roxanaschram
VLAN headache
Sun Mar 24, 2024 10:15 pm
So I have a site I manage and they recently decided to rent an office to another company and I need to setup a VLAN to isolate their traffic away from the rest of the client company. They have a hex s (RB760iGS) as the gateway. Internet comes in on ether1. There is a CRS305 connected to it, then fiber goes to the other side of the building where there is another hex s being used as a switch basically. I know, doesn't seem like a great device for a switch but this part of the building only has 3 offices. No need for a larger device. Anyways, all the ports on it are assigned to a bridge, no firewall or anything. It's connected to the CRS305 via the sfp1 port. The tenant comes off ether1 on it. I've created a VLAN on the gateway and tried tagging ether1 on the second switch for the VLAN I created but all traffic still goes across as normal. I tried search here and even resorted to asking Chat but no luck. Nothing has worked. Any one have any suggestions?
anav
Re: VLAN headache
Sun Mar 24, 2024 10:48 pm
Config of hex, config of second hex please, the 305 I will assume has trunk port from HEX with internet and a trunk port going to hex switch.
Assuming there is management vlans where the 305 and hex switch get their IP address from.
/export file=anynameyouwish ( minus router serial number, public WANIP information, keys etc.)
roxanaschram
Re: VLAN headache
Mon Mar 25, 2024 12:15 am
This is from my last attempt. There have been various changes and settings attempted... I found most people want the switch port set to vlan, but these don't support that option...
Gateway:
# 2024-03-24 17:59:16 by RouterOS 7.14.1
# software id =
# model = RB760iGS
# serial number =
add name=pnp_bridge port-cost-mode=short
add name=smr_bridge port-cost-mode=short
/interface vlan
add interface=smr_bridge name=vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] supplicant-identity=MikroTik-Gateway
add name=smr_dhcp ranges=192.168.1.100-192.168.1.245
add name=pnp_dhcp ranges=10.185.79.27-10.185.79.29
add name=vlan10_dhcp ranges=10.200.201.10-10.200.201.15
add address-pool=smr_dhcp interface=smr_bridge lease-time=1h name=defconf
add address-pool=pnp_dhcp interface=pnp_bridge lease-time=10m name=pnp_fiber
/ip smb users
/port
set 0 name=serial0
/ppp profile
set *FFFFFFFE bridge=smr_bridge local-address=192.168.1.1 remote-address=\
    smr_dhcp use-ipv6=no
/queue simple
add max-limit=38M/38M name=pnp_queue target=pnp_bridge
add max-limit=10M/10M name=tjm_client target=vlan10
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=smr_bridge comment=defconf ingress-filtering=no interface=ether3 \
    internal-path-cost=10 path-cost=10
add bridge=pnp_bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=smr_bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=pnp_bridge comment=defconf ingress-filtering=no interface=sfp1 \
add bridge=smr_bridge interface=ether2 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
    LAN
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add comment=defconf interface=smr_bridge list=LAN
add comment="Spirit Communications" interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.1.1/24 comment=defconf interface=smr_bridge network=\
    192.168.1.0
add address=[redacted]/29 interface=ether1 network=[redacted]
add address=10.185.79.26/24 interface=pnp_bridge network=10.185.79.0
add address=10.200.201.1/24 interface=vlan10 network=10.200.201.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1 use-peer-dns=no
/ip dhcp-server lease
[removed]
add address=10.185.79.0/24 dns-server=9.9.9.9 domain=149.112.112.112 gateway=\
    10.185.79.26 netmask=22
add address=10.200.201.0/24 dns-server=9.9.9.9 domain=10.200.201.1 gateway=\
    10.200.201.1
add address=192.168.1.0/24 comment=defconf dns-server=9.9.9.9,1.1.1.1 \
    gateway=192.168.1.1 netmask=24
set servers=9.9.9.9,1.1.1.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
add action=drop chain=forward in-interface=pnp_bridge out-interface=\
    smr_bridge
add action=drop chain=forward in-interface=smr_bridge out-interface=\
    pnp_bridge
add action=accept chain=input dst-port=8291 in-interface=ether1 protocol=tcp \
    src-address=[redacted]
add action=drop chain=input dst-port=8291 in-interface=ether1 protocol=tcp \
    src-address=![redacted]
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=established,related hw-offload=yes in-interface=\
    smr_bridge
    connection-state=invalid
add action=dst-nat chain=dstnat comment="Temp Rule (delete when done)" \
    dst-port=8292 protocol=tcp src-address=[redacted] to-addresses=\
    192.168.1.2 to-ports=8291
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
add check-gateway=ping comment="Spirit Communications" disabled=no \
    dst-address=0.0.0.0/0 gateway=[redacted]
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.1.0/24,[redacted]/32
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/ppp secret
add name=vpn profile=default-encryption
/system clock
set time-zone-name=America/New_York
/system identity
set name=MikroTik-Gateway
/system note
set show-at-login=no
/tool bandwidth-server
set authenticate=no enabled=no
/tool mac-server
/tool mac-server mac-winbox
Switch:
# 2024-03-24 18:11:56 by RouterOS 7.14.1
# software id = [redacted]
# model = RB760iGS
# serial number = [redacted]
add admin-mac=2C:C8:1B:E7:DD:0B auto-mac=no comment=defconf fast-forward=no \
    ingress-filtering=no name=bridge1 port-cost-mode=short vlan-filtering=yes
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
/interface lte apn
/port
set 0 name=serial0
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether2 \
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge1 comment=defconf ingress-filtering=no interface=sfp1 \
add auto-isolate=yes bridge=bridge1 ingress-filtering=no interface=ether1 \
    internal-path-cost=10 path-cost=10 pvid=10
/interface bridge settings
set use-ip-firewall=yes
set udp-timeout=10s
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
    forward=no max-neighbor-entries=8192
/interface bridge vlan
add bridge=bridge1 tagged=ether1 untagged=sfp1,ether2,ether3,ether4,ether5 \
    vlan-ids=10
add comment=defconf interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=sfp1 list=LAN
set auth=sha1,md5
add address=192.168.1.2 interface=sfp1 network=192.168.1.0
/ip dhcp-client
add comment=defconf interface=bridge1
set allow-remote-requests=yes
set sctp disabled=yes
/ip service
set winbox address=0.0.0.0/0
/system clock
/system identity
set name=Front-Building-Bridge
/system note
/tool mac-server
anav
Re: VLAN headache
Mon Mar 25, 2024 3:13 am
ONE BRIDGE - ROUTER
# model = RB760iGS
add name=bridge ingress-filtering=yes
/interface vlan
add interface=bridge  name=vlan10-client vlan-id=10
add interface=bridge  name=vlan2-homeoffice  vlan-id=2
add interface=bridge  name=vlan99-mngmt   vlan-id=99  comment="smart devices control subnet"
/interface wireguard
add comment="A Proper VPN!"  listen-port=13445  mtu=1420 name=wireguard1
add comment name=Trusted
add name=homeoffice-pool ranges=192.168.1.100-192.168.1.245
add name=client-pool ranges=10.200.201.10-10.200.201.15
add name=mngmt-pool ranges=192.168.99.10-192.168.99.50
add address-pool=homeoffice-pool interface=vlan2-homeoffice lease-time=1h name=office-dhcp
add address-pool=client-pool  interface=vlan10-client  lease-time=10m name=client-dhcp
add address-pool=client-pool  interface=vlan99-mngmt  lease-time=10m name=mngmt-dhcp
add bridge=bridge ingress-filtering=yes frame-types=admit-only-priority-and-untagged interface=ether2  pvid=2
add bridge=bridge ingress-filtering=yes frame-types=admit-only-priority-and-untagged interface=ether3  pvid=2
add bridge=bridge ingress-filtering=yes frame-types=admit-only-priority-and-untagged interface=ether4  pvid=2
add bridge=bridge ingress-filtering=yes frame-types=admit-only-priority-and-untagged interface=ether5  pvid=2
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged  interface=sfp1 comment="Trunk to 305"
set udp-timeout=10s
set discover-interface-list=Trusted
add bridge=bridge tagged=bridge,sfp1  untagged=ether2,ether3,ether4,ether5  vlan-ids=2
add bridge=bridge tagged=bridge,sfp1  vlan-ids=10,99
/interface wireguard peers
add allowed-address=10.10.10.2/32 interface=wireguard1 comment=" remote admin desktop"
    public-key= "---------------------="
add allowed-address=10.10.10.3/32 interface=wireguard1 comment=" remote admin laptop"
    public-key= "--&&&&&&&&&---="
add allowed-address=10.10.10.4/32 interface=wireguard1 comment=" remote admin smartphone-ipad"
    public-key= "----********------="
/ipv6 settings
set disable-ipv6=yes
set detect-interface-list=NONE
add interface=vlan2-homeoffice list=LAN
add interface=vlan10-client list=LAN
add interface=wireguard1 list=LAN
add interface=vlan99-mngmt  list=LAN
add interface=vlan2-homeoffice list=Trusted
add interface=wireguard1 list=Trusted
add interface=vlan99-mngmt  list=Trusted
add address=192.168.1.1/24  interface=vlan2-homeoffice network=192.168.1.0
add address=10.200.201.1/24 interface=vlan10-client network=10.200.201.0
add address=10.10.10.1/24 interface=wireguard1 network=10.10.10.0
add address=192.168.99.1/24 interface=vlan99-mngmt network=192.168.99.0
/ip cloud
/ip dhcp-client
add address=10.200.201.0/24 dns-server=10.200.201.1 gateway=10.200.201.1
add address=192.168.1.0/24  dns-server=192.168.1.1   gateway=192.168.1.1
add address=192.168.99.0/24  dns-server=192.168.99.1   gateway=192.168.99.1
/ip firewall address-list
add address=192.168.1.X/32  list=Authorized comment="Local Router Admin IP"
add address=10.10.10.0/24  list=Authorized comment="Remote Admin Access"
    invalid
add acction=accept chain=input dst-port=13445 protocol=udp   comment="wireguard handshake"
add action=accept chain=input comment="Admin access only "  src-address-list=Authorized
add action=accept chain=input in-interface-list=LAN dst-port=53 protocol=udp comment="dns services"
add action=accept chain=input in-interface-list=LAN dst-port=53 protocol=tcp comment="dns services"
add action=drop chain=input comment="Drop all else"  {  put this as last rule }
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="admin access vlans"  src-address-list=Authorized out-interface-list=LAN
add action=accept chain=forward comment="port forwarding"  connection-nat-state=dstnat disabled=yes { enable if required }
add action=drop chain=forward comment="Drop all else"
/ip service
set winbox address=192.168.1.0/24, 10.10.10.0/24,192.168.99.0/24 set port =NOT DEFAULT!!!!
/system clock
/tool mac-server
set allowed-interface-list=NONE
set allowed-interface-list=Trusted
ONE BRIDGE - SWITCH
# model = RB760iGS
add ingress-filtering=no name=bridge1  vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan99-management vlan-id=99
add name=Manage
add bridge=bridge ingress-filtering=yes frame-types=admit-only-priority-and-untagged interface=ether1  pvid=10
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged  interface=sfp1 comment="Trunk from 305"
set discover-interface-list=Manage
/ipv6 settings
disable-ipv6=yes \
add bridge=bridge1  tagged=sfp1  untagged=ether2,ether3,ether4,ether5  vlan-ids=2
add bridge=bridge1  tagged=sfp1  untagged=ether1  vlan-ids=10
add bridge=bridge1  tagged=bridge1,sfp1  vlan-ids=99
add interface=vlan99-management  list=Manage
add address=192.168.99.3/24  interface=vlan99-management  network=192.168.99.0
set allow-remote-requests=yes servers=192.168.99.1
add dst-address=0.0.0.0/0 gateway=192.168.99.1 routing-table=main
/tool mac-server
set allowed-interface-list=Manage
roxanaschram
Re: VLAN headache
Mon Mar 25, 2024 5:06 am
Why the wireguard added? I've removed all the VPN related setting why I started to manage the site and set up zerotier for their systems... Also, there is equipment I am not allowed to modify settings as it is owned and managed by another company that provides it on a leasing/licensing scheme so I can't change the 2nd bridge without a huge ordeal from the equipment owner... It's a nightmare at this site.
edit:
the vpn because I have the winbox ports temporally open to my home ip?
anav
Re: VLAN headache
Mon Mar 25, 2024 12:24 pm
Yup, I saw unsafe pptp and then winbox open on the internet............. The right way to handle that is for you to at least be able to wireguard into the First Router. From there you can reach the 305 switch and the second hex through the neighbours discovery etc.
roxanaschram
Re: VLAN headache
Mon Mar 25, 2024 5:08 pm
So I gave the scripts a try but before I could test the vlans all the security cameras went down as did their machinery so I had to revert back... I knew the machinery would go down because they hardcoded their IP addresses to their device... I'll give another try after hours...
anav
Re: VLAN headache
Mon Mar 25, 2024 5:14 pm
Ensure the subnet being used for the cameras fits what they are hardcoded too.
Then via the mac addresses of each camera fix the IP static to the mac address in DHCP leases for that subnet
roxanaschram
Re: VLAN headache
Mon Mar 25, 2024 5:22 pm
I have the exported dhcp lease data and copied it over and it showed up in the router with the new config but any attempt to ping the ip failed so I had to revert back. They were on the main network which is stupid but "I'm just here to keep things working"
roxanaschram
Re: VLAN headache
Tue Mar 26, 2024 3:23 am
So I've reapplied both configs to each device and still no vlan. I attempted to manually set the end device to the vlan id and no connection still. I then moved the fiber from the CRS305 to the HexS to remove any switches between, still no vlan... Using torch, I can see the device I set to the vlan id requesting dhcp, it was tagged... but it never made it to the router...
anav
Re: VLAN headache
Tue Mar 26, 2024 3:38 am
Post both configs again with latest settings
roxanaschram
Re: VLAN headache
Tue Mar 26, 2024 3:41 am
I've reverted back to the original. I can't have the cameras down that long. Also back home now and the winbox is closed to the internet. I only opened it for the weekend to try and do everything from home.
roxanaschram
Re: VLAN headache
Tue Mar 26, 2024 3:49 am
Please know I appreciate your help. I truly do. Just with this particular site, I don't have the freedom of taking things offline for any length of time.
Users browsing this forum: boocko, vingjfg and 42 guests
