated from each other. i read a few possibilities how to do it but i don't know whats the safest/easyest to do. First is a network seperated with VLANs. I really don't like VLANs and i'm not using them in my production network so i think it's not the best way to do it. The other ways was with different bridges and through wireguard to the firewall. I'm new to configurating networks so i'd be happy for suggestions or even guides on how to do it the best way possible. Thanks.
Here is my config of the AP1 (i changed the passwords and names):
# 2024-03-20 14:10:05 by RouterOS 7.14.1
# software id = V4QI-Z9T8
# model = cAPGi-5HaxD2HaxD
add admin-mac=78:9A:18:F5:69:B3 auto-mac=no comment=defconf name=lan_bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi configuration
add country=Germany disabled=no mode=ap name=cfg1 \
    security.authentication-types=wpa2-psk,wpa3-psk .encryption="" ssid=\
    Wifiname1
/interface wifi
add configuration=cfg1 configuration.mode=ap disabled=no name=cap-wifi1 \
    radio-mac=MACADDRESS
add configuration=cfg1 configuration.mode=ap disabled=no name=cap-wifi2 \
add configuration=cfg1 configuration.mode=ap disabled=no name=cap-wifi3 \
add configuration=cfg1 configuration.mode=ap disabled=no name=cap-wifi4 \
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration=cfg1 configuration.mode=ap disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
add bridge=lan_bridge comment=defconf interface=ether2
add bridge=lan_bridge comment=defconf interface=wifi1
add bridge=lan_bridge comment=defconf interface=wifi2
add bridge=lan_bridge interface=ether1
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all wan-interface-list=all
add comment=defconf interface=lan_bridge list=LAN
add interface=ether1 list=LAN
/interface wifi cap
set discovery-interfaces=all
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=\
    none
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
add address= comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system identity
set name=E22AP1
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
holvoetn
Re: secure guest network
Wed Mar 20, 2024 4:26 pm
Best option for your requirements:
capsman and vlan.
You don't need a separate controller, one of the caps can do it easily.
Any other option will require you to make workaround after workaround on 3 different devices and maybe still have some loopholes in it.
No need to sugarcoat it any further.
Users browsing this forum: Ahrefs [Bot], FurfangosFrigyes, rolfschneider and 18 guests
