Raf44
sniffing is crashing ?
Wed Mar 27, 2024 10:57 am
Hello everyone,
I've had to deal with a rather serious problem:
on a CCR1072 / RoS 7.14.1 router - BGP absorbing 2*full-table IPv4 + 2*full-table IPv6 for approximately 2Gbps of incoming traffic;
I wanted to try to trace a connection and thus to try a "tool/sniffer/quick..." by filtering only on the IP
after a few seconds of sniffing, the router rebooted itself via the watchdog.
Imagining that I'd been a bit too adventurous to run this command on this router, I then ran it again on its neighbour - which handles the same amount of traffic, but this time doesn't handle full-tables, and "only" has around 1000 to 1500 routes.
This neighbour is also a CCR1072 but in RoS 6.49.13.
The same command started to work, again for a few seconds, then rebooted by the watchdog...
So I have a simple question:
Is the amount of 2Gbps traffic really too much for this type of command to be executed?
I would have imagined that a CCR1072 could handle all that more easily...
Or am I focusing on the wrong problem, and probably missing something on the side?
The consequence of these crashes has been to make a big mess of our entire backbone for a few minutes, so I'm not going to be able to repeat the experience easily for testing purposes...
snowflake
Re: sniffing is crashing ?
Thu Apr 25, 2024 5:49 pm
Sniffer crashes here too.
Here's my model info
                   uptime: 1m6s
                  version: 7.14.3 (stable)
               build-time: 2024-04-17 12:47:58
              free-memory: 27.3MiB
             total-memory: 64.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 400MHz
                 cpu-load: 9%
           free-hdd-space: 48.1MiB
          total-hdd-space: 64.0MiB
  write-sect-since-reboot: 60
         write-sect-total: 11002727
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB751G-2HnD
                 platform: MikroTik
It's the first crash I've had since getting the Routerboard about 10 years ago.
Here's the sniffer configuration.
                    only-headers: no
                     memory-limit: 1000KiB
                    memory-scroll: yes
                        file-name:
                       file-limit: 1000KiB
                streaming-enabled: yes
                 streaming-server: 192.168.0.222:37008
                    filter-stream: yes
                 filter-interface: bridge-local
               filter-mac-address:
           filter-src-mac-address:
           filter-dst-mac-address:
              filter-mac-protocol:
                filter-ip-address:
            filter-src-ip-address:
            filter-dst-ip-address:
              filter-ipv6-address:
          filter-src-ipv6-address:
          filter-dst-ipv6-address:
               filter-ip-protocol: udp
                      filter-port: bootpc
                  filter-src-port:
                  filter-dst-port:
                      filter-vlan:
                       filter-cpu:
                      filter-size:
                 filter-direction: any
  filter-operator-between-entries: and
                          running: no
{/code]
Users browsing this forum: tikworx and 48 guests
