sebus46
[solved] Dual-WAN PPPoE +DHCP (LAN clients on same VLAN split routing, no load balance)
Sat Mar 23, 2024 12:23 pm
7.14.1 on RB4011iGS+ r2 (not complicated setup)
# 2024-03-23 10:05:45 by RouterOS 7.14.1
# software id = 5WSQ-IVBW
# model = RB4011iGS+
# serial number =
add arp=proxy-arp ingress-filtering=no name=bridge port-cost-mode=short \
    vlan-filtering=yes
set [ find default-name=ether10 ] poe-out=off
set [ find default-name=sfp-sfpplus1 ] name=sfp1
/interface l2tp-server
add name=L2TP-VPN user=
/interface vlan
add interface=bridge mtu=1480 name=vlan21 vlan-id=21
add interface=bridge name=vlan50 vlan-id=50
add interface=bridge name=vlan99 vlan-id=99
add interface=bridge name=vlan100 vlan-id=100
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=60 \
    max-mtu=1480 name=pppoe-out1 user=
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.88.5-192.168.88.148
add name=dhcp-pool99 ranges=192.168.99.2-192.168.99.22
add name=dhcp-pool100 ranges=192.168.100.2-192.168.100.10
add name=L2TP ranges=192.168.88.150-192.168.88.160
add name=dhcp-pool21 ranges=192.168.21.2-192.168.21.6
add address-pool=dhcp-pool99 authoritative=after-2sec-delay interface=\
    vlan99 lease-time=1d name=dhcp-vlan99
add address-pool=dhcp-pool100 interface=vlan100 lease-time=1w3d name=\
    dhcp-vlan100
add address-pool=dhcp-pool21 authoritative=after-2sec-delay bootp-support=\
    none interface=vlan21 name=dhcp-vlan21
/ip smb users
add bridge=bridge disabled=yes interface=\
    ether1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge interface=sfp1 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether3 internal-path-cost=10 \
    path-cost=10 pvid=100
add bridge=bridge interface=ether4 \
add bridge=bridge  interface=ether9 \
add bridge=bridge interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether8 internal-path-cost=10 path-cost=10
set loose-tcp-tracking=no tcp-established-timeout=30m
/ip settings
set max-neighbor-entries=4096 rp-filter=loose
/interface bridge vlan
add bridge=bridge vlan-ids=1
add bridge=bridge tagged=ether2,sfp1,bridge vlan-ids=99
add bridge=bridge tagged=ether2,sfp1,bridge vlan-ids=100
add bridge=bridge tagged=bridge,ether2,sfp1 vlan-ids=50
/interface l2tp-server server
set authentication=mschap2 enabled=yes use-ipsec=yes
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
add address=192.168.99.1/24 interface=vlan99 network=192.168.99.0
add address=192.168.100.1/24 interface=vlan100 network=192.168.100.0
add address=192.168.21.1/29 interface=vlan21 network=192.168.21.0
/ip dhcp-client
add disabled=yes interface=ether1
add comment=defconf disabled=yes interface=ether1
/ip firewall address-list
add address=192.168.88.0/24 list=internal
add address=xx.yyy.zz.aaa list=Whitelist
add address=198.199.104.26 list=banned
add address=118.123.105.90 list=banned
add action=log chain=- comment=\
    ----------------------input--------------------------------
add action=drop chain=input comment="Drop VPN attempts" src-address-list=\
    banned
    established,related,untracked
    invalid
add action=accept chain=input comment="Allow L2TP VPN" in-interface=\
    pppoe-out1 log=yes log-prefix=--vpn-in-1st-- port=500,1701,4500 protocol=\
    udp
add action=accept chain=input comment="Allow IPsec ESP" in-interface=\
    pppoe-out1 log=yes log-prefix=--vpn-in-esp-- protocol=ipsec-esp
    "Remote access to SSL Mikrotik webif & WinBox" dst-port=443,8291 log=yes \
    protocol=tcp src-address-list=Whitelist
    "VPN access to SSL Mikrotik webif & WinBox" dst-port=443,8291 log=yes \
    log-prefix=--VPN-remote-access-- protocol=tcp src-address=192.168.88.161
add action=accept chain=input comment="defconf: accept ICMP (internal)" \
    disabled=yes protocol=icmp src-address-list=internal
add action=accept chain=input comment="Local access to SSH" disabled=yes \
    dst-port=22 protocol=tcp src-address=192.168.88.98
add action=accept chain=input comment="Requests to Mikrotik DNS server (LAN)" \
    disabled=yes dst-port=53 in-interface-list=LAN log=yes log-prefix=--DNS-- \
    protocol=udp
    in-interface-list=!LAN log-prefix="--not lan--"
    -----------------------forward-------------------------------
add action=accept chain=forward log=yes log-prefix=--Yealink-- src-address=\
    192.168.21.2
# L2TP-VPN not ready
add action=accept chain=forward comment="VPN to LAN" in-interface=L2TP-VPN \
    log=yes log-prefix=--vpn-to-lan-- out-interface=bridge
add action=accept chain=forward comment="LAN to VPN" in-interface=bridge log=\
    yes log-prefix=--lan-to-vpn-- out-interface=L2TP-VPN
add action=accept chain=forward comment="VPN to Internet" in-interface=\
    L2TP-VPN log=yes log-prefix=--vpn-out-- out-interface=pppoe-out1
add action=accept chain=forward comment="Internet to VPN" in-interface=\
    pppoe-out1 log=yes log-prefix=--vpn-in-- out-interface=L2TP-VPN
    connection-state=invalid
    connection-state=new in-interface-list=WAN log=yes log-prefix=\
    "--WAN drop--"
    "Disable Guest VLAN to anywhere but Internet" in-interface=\
    vlan99 out-interface=!pppoe-out1
add action=drop chain=forward comment="Drop all other" disabled=yes \
    log-prefix="--Drop all other--" out-interface=pppoe-out1
    out-interface=pppoe-out1 out-interface-list=WAN
add action=dst-nat chain=dstnat comment="VNC" dst-port=5900 log=yes \
    protocol=tcp src-address-list=Whitelist to-addresses=192.168.88.25 \
    to-ports=5900
add action=dst-nat chain=dstnat comment="Z web" dst-port=9001 protocol=\
    tcp src-address-list=Whitelist to-addresses=192.168.88.11 to-ports=80
add action=dst-nat chain=dstnat comment="Z stream" dst-port=8082 \
    protocol=tcp src-address-list=Whitelist to-addresses=192.168.88.11 \
    to-ports=8001
add action=dst-nat chain=dstnat comment="VM Minecraft Server" dst-port=\
    27165 log=yes log-prefix=--mc- protocol=tcp to-addresses=192.168.88.50 \
    to-ports=25565
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set sip disabled=yes
set pptp disabled=yes
add disabled=no distance=1 dst-address=192.168.2.10/32 gateway=ether1 \
    pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/ip service
set telnet disabled=yes
set www disabled=yes
set www-ssl certificate=sc_WC disabled=no tls-version=only-1.2
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ppp secret
add name=***** profile=default-encryption remote-address=192.168.88.161 \
    service=l2tp
/system clock
set time-zone-name=Europe/London
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=xx.xx.xx.xx
add address=yy.yy.yy.y
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
Currently have a single ISP1 with:
- external traffic to the router itself?? aka VPN LT2P
- external traffic to the LAN?? aka port forwarding to LAN server(s)
- traffic entering/leaving the router by VPN
I will get ISP2 (also PPPoE client) added and temporary requirements are:
- external traffic to the router itself?? aka VPN to stay on ISP1 (unchanged)
- traffic entering/leaving the router by VPN to stay on ISP1 (unchanged)
- external traffic to the LAN?? aka port forwarding to LAN server(s) be split between ISP1 & ISP2 (depending on inbound WAN / NAT)
No need for lout oad balancing, most traffic to go out on IPS2 with only a couple of clients to go out on IPS1 (via Policy Routing with src-address I assume)
I am trying to pre-prepare the config, as I will not want much downtime when the second line gets connected
So far I think that these are really helpful:
viewtopic.php?t=179853
viewtopic.php?t=203165
viewtopic.php?t=189520
But if somebody has good pointers on config with ISP2 added to the mix, it would be most appreciated
sebus
sebus46
Re: Dual-WAN PPPoE +DHCP (LAN clients split routing on same VLAN)
Tue Mar 26, 2024 8:03 am
deleted
anav
Re: Dual-WAN PPPoE +DHCP (LAN clients on same VLAN split routing, no load balance)
Tue Mar 26, 2024 12:41 pm
Can you provide a diagram, so far it looks like most of your bridge ports are connected to smart devices (like smart APs and switches) as they are mostly trunk ports......
You can remove this completely useless line.......... bridge ports/vlans deals with data traffic or management vlan.
anav
Tue Mar 26, 2024 12:45 pm
If you have a home subnet .88, then call it vlan88 and make it a vlan and then the config will make sense.
and where is VLAN50 ????
add address=192.168.88.1/24 interface=bridge network=192.168.88.0 { wrong }
This is not recommended........... list or not. USE your VPN to access the router and then access winbox. or get rid of the old VPN and use wireguard VPN, much simpler.
Seeing your vpn issues, definitely drop it and use wireugard.
The IP route you creates is for what ???? it doesnt match up with anything!!!
sebus46
Tue Mar 26, 2024 1:34 pm
Grateful for the comments, but I was not asking about my current config.
I was asking how to make use of dual-wan (when it is here):
- external traffic to the router itself?? aka VPN to stay on ISP1 (unchanged) - and that works just fine
- traffic entering/leaving the router by VPN to stay on ISP1 (unchanged) - which also works fine
sebus
sebus46
Tue Mar 26, 2024 1:37 pm
Vlan 50 is to yet be used (I have to first configure devices to use it, so currently unused)
I have no issues with VPN, it works as I expect it to work (from external PC or iOS device), when I set that up years ago, Wireguard was not an option on iOS
To swap default vlan to VLAN88 is of course possible, but requires full re-config of all network devices around the house (some easier to get to, some more difficult ie switch in the loft), so unagged ports are correct throughout
Remote access rule is perfectly valid for direct Winbox access (which is way easier than VPN from inside another network), from a PC on a remote network, which IP is restricted by Whitelist list
One must agree that there is no ONE-FOR-ALL solution in IT every time, otherwise life would be terribly boring,?
And if you mean:
then it is also valid to get to web interface of the DSL modem going on the same Ether1 as PPPoE client (when IP 192.168.2.1 is assigned to Ether1 - hacky, but works!
anav
Tue Mar 26, 2024 1:53 pm
nm duplicate
anav
Tue Mar 26, 2024 1:54 pm
Lots of threads contain the information you are looking for. Suggest search.
The links you already have seem germane.
sebus46
Tue Mar 26, 2024 1:55 pm
OK, will muddle through it
anav
Tue Mar 26, 2024 1:56 pm
I wont work on a config that is in my opinion hosed, but many others should help when you have specific questions.
sebus46
Tue Mar 26, 2024 2:17 pm
Thank you. Appreciate (even if you consider hosed, a basic clean config which fully works - just because something could be done different, that is very authoritarian view)
sebus46
Re: [solved] Dual-WAN PPPoE +DHCP (LAN clients on same VLAN split routing, no load balance)
Mon Apr 22, 2024 8:25 pm
Had to use Routing / Rules to "lookup only" in WAN2 table for specific addresses to go out to internet using WAN2
But also had to add additional rules for the same addresses, ABOVE, using main table for the local network access for these devices that are set to use WAN2 table
Otherwise these two clients could not "see" each other locally
anav
Mon Apr 22, 2024 8:41 pm
Often the case. Routing rules are powerful as they move all the traffic out that door............ so the trick when using them is to move other traffic first.
Some chap (rplant) came up with a trick to do so, on a one liner, as the first rule in Routing Rules, which is pretty cool.
/routing rule
add action=lookup comment="min-prefix=0, all except 0.0.0.0/0" disabled=no min-prefix=0 table=main
Just an easy way of making all routes that are not 0.0.0.0/0 use the main routing table
sebus46
Wed Apr 24, 2024 8:02 pm
That is really nice, thanks
But Winbox GUI cannot handle the display of this rule
anav
Wed Apr 24, 2024 10:14 pm
I had no issues implementing this in winbox ???
Here is my export line, after doing so!
/routing rule
add action=lookup disabled=no min-prefix=0 table=main
The only thing I did was take the default rule already supplied and added at the very bottom: Min Prefix: 0 and hit apply.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 24 guests
