3eff
Virtualized VLANs (for Proxmox)
Thu Apr 04, 2024 9:31 pm
Hi everyone,
after resolving this issue viewtopic.php?t=206359 just wanted to know how to setup RouterOS 7 (without external switch) in order to have the following setup:
  • VLAN10, 192.168.10.0/24, for router and proxmox management
  • VLAN11, 192,168,11.0/24, for virtualized machines inside Proxmox nodes on VLAN10
I want to have a virtualized LAN in order to isolate "operative" infraestructure/LAN (VLAN11) inside the IT LAN (VLAN10).
Besides Proxmox and virtualized machines setup, what would be the correct configuration of tagget/untagged in the router. Now I have the following conf (only what I believe is important for VLAN conf) but only VLAN10 is working (internet, LAN connection), VLAN11 outside proxmox working ok, VLAN11 inside proxmox seems not to have network connectivity (inside and outside):
add name=aBridge port-cost-mode=short protocol-mode=none pvid=11 vlan-filtering=yes
/interface vlan
add interface=aBridge name=VLAN10 vlan-id=10
add interface=aBridge name=VLAN11 vlan-id=11
add name=WAN
add name=LAN
add name=VLAN10_POOL ranges=192.168.10.100-192.168.10.200
add name=VLAN11_POOL ranges=192.168.11.100-192.168.11.200
add address-pool=VLAN10_POOL interface=VLAN10 lease-time=10m name=VLAN10_DHCP
add address-pool=VLAN11_POOL interface=VLAN11 lease-time=10m name=VLAN11_DHCP
add bridge=aBridge frame-types=admit-only-untagged-and-priority-tagged interface=ether2 internal-path-cost=10 path-cost=10 pvid=10
add bridge=aBridge frame-types=admit-only-untagged-and-priority-tagged interface=ether3 internal-path-cost=10 path-cost=10 pvid=10
add bridge=aBridge frame-types=admit-only-untagged-and-priority-tagged interface=wlan1 internal-path-cost=10 path-cost=10 pvid=10
add bridge=aBridge frame-types=admit-only-untagged-and-priority-tagged interface=wlan2 internal-path-cost=10 path-cost=10 pvid=11
add bridge=aBridge frame-types=admit-only-untagged-and-priority-tagged interface=ether4 internal-path-cost=10 path-cost=10 pvid=11
add bridge=aBridge frame-types=admit-only-untagged-and-priority-tagged interface=ether5 internal-path-cost=10 path-cost=10 pvid=11
/interface bridge vlan
add bridge=3TSBridge tagged=3TSBridge vlan-ids=101
add bridge=3TSBridge tagged=3TSBridge vlan-ids=100
add interface=ether1 list=WAN
add interface=VLAN10 list=LAN
add interface=VLAN11 list=LAN
add address=192.168.10.1/24 interface=VLAN10 network=192.168.10.0
add address=192.168.11.1/24 interface=VLAN11 network=192.168.11.0
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
add address=192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1
set allow-remote-requests=yes
/ip firewall address-list
add address=192.168.10.0/24 list=LAN
add address=192.168.11.0/24 list=LAN
add action=accept chain=input comment="Accept established/related/untracked" connection-state=established,related,untracked
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input comment="Accept local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="Drop all not comming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="Accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="Accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="Fastrack for established/related" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Accept forwardig of established/related/untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="Drop all WAN not NATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="NAT out" ipsec-policy=out,none out-interface-list=WAN
Thanks in advance!
Juan Ignacio.
TheCat12
Re: Virtualized VLANs (for Proxmox)
Thu Apr 04, 2024 10:07 pm
Could you post a diagram of some sort because your configuration is a bit confusing
tdw
Fri Apr 05, 2024 12:22 am
The configuration doesn't make sense - you have name=aBridge in /interface bridge but references to bridge=3TSBridge in /interface bridge vlan.
Also, do not set the bridge-to-CPU PVID in /interface bridge to have the same ID as an /interface vlan attached to the bridge.
3eff
Fri Apr 05, 2024 12:43 am
Sure @theCat12!
Hope this diagram helps...
Right know, Proxmox (and its contained VMs) cannot access anything on 192.168.11.x/24 (just 192.168.11.2 that lives inside proxmox machine static IP).
@tdw, just a typo from playing with config: should be aBridge always, sorry. Sorry also for misunderstanding, which is the CPU PVID and where in the code I'm attaching it to de vlan attached to the bridge? (I believed it was CPU PVID was 0 for mikrotik)
Juan Ignacio,
loloski
Re: Virtualized VLANs (for Proxmox)  [SOLVED]
Fri Apr 05, 2024 1:09 am
You need a trunk port on both router and proxmox, this is how you are going to do it if your equipment is a CRS 3xx switch this is device specific , this is just a bare minimum and assume that your tagged port is ether1
[admin@RT] > export
# 2024-04-04 22:01:36 by RouterOS 7.15beta9
# software id =
add frame-types=admit-only-vlan-tagged name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=VLAN10 vlan-id=10
add interface=bridge name=VLAN11 vlan-id=11
add name=dhcp_pool0 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool1 ranges=192.168.11.2-192.168.11.254
/port
set 0 name=serial0
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1 pvid=4094
add bridge=bridge tagged=bridge,ether1 vlan-ids=10
add bridge=bridge tagged=bridge,ether1 vlan-ids=11
add address-pool=dhcp_pool0 interface=VLAN10 name=dhcp1
add address-pool=dhcp_pool1 interface=VLAN11 name=dhcp2
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.11.0/24 gateway=192.168.11.1
/system identity
set name=RT
/system note
set show-at-login=no
/tool romon
set enabled=yes
3eff
Fri Apr 05, 2024 1:40 am
Thanks @loloski,
I believed the solution was about trunk port, but did not know how to apply the the specific mikrotic implementation (tried randomly some changes related to tagged/untagged without success) I will try you solution in my scenario and then tell the about results!
Juan Ignacio.
[admin@RT] > export
# software id =
/interface vlan
/port
set 0 name=serial0
/system identity
set name=RT
/system note
/tool romon
set enabled=yes
loloski
Fri Apr 05, 2024 2:37 am
There are many ways how to make a VLAN in mikrotik, even if it works it doesn't mean it's correct because if you are doing that on non CRS 3xx series it will consume CPU, so be careful
3eff
Thu Apr 11, 2024 6:05 am
Thank you @loloski,
just played a little more with
on aBridge and the specific port to use Proxmox and its virtual machines.
Have a nice week! Juan Ignacio.
Users browsing this forum: Bing [Bot] and 18 guests
