mayerhans
V 7.14.2 - firewall rules layout unusable
Fri Apr 12, 2024 12:34 am
Dear All,
I am using firmware 7.14.2 on routerboard model RB750Gr3 with firmware type mt7621L
Since that version the table with the firewall rules ( IPv4 and IPv6 ) is almost unusable because of a strange column width layout.
The third column (#) with the rule numbers is extremely wide, but the fourth column (Comment) is to too narrow.
I testet with Chrome and Firefox with the latest version. In both browsers the same behaviour.
Hopefully soon a fix in the next version.
Kind regards
Hans
patrikg
Re: V 7.14.2 - firewall rules layout unusable
Fri Apr 12, 2024 9:39 am
You can change the webfig behavior if you want, just click here:
Design skin
pimmie
Fri Apr 12, 2024 9:41 am
You should also be able to change the width of each column yourself? Hover with your mouse between two column headers, note that the mouse pointer turns into a double arrow and then drag left/right while holding the left mouse button to change the column width.
If that doesn't work maybe one of stylesheets or scripts got blocked by your browser for whatever reason? Or maybe try incognito mode to make sure it doesn't use a corrupted browser cache..
patrikg
Fri Apr 12, 2024 9:53 am
I have also seen this new thing in some of the settings menus.
There you can expand the view.
Maybe Mikrotik has forget to add these in some menus.
johnson73
Fri Apr 12, 2024 5:22 pm
Use Winbox and there will be no problems. https://mikrotik.com/download
mayerhans
Fri Apr 12, 2024 11:12 pm
Thanks to all for these hints.
I cleared the cache, it worked. But then the issue came back.
Working within an incognito window seems to be one solution.
// Hans
DarkNate
Sun Apr 14, 2024 7:04 pm
Who uses Webfig? Just use SSH or API in production and Winbox at home.
anav
Sun Apr 14, 2024 7:31 pm
One reason to use webconfig is to see memory leakage?
mayerhans
Thu Apr 18, 2024 3:56 pm
Also incognito window does not help. It looks ok when opening fresh but after a time the column width is destroyed.
Changing the design skin does not solve the issue too.
But this was not always so. It came with one of the last updates.
As it's annoying I hope for a fix with an upgrade.
// Hans
johnson73
Thu Apr 18, 2024 7:32 pm
You don't like winbox so much? Use it and you won't have any problems.
mayerhans
Sun Apr 21, 2024 3:48 pm
I can't say.
I am using a macbook with macOS. And winbox seems to be for MS.
Sorry.
// Hans
mayerhans
Re: V 7.14.3 - firewall rules layout unusable
Sun Apr 21, 2024 3:59 pm
I just upgraded to Version 7.14.3
But still the same issue.
// Hans
Users browsing this forum: CGGXANNX, glat, holvoetn, jaclaz, maigonis, milko, mkx and 55 guests
