Mikrotik firewall always starts with "Input" chain. When the last rule of the input chain, Drop=All ends, continues with the Forward chain.
Its order is important, the rules are followed from top to bottom, otherwise there will be no correct traffic operation.
Please copy the entire firewall section from beginning to end. (without sensitive information)
It seems that the problem will be in your traffic configuration.
/ip firewall address-list
add address=192.168.88.0/24 list=Admin
{Input Chain} +++++++
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input src-address-list=Admin comment="Config Access"
add action=accept chain=input comment=L2TP dst-port=500,1701,4500 \
in-interface-list=WAN protocol=udp
add action=accept chain=input comment="IKE IPSec" in-interface-list=WAN \
protocol=ipsec-esp
add action=drop chain=input comment="drop all else"
{forward chain} ++++++
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow dst-nat from both WAN and LAN (including port forwarding)" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
