Trekker0612
NAT to connect Modbus Server
Mon Mar 25, 2024 5:45 pm
Dear Users,
first of all I'm very new to MikroTik, so excuse upfront :-)
As I've an Huawei Inverter and it's known the Dongle which expose Modbus as well is not relyable I need to connect to the ModBus Server directly.
Following Setup:
ModBus Server - IP:192.168.200.1 Port: 6607 <-via WLAN DHCP-> MikroTik mAP lite <-> Ethernet via DHCP 192.168.2.4 <-> End Device: 192.168.20.0/26
What I've understand so far --- I need to create the NAT Rules (which I tried, but I cannot connect.
My config looks like this:
# mar/25/2024 16:39:31 by RouterOS 6.49.11
# software id = 4N5V-GH7C
# model = RBmAPL-2nD
# serial number = XXXXXX
add admin-mac=D4:01:C3:XX:XX:XX auto-mac=no comment=defconf name=bridge_lan
add name=bridge_wan
/interface pwr-line
set [ find default-name=pwr-line1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk mode=dynamic-keys name=huawei supplicant-identity="" wpa2-pre-shared-key=XXXXXXX
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=germany disabled=no distance=indoors frequency=2437 installation=indoor security-profile=huawei ssid=SUN2000-XXXXX wireless-protocol=802.11
add address-pool=default-dhcp disabled=no interface=bridge_lan name=defconf
add bridge=bridge_lan comment=defconf disabled=yes interface=pwr-line1
add bridge=bridge_wan interface=wlan1
add bridge=bridge_lan interface=LAN
add comment=defconf interface=bridge_lan list=LAN
add comment="defconf; to huawei" interface=wlan1 list=WAN
add interface=ether1 list=LAN
add interface=bridge_wan list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge_lan network=192.168.88.0
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add disabled=no interface=bridge_lan
add disabled=no interface=bridge_wan use-peer-dns=no use-peer-ntp=no
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=log chain=prerouting disabled=yes dst-port=6607 log=yes protocol=tcp
add action=src-nat chain=srcnat dst-address=192.168.200.1 dst-port=6607 protocol=tcp src-address=192.168.20.0/26 to-addresses=192.168.200.2
add action=src-nat chain=srcnat disabled=yes dst-address=192.168.200.1 dst-port=6607 protocol=tcp src-address=192.168.33.51 to-addresses=192.168.200.2
add action=dst-nat chain=dstnat dst-port=6607 in-interface=bridge_lan in-interface-list=LAN protocol=tcp src-address=192.168.20.0/26 to-addresses=192.168.200.1 to-ports=6607
add action=dst-nat chain=dstnat disabled=yes dst-port=6607 in-interface=bridge_lan in-interface-list=LAN protocol=tcp src-address=192.168.33.51 to-addresses=192.168.200.1 to-ports=6607
/ip service
set telnet disabled=yes
set winbox disabled=yes
/system clock
/tool mac-server
/tool mac-server mac-winbox
From MikroTik Router I'm able to ping the 192.168.200.1 device and telnet to port 6607 seems to react as well. Default ModBus Port 502 is closed -- which is fine.
Can someone tell me what I'm doing wrong with NAT that my request are no passed (forth and back). If you wander .. the srcnat rule is required (as I've seem in different other forums) to make the Huawei are that only the sender receives the answer.
Thx in advance
Users browsing this forum: PBondurant, webnoob and 21 guests
