Greyhard
access to winbox by wireguard
Fri Mar 22, 2024 4:20 pm
Hello everyone, I have a problem, I cannot enter winbox when I am connected through wireguard. If I can access the server via remote desktop. If you can help me, I would appreciate it.
# model = RB760iGS
add admin-mac=XXXXXXXXXX auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wireguard
add listen-port=13235 mtu=1420 name=XXXXXXXXXX
add listen-port=13236 mtu=1420 name=XXXXXXXXXX
add listen-port=13237 mtu=1420 name=XXXXXXXXXX
add listen-port=13238 mtu=1420 name=XXXXXXXXXX
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip hotspot profile
add name=default-dhcp ranges=192.168.0.2-192.168.0.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 \
set udp-timeout=10s
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.10.3.2/32 interface=XXXXXXXXXX public-key=\
"XXXXXXXXXX"
add allowed-address=10.10.4.2/32 interface=XXXXXXXXXX public-key=\
"XXXXXXXXXX"
add allowed-address=10.10.5.2/32 interface=XXXXXXXXXX public-key=\
"XXXXXXXXXX"
add allowed-address=10.10.6.2/32 interface=XXXXXXXXXX public-key=\
"XXXXXXXXXX"
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=10.10.3.1/24 interface=XXXXXXXXXX network=10.10.3.0
add address=10.10.4.1/24 interface=XXXXXXXXXX network=10.10.4.0
add address=10.10.5.1/24 interface=XXXXXXXXXX network=10.10.5.0
add address=10.10.6.1/24 interface=XXXXXXXXXX network=10.10.6.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.0.100 client-id=XXXXXXXXXX mac-address=\
XXXXXXXXXX server=defconf
add address=192.168.0.3 client-id=XXXXXXXXXX mac-address=\
add address=192.168.0.2 client-id=XXXXXXXXXX mac-address=\
add address=192.168.0.10 mac-address=XXXXXXXXXX server=defconf
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1
set allow-remote-requests=yes servers=XXXXXXXXXX
/ip dns static
/ip firewall address-list
xxxxxxx
established,related,untracked
invalid
add action=accept chain=input comment="wireguard " dst-port=13237 protocol=\
udp
add action=accept chain=input comment="wireguard " dst-port=13235 protocol=\
udp
add action=accept chain=input comment="wireguard " dst-port=13238 protocol=\
udp
add action=accept chain=input comment="wireguard " dst-port=13236 protocol=\
udp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=drop chain=input dst-port=8291 in-interface-list=WAN protocol=tcp
add action=drop chain=input in-interface-list=WAN protocol=udp
add action=dst-nat chain=dstnat dst-port=53 protocol=udp to-addresses=\
192.168.0.1 to-ports=53
/ip firewall raw
add action=drop chain=prerouting comment=\
"DMNTR SecurIP: Block WAN connections from BlackList" in-interface-list=\
WAN src-address-list=dmntr-blacklist
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=America/Argentina/Buenos_Aires
/system identity
set name=RouterOS
/system note
set show-at-login=no
/system scheduler
add comment="DMNTR SecurIP 30m Update Script" interval=3h name=\
dmntr_securipupdate on-event="/system script run dmntr_securip" policy=\
read,write,policy,test start-date=1970-01-01 start-time=00:00:00
add comment="DMNTR SecurIP OnBoot Script" name=dmntr_securipupdateOnBoot \
on-event=":delay 30;system script run dmntr_securip" policy=\
read,write,policy,test start-time=startup
/system script
add comment="DMNTR SecurIP Script" dont-require-permissions=no name=\
dmntr_securip owner=admin policy=read,write,policy,test source="# DMNTR Ne\
twork Solutions SecurIP Installer\
\n# 2022 dmntr@dmntr.net\
\n:local destPath \"securip_dmntr.rsc\";\
\n:local priority \"2\";\
\n:do { /file remove \$destPath } on-error={};\
\n/tool fetch mode=https url=\"https://intelligence.dmntr.net/dmmntr-secur\
ip-lite.rsc\" user=\"XXXXXXXXXX\" password=\"XXXXXXXXXX\" dst-path=\"\$de\
stPath\" output=file;\
\n/system logging disable numbers=0\
\n/import file-name=\$destPath;\
\n/system logging enable numbers=0\
\n/file remove \$destPath;"
/tool mac-server
/tool mac-server mac-winbox
johnson73
Re: access to winbox by wireguard
Fri Mar 22, 2024 4:34 pm
Deleted the super long blacklist, it is not needed here.
The sequence of firewall rules is not correct for you. Remove the last 2 rules from the forward section...
And what was the point of this-
add action=drop chain=input dst-port=8291 in-interface-list=WAN protocol=tcp ?
anav
Fri Mar 22, 2024 4:44 pm
If anyone complains about your long list of code, they should look inwards for not supporting my recommendation for a first post process !!!
Now for the OP......
(1) WIREGUARD is not a local SUBNET, so you only assign an IP address, nothing else!!
(2) Get rid of this default setting, its on the static menu found at /ip dns
/ip dns static
(3) No need for blacklists, waste of time. Get rid of them you will be safe and the associated raw rule.
(4) DROP these two rules, they are NOT required!
A. add action=drop chain=input dst-port=8291 in-interface-list=WAN protocol=tcp
B. add action=drop chain=input in-interface-list=WAN protocol=udp
A. There is no need to block an attempt to 8291, winbox port, because you have the following rule:
Any traffic coming from the WAN that is not already permitted ( aka wireguard ports ), then any such traffic will be dropped already!!
B. Same logic applies here. After the above drop rule identified, any incoming WAN traffic will be dropped!!
(4) What is the purpose of this DANGEROUS rule??
You are very concerned with perceived outside threats and then you OPEN your router to the whole world to abuse your DNS and possibly cause your ISP to blacklist your WANIP etc.....
REMOVE THIS RULE for now, as its not well conceived and state your requirement and we can replace it with something more valid.
anav
Re: access to winbox by wireguard  [SOLVED]
Fri Mar 22, 2024 4:50 pm
Now to answer your question directly
Do this
add interface=wireguardInterfaceX list=LAN
add interface=wireguardInterfaceY list=LAN
etc...
Greyhard
Sat Mar 30, 2024 12:59 am
/ip dns static
Thank you very much for your answer. I apologize for the delay in my response. I have not seen the forum email informing me of your response.
I have edited the post so that they do not see the block lists
Your response has been very helpful to me. I would like to know your opinion on how the configuration is now.
I'm new to mikrotik but I'm passionate about it. I learn a lot by reading your responses to the posts.
# model = RB760iGS
add admin-mac=701 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=XXXXXXXXXXXXX
set [ find default-name=ether2 ] mac-address=XXXXXXXXXXXXX
set [ find default-name=ether3 ] mac-address=XXXXXXXXXXXXX
set [ find default-name=ether4 ] mac-address=XXXXXXXXXXXXX
set [ find default-name=ether5 ] mac-address=XXXXXXXXXXXXX
set [ find default-name=sfp1 ] mac-address=XXXXXXXXXXXXX
add listen-port=13235 mtu=1420 name=AreXXXXXXXXXXXXX
add listen-port=13236 mtu=1420 name=AzcuXXXXXXXXXXXXX
add listen-port=13237 mtu=1420 name=Emanuel
add listen-port=13238 mtu=1420 name=RuXXXXXXXXXXXXX
/interface lte apn
/ip hotspot profile
/port
set 0 name=serial0
/ipv6 settings
add interface=Emanuel list=LAN
set auth=sha1,md5
add allowed-address=10.10.3.2/32 interface=AreXXXXXXXXXXXXX public-key=\
"XXXXXXXXXXXXX"
add allowed-address=10.10.4.2/32 interface=AzcXXXXXXXXXXXXX public-key=\
"XXXXXXXXXXXXX"
add allowed-address=10.10.5.2/32 interface=Emanuel public-key=\
"XXXXXXXXXXXXX"
add allowed-address=10.10.6.2/32 interface=RubXXXXXXXXXXXXX lic-key=\
"XXXXXXXXXXXXX"
192.168.0.0
add address=10.10.3.1/24 interface=Arenales network=10.10.3.0
add address=10.10.4.1/24 interface=Azcuenaga network=10.10.4.0
add address=10.10.5.1/24 interface=Emanuel network=10.10.5.0
add address=10.10.6.1/24 interface=Ruben network=10.10.6.0
/ip cloud
/ip dhcp-client
add address=192.168.0.100 client-id=1:XXXXXXXXXXXXX mac-address=\
XXXXXXXXXXXXX server=defconf
add address=192.168.0.3 client-id=XXXXXXXXXXXXX mac-address=\
add address=192.168.0.2 client-id=XXXXXXXXXXXXX mac-address=\
add address=192.168.0.10 mac-address=XXXXXXXXXXXXX server=defconf
set allow-remote-requests=yes servers=45.90.28.18,45.90.30.18
XXXXXXXXXXXXX
invalid
udp
udp
udp
udp
/ip firewall raw
/ip service
/system identity
set name=RouterOS
/system note
/system scheduler
/system script
add comment="XXXXXXXXXXXXX SecurIP Script" dont-require-permissions=no name=\
\n# 2022 dmntnet\
\n/tool fetch mode=https url=\"httpsXXXXXXXXXXXXXtr.net/dmmntr-secur\
ip-lite.rsc\" user=\"XXXXXXXXXXXXX\" password=\"XXXXXXXXXXXXX\" dst-path=\"\$de\
/tool mac-server
Users browsing this forum: erlinden, gotsprings, mkx and 53 guests
