ConnyMercier
Forum Veteran
Forum Veteran
BootLoop after Update
Wed Mar 20, 2024 7:25 pm
I updated a Mikrotik CRS328-24P-4S+RM to the latest Stable-Version labeled "7.14.1 (stable) 2024-03-08 12:50:23"
Since the Update, the Device is in a permanent Boot-Loop......
Since then, I tried
Loading the backup RouterBOOT loader...
Resetting the RouterOS configuration....
Starting the RouterBOARD in Netinstall mode...
All failed to recover, does somebody have an Idea how to fix?
P.S:
I understand, that the 16MB Storage Size is most likely the Issue.
But at the Time of the Update, there were no Warning / Information in the Changelogs of the Issue.
Just want to Fix my Switch :lol:
stefanau
Re: BootLoop after Update
Wed Mar 27, 2024 10:06 am
Has anyone found a fix for this? I'm in the same situation
infabo
Long time Member
Long time Member
Wed Mar 27, 2024 1:10 pm
Mikrotik offers free support for this kind of issues.
stefanau
Wed Mar 27, 2024 2:29 pm
A few hours later, a range of console error messages including "not an elf header" from the failed upgrade, and I've now managed to use netinstall not only to recover the switch but to install a fresh 7.14.1 onto it without any further issues.
For anyone else that comes across this, I ended up doing a full storage format using console in the process, but am not sure if this was a necessary step.
ConnyMercier
Forum Veteran
Forum Veteran
Re: BootLoop after Update  [SOLVED]
Fri Apr 12, 2024 7:10 pm
Quick Feedback regarding my BootLoop-Issue
After a few failed attempt, I was also able to use Netinstall to recover the Switch with the latest 7.14.2(Stable)
Everything works normally again!
Users browsing this forum: Ahrefs [Bot], Heyman3, JanO, noyo and 38 guests
