tiago15
hotspot captive portal landing page not pop up in ios devices
Wed Mar 27, 2024 10:58 am
HI, I have several hotspots working fine in android and windows, but I have issues with Ios apple devices, iphones and ipads. The problem is, the splash page is not showing up automatically in apple devices.
I have tried to create a file api.json and trying with dhcp server option 114. But not having luck. Could you help me in the correct configuration for hotspots and ios devices? I'm using v 6.49.10
Best regards
normis
Re: hotspot captive portal landing page not pop up in ios devices
Wed Mar 27, 2024 11:04 am
show your configuration
patrikg
Wed Mar 27, 2024 11:10 am
Have you read this:
normis recommend to upgrade
viewtopic.php?t=182708
tiago15
Wed Mar 27, 2024 12:02 pm
This is my config:
# mar/27/2024 10:52:45 by RouterOS 6.49.10
# software id = L7P8-PESJ
# model = 2011iL
# serial number =
/interface pptp-client
add connect-to= disabled=no name=pptp-out1 password=\
"" user=
add fast-forward=no mtu=1500 name=bridge1 protocol-mode=none
add fast-forward=no name=bridgeEoIP
set [ find default-name=ether1 ] name="ether1-Ba\F1osIzquierda" speed=100Mbps
set [ find default-name=ether2 ] name="ether2-Ba\F1osDerecha" speed=100Mbps
set [ find default-name=ether3 ] name=ether3-LKMultiSur speed=100Mbps
set [ find default-name=ether4 ] name=ether4-PowerStation5G speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=\
set [ find default-name=ether8 ] advertise=\
set [ find default-name=ether9 ] advertise=\
set [ find default-name=ether10 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
ether10-WAN poe-out=off
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether10-WAN \
keepalive-timeout=60 max-mru=1400 max-mtu=1400 name=pppoe-out1 password=\
econectia use-peer-dns=yes user=/interface l2tp-client
add connect-to= name=l2tp-out1 password=eConectia_l2tp user=\
add connect-to= disabled=no name=l2tp-out3 \
password= user=
/interface eoip
add allow-fast-path=no clamp-tcp-mss=no !keepalive local-address= \
mac-address=02:B1:43:36:89:13 mtu=1500 name=eoip-tunnel1 \
remote-address= tunnel-id=25
add exclude=dynamic name=discover
set [ find default=yes ] supplicant-identity=
/ip hotspot profile
add dns-name=azahar.info hotspot-address=10.5.50.1 html-directory=hotspot1 \
login-by=cookie,http-chap,https,http-pap name=hsprof1 \
radius-interim-update=1m use-radius=yes
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=hs-pool-13 ranges=10.5.48.1-10.5.50.0,10.5.50.2-10.5.51.254
add address-pool=hs-pool-13 authoritative=after-2sec-delay disabled=no \
interface=bridge1 lease-time=3h name=dhcp1
/ip hotspot
add address-pool=hs-pool-13 disabled=no interface=bridge1 name=hotspot1 \
profile=hsprof1
add comment="radius viejo 10.1.5.12" connect-to= name=l2tp-out2 \
password=econectia profile=default user=
/ip hotspot user profile
set [ find default=yes ] keepalive-timeout=10m queue-type=wireless-default \
shared-users=10
add name=MAC_1M/3M queue-type=wireless-default rate-limit=1M/3M \
transparent-proxy=yes
add name=MAC_2M/10M queue-type=wireless-default rate-limit=2M/10M \
shared-users=50 transparent-proxy=yes
add name="2M/10M - 2 shared user" queue-type=wireless-default rate-limit=\
2M/10M shared-users=2 transparent-proxy=yes
add name="2M/10M - 1 shared user" queue-type=wireless-default rate-limit=\
2M/10M transparent-proxy=yes
/queue tree
add max-limit=8M name=Queue_up parent=ether10-WAN queue=default
add name=queue1 packet-mark=Users-packet parent=Queue_up queue=\
pcq-upload-default
add max-limit=16M name=Queue_down parent=bridge1 queue=default
add name=queue2 packet-mark=Users-packet parent=Queue_down queue=\
pcq-download-default
/snmp community
add addresses=0.0.0.0/0 name
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add name=remoteOK remote=10.250.1.4 target=remote
/user group
add name=groupAPI policy="read,write,api,!local,!telnet,!ssh,!ftp,!reboot,!pol\
icy,!test,!winbox,!password,!web,!sniff,!sensitive,!romon,!dude,!tikapp"
add bridge=bridge1 hw=no interface="ether2-Ba\F1osDerecha"
add bridge=bridge1 hw=no interface=ether3-LKMultiSur
add bridge=bridge1 hw=no interface=ether4-PowerStation5G
add bridge=bridge1 hw=no interface=ether5
add bridge=bridge1 hw=no interface=ether6
add bridge=bridge1 hw=no interface=ether7
add bridge=bridge1 hw=no interface=ether8
add bridge=bridge1 hw=no interface=ether9
add bridge=bridge1 hw=no interface="ether1-Ba\F1osIzquierda"
add bridge=bridge1 interface=eoip-tunnel1-
set discover-interface-list=discover
/interface l2tp-server server
set enabled=yes
add interface="ether1-Ba\F1osIzquierda" list=discover
add interface="ether2-Ba\F1osDerecha" list=discover
add interface=ether3-LKMultiSur list=discover
add interface=ether4-PowerStation5G list=discover
add interface=ether5 list=discover
add interface=ether6 list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=pppoe-out1 list=discover
add interface=bridge1 list=discover
add interface=l2tp-out1 list=discover
add interface=eoip-tunnel1- list=discover
add address=10.5.50.1/22 interface=bridge1 network=10.5.48.0
add address=10.10.2.1/24 interface=bridge1 network=10.10.2.0
add address=10.250.1.5/24 disabled=yes interface=ether10-WAN network=\
10.250.1.0
add address=192.168.1.1/24 disabled=yes interface=bridge1 network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add add-default-route=no interface=bridge1 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=10.5.48.36 client-id=1:dc:9f:db:68:f2:7a mac-address=\
DC:9F:DB:68:F2:7A server=dhcp1
add address=10.5.48.0/22 comment="hotspot network" gateway=10.5.50.1
set servers=8.8.8.8,8.8.4.4
/ip dns static
add address=10.5.50.1 disabled=yes name=captive.apple.com/hotspot-detect.html
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="masquerade hotspot network " \
src-address=10.5.48.0/22 to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="Cliente cuota " \
src-address=10.10.2.100
add action=dst-nat chain=dstnat disabled=yes dst-port=1000 in-interface=\
pppoe-out1 protocol=tcp to-addresses=10.10.2.6 to-ports=80
add action=dst-nat chain=dstnat disabled=yes dst-port=5555 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.1.20 to-ports=443
add action=dst-nat chain=dstnat dst-port=5560 in-interface=pppoe-out1 \
protocol=tcp to-addresses=10.10.2.100 to-ports=443
add action=dst-nat chain=dstnat disabled=yes dst-port=5556 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.1.20 to-ports=80
/ip hotspot ip-binding
add address=10.10.2.0/24 type=bypassed
add address=192.168.1.0/24 disabled=yes type=bypassed
/ip hotspot user
add disabled=yes name=instaladores password=instaladores
add name=
add name=add name=
add comment="" name=08:3E:8E:C9:19:2B
add comment="" name=E0:F5:C6:3D:85:EF
add comment="" name=D8:96:95:8F:E7:68
add comment=borrar disabled=yes name=DC:9F:DB:6D:F8:B9
add comment=borrar disabled=yes name=DC:9F:DB:6D:F7:E1
add comment=borrar disabled=yes name=00:27:22:AE:AA:D9
add comment=borrar disabled=yes name=00:27:22:AC:4F:74
add comment=borrar disabled=yes name=00:50:B6:10:D1:F6
add comment=" disabled=yes name=D8:BB:2C:B3:B9:FD
add comment=" name=2C:F0:A2:68:3B:25 profile=MAC_1M/3M
add comment="usuario en caso de emergencia" disabled=yes name= \
password=azahar profile=MAC_2M/10M
add comment="usuario de emergencia" limit-uptime=3w name= password=\
add comment="usuario de emergencia 20-02-2023" limit-uptime=4w2d name=\
CA14276b password= profile="2M/10M - 2 shared user"
CA872046b password= profile="2M/10M - 1 shared user"
add comment="usuario de emergencia 14-03-2023" limit-uptime=1w name=CA500695b \
add comment="Usuario de emergencia 27-03-2023" name=CA766262 password= \
add name= password=profile="2M/10M - 2 shared user"
/ip proxy
set cache-path=web-proxy1 parent-proxy=0.0.0.0
add distance=1 dst-address=10.0.0.11/32 gateway=10.1.5.1
add distance=1 dst-address=192.168.10.0/24 gateway=10.1.6.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes port=81
set ssh port=
set api address=10.0.0.11/32
set winbox address= port=
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/ppp secret
add local-address=10.10.10.14 name=Azahar_eoip password=econectia \
remote-address=10.10.10.15 service=l2tp
/radius
add address=10.0.0.11 disabled=yes secret= service=\
hotspot timeout=2s
add address=disabled=yes secret=jf3a894huiw service=\
login,hotspot,dhcp timeout=3s
add address= disabled=yes secret=jf3a894huiw service=\
login,hotspot,dhcp
add address=127.0.0.1 disabled=yes secret=.crack06 service=\
login,hotspot,wireless
add address=10.0.0.1 secret=.crack06 service=ppp,hotspot timeout=3s
/radius incoming
set accept=yes port=1700
/snmp
set contact= enabled=yes location= trap-community=\
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Madrid
/system identity
set name=
/system logging
add action=remoteOK prefix= topics=critical
add action=remoteOK prefix=- topics=error
add action=remoteOK prefix=- topics=info
add action=remoteOK prefix=- topics=warning
/system ntp client
set enabled=yes primary-ntp=
/system package update
set channel=long-term
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
patrikg
Wed Mar 27, 2024 1:49 pm
Please posting config with the code tag.
[code]
Ending with
[/ code]
Without the space
normis
Wed Mar 27, 2024 1:53 pm
Did you disable Apple hotspot detection and then ask, why it is disabled?
/ip dns static
rule is disabled, but still. why even add it?
tiago15
Wed Mar 27, 2024 1:56 pm
I disabled it because the splash page in ios, didn't works although the dns entry was enabled. Do you suggest to enable it? or anything else?
normis
Wed Mar 27, 2024 1:57 pm
no, delete it!
tiago15
Wed Mar 27, 2024 1:59 pm
OK, deleted. And which more things I have to review or add for Ios devices?
Qanj72
Thu Apr 25, 2024 11:54 am
hello
I have a problem i configure Hotspot Captive portal but page not pop up in ios devices only please can you help me
and this is my configuration
add ingress-filtering=no name=bridge-trunk protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] comment=WAN
/interface vlan
add interface=bridge-trunk name=vlan10_CP vlan-id=10
add interface=bridge-trunk name=vlan30_Private vlan-id=30
add interface=ether1 name=vlan126_B2B_Management vlan-id=126
add interface=ether1 name=vlan127_B2B_Internet vlan-id=127
/caps-man datapath
add bridge=bridge-trunk client-to-client-forwarding=no comment="Hotspot Datapath" local-forwarding=no name=vlan10 vlan-id=10 vlan-mode=use-tag
add bridge=bridge-trunk client-to-client-forwarding=no comment="Private Customer Datapath" local-forwarding=no name=vlan30 vlan-id=30 vlan-mode=use-tag
/caps-man configuration
add channel.band=2ghz-b/g/n .control-channel-width=20mhz .tx-power=30 country=**ELIDED** datapath=vlan10 distance=dynamic installation=any mode=ap name=hotspot-vlan10 rates.basic=1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    .ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 .ht-supported-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 .supported=1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    .vht-basic-mcs="" ssid=**ELIDED**
add channel.band=2ghz-b/g/n .control-channel-width=20mhz .tx-power=30 country=**ELIDED** datapath=vlan30 distance=dynamic installation=any mode=ap name=private-vlan30 rates.basic=1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
/ip hotspot profile
add dns-name=**ELIDED** hotspot-address=192.168.150.1 http-cookie-lifetime=1d login-by=cookie,https name=hsprof1 ssl-certificate=**ELIDED**.crt use-radius=yes
add name=pool_portal ranges=192.168.150.5-192.168.151.254
add name=dhcp_pool1 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool2 ranges=192.168.160.2-192.168.160.254
add address-pool=pool_portal interface=vlan10_CP lease-time=2h name=dhcp-captive-portal
add address-pool=dhcp_pool1 interface=bridge-trunk lease-time=2h name=dhcp-management
add address-pool=dhcp_pool2 interface=vlan30_Private lease-time=2h name=dhcp-private-lan
/ip hotspot
add address-pool=pool_portal addresses-per-mac=1 disabled=no interface=vlan10_CP name=hotspot1 profile=hsprof1
/port
set 0 name=serial0
/queue type
set 0 pfifo-limit=5000
set 1 pfifo-limit=5000
set 9 pfifo-limit=1000
/caps-man manager
set ca-certificate=auto certificate=auto enabled=no
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=hotspot-vlan10 slave-configurations=private-vlan30
add bridge=bridge-trunk interface=ether2
add bridge=bridge-trunk interface=ether3
add bridge=bridge-trunk interface=ether4
add bridge=bridge-trunk interface=ether5
add bridge=bridge-trunk interface=ether6
add bridge=bridge-trunk interface=ether7
add bridge=bridge-trunk interface=ether8
/interface bridge vlan
add bridge=bridge-trunk tagged=ether2,ether3,ether4,ether5,ether6,ether7,ether8,bridge-trunk vlan-ids=10
add bridge=bridge-trunk tagged=bridge-trunk,ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=30
add interface=bridge-trunk list=LAN
add interface=ether1 list=WAN
add address=192.168.88.2/24 interface=ether2 network=192.168.88.0
add address=102.216.175.200/23 interface=vlan127_B2B_Internet network=102.216.174.0
add address=192.168.150.1/23 interface=vlan10_CP network=192.168.150.0
add address=192.168.20.1/24 interface=bridge-trunk network=192.168.20.0
add address=192.168.160.1/24 interface=vlan30_Private network=192.168.160.0
/ip dhcp-client
add add-default-route=no interface=vlan126_B2B_Management
add address=192.168.20.0/24 dns-server=10.100.4.2,10.100.4.10 gateway=192.168.20.1 netmask=24
add address=192.168.150.0/23 dns-server=10.100.4.2,10.100.4.10 gateway=192.168.150.1 netmask=23
add address=192.168.160.0/24 dns-server=10.100.4.2,10.100.4.10 gateway=192.168.160.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=1d cache-size=4096KiB servers=10.100.4.2,10.100.4.10
/ip dns static
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Allow already established & related connections" connection-state=established,related
add action=accept chain=forward comment="Allow access to router from known network"
add action=accept chain=forward comment="Allow acces to internal machines" dst-address-list=Internal_LAN
add action=drop chain=forward comment="Drop anything else"
add action=accept chain=input comment="Allow Established & related connections" connection-state=established,related
add action=accept chain=input comment="Allow access to router from known network" src-address=192.168.0.0/16
add action=accept chain=input comment="Allow remote ssh & WinBOX" dst-port=18291,32222,443 protocol=tcp src-address=10.100.0.0/16
add action=accept chain=input comment="Allow ping" protocol=icmp
add action=accept chain=input comment="Allow SNMP" dst-port=161 protocol=udp src-address=10.100.0.0/16
add action=accept chain=input comment="Allow pptp connections" disabled=yes dst-port=1723 protocol=tcp
add action=accept chain=input disabled=yes protocol=gre
add action=accept chain=input comment="Allow Web Acces" disabled=yes dst-port=80 protocol=tcp src-address=10.0.0.0/8
add action=drop chain=input comment="Drop anything else"
/ip firewall mangle
add action=mark-connection chain=prerouting comment="VOIP Traffic" connection-type=sip disabled=yes new-connection-mark=VOIP passthrough=yes
add action=mark-connection chain=prerouting comment="VOIP Traffic" disabled=yes dst-address-list=WM-VOIP dst-port=5060-5070,10000-20000 new-connection-mark=VOIP passthrough=yes protocol=udp
add action=set-priority chain=prerouting comment="VOIP Priority" connection-mark=VOIP disabled=yes new-priority=5 passthrough=no
add action=mark-connection chain=prerouting comment="Remaining Traffic" connection-mark=no-mark disabled=yes new-connection-mark=NO-VOIP passthrough=yes
add action=set-priority chain=prerouting comment="Remaining Traffic Priority" connection-mark=NO-VOIP disabled=yes new-priority=3 passthrough=no
add action=masquerade chain=srcnat comment=Private-LAN out-interface=vlan126_B2B_Management src-address=192.168.160.0/24
add action=masquerade chain=srcnat out-interface=vlan127_B2B_Internet src-address=192.168.160.0/24
add action=masquerade chain=srcnat comment=Hotspot-LAN out-interface=vlan126_B2B_Management src-address=192.168.150.0/23
add action=masquerade chain=srcnat out-interface=vlan127_B2B_Internet src-address=192.168.150.0/23
/ip firewall service-port
set tftp disabled=yes
set h323 disabled=yes
set pptp disabled=yes
/ip hotspot user
set [ find default=yes ] limit-bytes-total=65000000
/ip hotspot walled-garden
add dst-host=**ELIDED** server=hotspot1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=102.216.174.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10 vrf-interface=vlan126_B2B_Management
add disabled=no distance=1 dst-address=10.100.0.0/16 gateway=10.100.102.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10 vrf-interface=vlan126_B2B_Management
/ip service
set ssh address=162.213.64.0/24,162.213.65.0/24,10.100.102.1/32,162.213.66.0/24,162.213.67.0/24,185.132.90.0/24,185.41.96.0/24,185.41.97.0/24,185.41.98.0/24,185.41.99.0/24,45.15.136.0/24,145.224.66.0/24,102.216.172.1/32,41.223.183.25/32 port=32222
set www-ssl address=192.168.150.0/23,192.168.160.0/24 disabled=no
set api disabled=yes
set winbox address="162.213.64.0/24,162.213.65.0/24,162.213.66.0/24,162.213.67.0/24,185.132.90.0/24,185.41.96.0/24,185.41.97.0/24,185.41.98.0/24,185.41.99.0/24,45.15.136.0/24,145.224.66.0/24,102.216.172.1/32,41.223.183.25/32,10.100.10.1/32,192.168.200.0/24,10.100\
    .10.15/32,10.100.102.1/32" port=18291
/radius
add address=10.100.2.200 service=hotspot
/radius incoming
set accept=yes
/system clock
set time-zone-name=**ELIDED**
/system identity
set name=B2B-CP-NAME-FW
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
Reason: wrapped config in "code" block; elided location info, SSDs, etc
Users browsing this forum: No registered users and 48 guests
