I am interested in using a Mikrotik router to replace something like an Allen Bradley 1783-NATR device. I am familiar with doing one to one nat on Mikrotiks but the outside and inside interfaces have always had gateways on the mikrotik doing the natting. The Allen Bradley lets me take a layer two connection from an upstream router like a CIsco with a gateway of 10.10.10.1, assign 10.10.10.2 to the mikrotik, then nat things behind the mikrotik to 10.10.10.3-6. The devices behind the mikrotik on the inside have addresses from a network 192.168.1.0/24 that lives on the mikrotik. Here is the config:
add name=Bridge vlan-filtering=yes
/interface vlan
add comment=SCADA-INSIDE interface=Bridge name=vl66 vlan-id=66
add bridge=Bridge comment=SCADA-INSIDE interface=ether2 pvid=66
add bridge=Bridge comment=SCADA-INSIDE interface=ether3 pvid=66
add bridge=Bridge comment=SCADA-INSIDE interface=ether4 pvid=66
add bridge=Bridge comment=SCADA-INSIDE interface=ether5 pvid=66
add bridge=Bridge comment=SCADA-OUTSIDE disabled=yes interface=ether1
set discover-interface-list=all
/interface bridge vlan
add bridge=Bridge comment=SCADA-INSIDE tagged=Bridge untagged=ether2,ether3,ether5,ether4 vlan-ids=66
add address=192.168.1.254/24 comment=SCADA-INSIDE interface=vl66 network=192.168.1.0
add address=10.10.10.2/24 comment=SCADA-OUTSIDE interface=ether1 network=10.10.10.0
add action=accept chain=input
add action=accept chain=output
add action=accept chain=forward
add action=src-nat chain=srcnat out-interface=ether1 src-address=192.168.1.4 to-addresses=10.10.10.4
add action=dst-nat chain=dstnat dst-address=10.10.10.4 in-interface=ether1 to-addresses=192.168.1.4
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.1 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
I have a laptop plugged into port 2 with a static ip of 192.168.1.4 255.255.255.0 192.168.1.254 GW. From the upstream cisco router I am unable to ping 10.10.10.4 which should nat to my laptop at 192.168.1.4. Am I missing something in the nat statements? What about proxy arp?
