menyarito
Hotspot-Radius server not responding
Thu Mar 28, 2024 6:41 pm
Hello Dears,
I tried with several topics already open on the Forum before writing here.
I have a L009UiGS-RM and Hostspot & user-manager is configured on it.
Everything seems to be ok only users connected via Hotspot do not disconnect after their time expires.
Attached my configuration.
Excuse me if my question is not very professional because I am new to Mikrotik.
Blessings
bpwl
Re: Hotspot-Radius server not responding
Thu Mar 28, 2024 9:22 pm
127.0. 0.1 is a loopback IP address that is reserved for the local host or computer or router.
NtRadPing is probably run on a laptop, not on the MT router.
127.0.0.1 would mean the laptops local RADIUS server, not User Manager on the MT router
For MT router check the firewall setting, to allow the Radius ports 1812 and 1813 as input.
(Some recent Ros versions have this as deafult (comment says it's for CAPsMAN, but it is all ports for 127.0.0.1), other don't have it yet!)
Time limit should come with RADIUS Accounting (1813), and timing set with RADIUS (User Manager) attributes.
menyarito
Fri Mar 29, 2024 2:15 am
Thank you bpwl for your answer.
I tested with (192.168.88.1) but I still have the same issue.
Yes it's run on my laptop, how to run it on MT router.
it's done (see attachment).
Blessings
bpwl
Fri Mar 29, 2024 11:57 pm
It is normally run on a laptop, not on the MT router
The laptop IP , when using NtRadPing, must be in the "Routers" list of User Manager, or all requests will be ignored. (routers = RADIUS clients list)
Idem for ALL MT routers that use RADIUS, must be in that list, even if it is the same router as the one with User Manager (127.0.0.1 is OK if that one is used as RADIUS SRC address)
menyarito
Re: Hotspot-Radius server not responding  [SOLVED]
Sat Mar 30, 2024 6:19 am
I reconfigured MT (L009UiGS-RM) without enabling the Radius and it works, users now log out automatically after their time expires.
Thank you so much bpwl
God bless you
menyarito
Sat Mar 30, 2024 10:56 pm
PS: I reconfigured MT with Mikhmon without enabling the Radius and it works, users now log out automatically after their time expires.
Regards
Users browsing this forum: Ahrefs [Bot] and 21 guests
