I am attempting to get a Quectel EC25-AF LTE running on a Mikrotik Hex. The EC25-AF is connecting to the cellular network and everything works from it because I can ping from it to the Internet, but for some reason the MT router just says "connect failed" every few seconds when I enable the LTE1 interface. Can someone advise based on these logs what might be happening? I have factory reset the EC25-AF and factory reset the MT several times but still get the same results. I am on the latest stable V7 RouterOS and also upgraded the MT firmware.
The router is booting up at 16:05 with the lte1 interface disabled and I enable the lte1 interface at 16:17.
# 2024-04-13 16:18:26 by RouterOS 7.14.2
# software id = RZEN-594S
16:05:14 system,info router rebooted
16:05:15 interface,info lo link up
16:05:24 bridge,info hardware offloading activated on bridge "bridge" ports: ether3,ether2,ether4,ether5
16:05:27 interface,info ether3 link up (speed 100M, full duplex)
16:05:28 lte,async lte1: sent AT E0 V1
16:05:28 lte,async lte1: rcvd OK
16:05:28 lte,async lte1: sent AT+CMEE=2
16:05:28 lte,debug lte1 mbim: state 0=>1
16:05:28 lte,debug lte1 mbim: wdm max tx 4096
16:05:28 lte,debug lte1 mbim: <<< open
16:05:28 lte,packet,raw lte1 mbim: wdm <<< send #1
16:05:28 lte,packet,raw lte1 mbim: 01000000 10000000 01000000 00100000
16:05:28 lte,async lte1: sent AT+CGREG=2
16:05:28 lte,async lte1: sent AT+CEREG=2
16:05:28 lte,packet,raw lte1 mbim: wdm >>> recv #1
16:05:28 lte,packet,raw lte1 mbim: 01000080 10000000 01000000 00000000
16:05:28 lte,debug lte1 mbim: open done, status: 0
16:05:28 lte,debug lte1 mbim: state 1=>2
16:05:28 lte,debug lte1 mbim: set radio: off
16:05:28 lte,debug lte1 mbim: <<< S - connect: radio state
16:05:28 lte,packet,raw lte1 mbim: wdm <<< send #2
16:05:28 lte,packet,raw lte1 mbim: 03000000 34000000 02000000 01000000
16:05:28 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:05:28 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:05:28 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:05:28 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:05:28 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:05:28 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:05:28 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:05:28 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:05:28 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:05:28 lte,debug lte1 mbim: >>> N - sms: configuration
16:05:28 lte,packet lte1 mbim: status data:
16:05:28 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:05:28 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:05:28 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:05:28 lte,debug lte1 mbim: sms service center +12063130004
16:05:30 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:05:30 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:05:30 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:05:30 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:05:30 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:05:31 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:05:31 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000
16:05:31 lte,debug lte1 mbim: >>> N - connect: packet service
16:05:31 lte,packet lte1 mbim: status data:
16:05:31 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:05:31 lte,packet lte1 mbim: 00000000 00000000 00000000
16:05:31 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:05:31 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:05:31 lte,debug lte1 mbim: >>> N - connect: register state
16:05:31 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:05:31 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:05:31 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:05:31 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:05:31 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:05:31 lte,async,raw lte1: +CGREG: 0
16:05:31 lte,async,raw lte1: +CEREG: 0
16:05:31 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:05:31 lte,debug lte1 mbim: >>> N - connect: radio state
16:05:31 lte,packet,raw lte1 mbim: wdm >>> recv #2
16:05:31 lte,packet,raw lte1 mbim: 03000080 38000000 02000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:05:31 lte,packet,raw lte1 mbim: 01000000 00000000
16:05:31 lte,debug lte1 mbim: >>> D - connect: radio state
16:05:31 lte,debug lte1 mbim: state 2=>6
16:05:31 lte,debug lte1 mbim: <<< Q - connect: device services
16:05:31 lte,packet,raw lte1 mbim: wdm <<< send #3
16:05:31 lte,packet,raw lte1 mbim: 03000000 30000000 03000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 10000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:05:31 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:05:31 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:05:31 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:05:31 lte,debug lte1 mbim: >>> N - sms: configuration
16:05:31 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:05:31 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:05:31 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:05:31 lte,debug lte1 mbim: sms service center +12063130004
16:05:31 lte,packet,raw lte1 mbim: wdm >>> recv #3
16:05:31 lte,packet,raw lte1 mbim: 03000080 bc020000 03000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 10000000 00000000 8c020000
16:05:31 lte,packet,raw lte1 mbim: 0c000000 00000000 68000000 6c000000
16:05:31 lte,packet,raw lte1 mbim: d4000000 30000000 04010000 20000000
16:05:31 lte,packet,raw lte1 mbim: 24010000 2c000000 50010000 28000000
16:05:31 lte,packet,raw lte1 mbim: 78010000 24000000 9c010000 20000000
16:05:31 lte,packet,raw lte1 mbim: bc010000 24000000 e0010000 20000000
16:05:31 lte,packet,raw lte1 mbim: 00020000 34000000 34020000 28000000
16:05:31 lte,packet,raw lte1 mbim: 5c020000 30000000 a289cc33 bcbb8b4f
16:05:31 lte,packet,raw lte1 mbim: b6b0133e c2aae6df 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 14000000 01000000 02000000 03000000
16:05:31 lte,packet,raw lte1 mbim: 04000000 05000000 06000000 07000000
16:05:31 lte,packet,raw lte1 mbim: 08000000 09000000 0a000000 0b000000
16:05:31 lte,packet,raw lte1 mbim: 0c000000 0d000000 0f000000 10000000
16:05:31 lte,packet,raw lte1 mbim: 13000000 14000000 15000000 16000000
16:05:31 lte,packet,raw lte1 mbim: 17000000 533fbeeb 14fe4467 9f9033a2
16:05:31 lte,packet,raw lte1 mbim: 23e56c3f 00000000 00000000 05000000
16:05:31 lte,packet,raw lte1 mbim: 01000000 02000000 03000000 04000000
16:05:31 lte,packet,raw lte1 mbim: 05000000 e550a0c8 5e82479e 82f710ab
16:05:31 lte,packet,raw lte1 mbim: f4c3351f 00000000 00000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 01000000 4bf38476 1e6a41db b1d8bed2
16:05:31 lte,packet,raw lte1 mbim: 89c25bdb 00000000 00000000 04000000
16:05:31 lte,packet,raw lte1 mbim: d8f20131 fcb54e17 8602d6ed 3816164c
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 03000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 02000000 03000000 1d2b5ff7 0aa148b2
16:05:31 lte,packet,raw lte1 mbim: aa5250f1 5767174e 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 02000000 01000000 03000000 883b7c26
16:05:31 lte,packet,raw lte1 mbim: 985f43fa 980427d7 fb80959c 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 2d0c12c9
16:05:31 lte,packet,raw lte1 mbim: 0e6a495a 915c8d17 4fe5d63c 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 02000000 01000000 02000000
16:05:31 lte,packet,raw lte1 mbim: e9f7dea2 feaf4009 93ce90a3 694103b6
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 01000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 5967bdcc 7fd249a2 9f5cb2e7 0e527db3
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 06000000 01000000
16:05:31 lte,packet,raw lte1 mbim: 02000000 03000000 04000000 09000000
16:05:31 lte,packet,raw lte1 mbim: 0a000000 6427015f 579d48f5 8c54f43e
16:05:31 lte,packet,raw lte1 mbim: d1e76f83 00000000 00000000 03000000
16:05:31 lte,packet,raw lte1 mbim: 01000000 02000000 03000000 c2f6588e
16:05:31 lte,packet,raw lte1 mbim: f0374bc9 8665f4d4 4bd09367 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 05000000 01000000 02000000
16:05:31 lte,packet,raw lte1 mbim: 03000000 04000000 05000000
16:05:31 lte,debug lte1 mbim: >>> D - connect: device services
16:05:31 lte,packet lte1 mbim: 0c000000 00000000 68000000 6c000000
16:05:31 lte,packet lte1 mbim: d4000000 30000000 04010000 20000000
16:05:31 lte,packet lte1 mbim: 24010000 2c000000 50010000 28000000
16:05:31 lte,packet lte1 mbim: 78010000 24000000 9c010000 20000000
16:05:31 lte,packet lte1 mbim: bc010000 24000000 e0010000 20000000
16:05:31 lte,packet lte1 mbim: 00020000 34000000 34020000 28000000
16:05:31 lte,packet lte1 mbim: 5c020000 30000000 a289cc33 bcbb8b4f
16:05:31 lte,packet lte1 mbim: b6b0133e c2aae6df 00000000 00000000
16:05:31 lte,packet lte1 mbim: 14000000 01000000 02000000 03000000
16:05:31 lte,packet lte1 mbim: 04000000 05000000 06000000 07000000
16:05:31 lte,packet lte1 mbim: 08000000 09000000 0a000000 0b000000
16:05:31 lte,packet lte1 mbim: 0c000000 0d000000 0f000000 10000000
16:05:31 lte,packet lte1 mbim: 13000000 14000000 15000000 16000000
16:05:31 lte,packet lte1 mbim: 17000000 533fbeeb 14fe4467 9f9033a2
16:05:31 lte,packet lte1 mbim: 23e56c3f 00000000 00000000 05000000
16:05:31 lte,packet lte1 mbim: 01000000 02000000 03000000 04000000
16:05:31 lte,packet
16:05:31 lte,packet lte1 mbim: 05000000 e550a0c8 5e82479e 82f710ab
16:05:31 lte,packet lte1 mbim: f4c3351f 00000000 00000000 01000000
16:05:31 lte,packet lte1 mbim: 01000000 4bf38476 1e6a41db b1d8bed2
16:05:31 lte,packet lte1 mbim: 89c25bdb 00000000 00000000 04000000
16:05:31 lte,packet lte1 mbim: d8f20131 fcb54e17 8602d6ed 3816164c
16:05:31 lte,packet lte1 mbim: 00000000 00000000 03000000 01000000
16:05:31 lte,packet lte1 mbim: 02000000 03000000 1d2b5ff7 0aa148b2
16:05:31 lte,packet lte1 mbim: aa5250f1 5767174e 00000000 00000000
16:05:31 lte,packet lte1 mbim: 02000000 01000000 03000000 883b7c26
16:05:31 lte,packet lte1 mbim: 985f43fa 980427d7 fb80959c 00000000
16:05:31 lte,packet lte1 mbim: 00000000 01000000 01000000 2d0c12c9
16:05:31 lte,packet lte1 mbim: 0e6a495a 915c8d17 4fe5d63c 00000000
16:05:31 lte,packet lte1 mbim: 00000000 02000000 01000000 02000000
16:05:31 lte,packet lte1 mbim: e9f7dea2 feaf4009 93ce90a3 694103b6
16:05:31 lte,packet lte1 mbim: 00000000 00000000 01000000 01000000
16:05:31 lte,packet
16:05:31 lte,packet lte1 mbim: 5967bdcc 7fd249a2 9f5cb2e7 0e527db3
16:05:31 lte,packet lte1 mbim: 00000000 00000000 06000000 01000000
16:05:31 lte,packet lte1 mbim: 02000000 03000000 04000000 09000000
16:05:31 lte,packet lte1 mbim: 0a000000 6427015f 579d48f5 8c54f43e
16:05:31 lte,packet lte1 mbim: d1e76f83 00000000 00000000 03000000
16:05:31 lte,packet lte1 mbim: 01000000 02000000 03000000 c2f6588e
16:05:31 lte,packet lte1 mbim: f0374bc9 8665f4d4 4bd09367 00000000
16:05:31 lte,packet lte1 mbim: 00000000 05000000 01000000 02000000
16:05:31 lte,packet lte1 mbim: 03000000 04000000 05000000
16:05:31 lte,debug lte1 mbim: device service: a289cc33bcbb8b4fb6b0133ec2aae6df commands 20: 1,2,3,4,5,6,7,8,9,10,11..
16:05:31 lte,debug lte1 mbim: device service: 533fbeeb14fe44679f9033a223e56c3f commands 5: 1,2,3,4,5
16:05:31 lte,debug lte1 mbim: device service: e550a0c85e82479e82f710abf4c3351f commands 1: 1
16:05:31 lte,debug lte1 mbim: device service: 4bf384761e6a41dbb1d8bed289c25bdb commands 4: 1,2,3,4
16:05:31 lte,debug lte1 mbim: device service: d8f20131fcb54e178602d6ed3816164c commands 3: 1,2,3
16:05:31 lte,debug lte1 mbim: device service: 1d2b5ff70aa148b2aa5250f15767174e commands 2: 1,3
16:05:31 lte,debug lte1 mbim: device service: 883b7c26985f43fa980427d7fb80959c commands 1: 1
16:05:31 lte,debug lte1 mbim: device service: 2d0c12c90e6a495a915c8d174fe5d63c commands 2: 1,2
16:05:31 lte,debug lte1 mbim: device service: e9f7dea2feaf400993ce90a3694103b6 commands 1: 1
16:05:31 lte,debug lte1 mbim: device service: 5967bdcc7fd249a29f5cb2e70e527db3 commands 6: 1,2,3,4,9,10
16:05:31 lte,debug lte1 mbim: device service: 6427015f579d48f58c54f43ed1e76f83 commands 3: 1,2,3
16:05:31 lte,debug lte1 mbim: device service: c2f6588ef0374bc98665f4d44bd09367 commands 5: 1,2,3,4,5
16:05:31 lte,debug lte1 mbim: <<< Q - connect: device caps
16:05:31 lte,packet,raw lte1 mbim: wdm <<< send #4
16:05:31 lte,packet,raw lte1 mbim: 03000000 30000000 04000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 01000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: wdm >>> recv #4
16:05:31 lte,packet,raw lte1 mbim: 03000080 f0000000 04000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 01000000 00000000 c0000000
16:05:31 lte,packet,raw lte1 mbim: 03000000 01000000 01000000 02000000
16:05:31 lte,packet,raw lte1 mbim: 3c000000 03000000 01000000 08000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 40000000 1e000000
16:05:31 lte,packet,raw lte1 mbim: 60000000 22000000 84000000 3c000000
16:05:31 lte,packet,raw lte1 mbim: 38003600 34003800 33003900 30003400
16:05:31 lte,packet,raw lte1 mbim: 31003100 39003500 32003100 31000000
16:05:31 lte,packet,raw lte1 mbim: 45004300 32003500 41004600 46004100
16:05:31 lte,packet,raw lte1 mbim: 52003000 37004100 31003400 4d003400
16:05:31 lte,packet,raw lte1 mbim: 47000000 51005500 45004300 54004500
16:05:31 lte,packet,raw lte1 mbim: 4c002000 4d006f00 62006900 6c006500
16:05:31 lte,packet,raw lte1 mbim: 20004200 72006f00 61006400 62006100
16:05:31 lte,packet,raw lte1 mbim: 6e006400 20004d00 6f006400 75006c00
16:05:31 lte,debug lte1 mbim: >>> D - connect: device caps
16:05:31 lte,packet lte1 mbim: 03000000 01000000 01000000 02000000
16:05:31 lte,packet lte1 mbim: 3c000000 03000000 01000000 08000000
16:05:31 lte,packet lte1 mbim: 00000000 00000000 40000000 1e000000
16:05:31 lte,packet lte1 mbim: 60000000 22000000 84000000 3c000000
16:05:31 lte,packet lte1 mbim: 38003600 34003800 33003900 30003400
16:05:31 lte,packet lte1 mbim: 31003100 39003500 32003100 31000000
16:05:31 lte,packet lte1 mbim: 45004300 32003500 41004600 46004100
16:05:31 lte,packet lte1 mbim: 52003000 37004100 31003400 4d003400
16:05:31 lte,packet lte1 mbim: 47000000 51005500 45004300 54004500
16:05:31 lte,packet lte1 mbim: 4c002000 4d006f00 62006900 6c006500
16:05:31 lte,packet lte1 mbim: 20004200 72006f00 61006400 62006100
16:05:31 lte,packet lte1 mbim: 6e006400 20004d00 6f006400 75006c00
16:05:31 lte,debug lte1 mbim: device caps: cls:3c sms:3 sim:removable ctr:1 max_sess:8
16:05:31 lte,debug lte1 mbim: <<< Q - connect: provisioned contexts
16:05:31 lte,packet,raw lte1 mbim: wdm <<< send #5
16:05:31 lte,packet,raw lte1 mbim: 03000000 30000000 05000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 0d000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: wdm >>> recv #5
16:05:31 lte,packet,raw lte1 mbim: 03000080 50010000 05000000 01000000
16:05:31 lte,packet,raw lte1 mbim: c2aae6df 0d000000 00000000 20010000
16:05:31 lte,packet,raw lte1 mbim: 04000000 24000000 48000000 6c000000
16:05:31 lte,packet,raw lte1 mbim: 3c000000 a8000000 3c000000 e4000000
16:05:31 lte,packet,raw lte1 mbim: 3c000000 01000000 b43f758c a5604b46
16:05:31 lte,packet,raw lte1 mbim: b35ec586 9641fb54 34000000 12000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 4d006f00 62006900
16:05:31 lte,packet,raw lte1 mbim: 6c006500 6e006500 74000000 02000000
16:05:31 lte,packet,raw lte1 mbim: b43f758c a5604b46 b35ec586 9641fb54
16:05:31 lte,packet,raw lte1 mbim: 34000000 06000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 69006d00 73000000 03000000 b43f758c
16:05:31 lte,packet,raw lte1 mbim: a5604b46 b35ec586 9641fb54 34000000
16:05:31 lte,packet,raw lte1 mbim: 06000000 00000000 00000000 00000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 73006f00
16:05:31 lte,packet,raw lte1 mbim: 73000000 04000000 b43f758c a5604b46
16:05:31 lte,packet,raw lte1 mbim: b35ec586 9641fb54 34000000 08000000
16:05:31 lte,packet,raw lte1 mbim: 00000000 00000000 74006d00 75007300
16:05:31 lte,debug lte1 mbim: >>> D - connect: provisioned contexts
16:05:31 lte,packet lte1 mbim: 04000000 24000000 48000000 6c000000
16:05:31 lte,packet lte1 mbim: 3c000000 a8000000 3c000000 e4000000
16:05:31 lte,packet lte1 mbim: 3c000000 01000000 b43f758c a5604b46
16:05:31 lte,packet lte1 mbim: b35ec586 9641fb54 34000000 12000000
16:05:31 lte,packet lte1 mbim: 00000000 00000000 00000000 00000000
16:05:31 lte,packet lte1 mbim: 00000000 00000000 4d006f00 62006900
16:05:31 lte,packet lte1 mbim: 6c006500 6e006500 74000000 02000000
16:05:31 lte,packet lte1 mbim: b43f758c a5604b46 b35ec586 9641fb54
16:05:31 lte,packet lte1 mbim: 34000000 06000000 00000000 00000000
16:05:31 lte,packet lte1 mbim: 69006d00 73000000 03000000 b43f758c
16:05:31 lte,packet lte1 mbim: a5604b46 b35ec586 9641fb54 34000000
16:05:31 lte,packet lte1 mbim: 06000000 00000000 00000000 00000000
16:05:31 lte,packet lte1 mbim: 00000000 00000000 00000000 73006f00
16:05:31 lte,packet lte1 mbim: 73000000 04000000 b43f758c a5604b46
16:05:31 lte,packet lte1 mbim: b35ec586 9641fb54 34000000 08000000
16:05:31 lte,packet
16:05:31 lte,packet lte1 mbim: 00000000 00000000 74006d00 75007300
16:05:31 lte,debug lte1 mbim: provisioned ctx: 1, type: none, apn: Mobilenet
16:05:31 lte,debug lte1 mbim: provisioned ctx: 2, type: none, apn: ims
16:05:31 lte,debug lte1 mbim: provisioned ctx: 3, type: none, apn: sos
16:05:31 lte,debug lte1 mbim: provisioned ctx: 4, type: none, apn: tmus
16:05:31 lte,debug lte1 mbim: state 6=>3
16:05:31 lte,debug lte1 mbim: state 3=>6
16:05:42 lte,async lte1: sent AT E0 V1
16:05:42 lte,async lte1: rcvd OK
16:05:53 lte,async lte1: sent AT E0 V1
16:05:53 lte,async lte1: rcvd OK
16:17:21 lte,async,raw lte1: sent AT+QENG="servingcell"
16:17:21 lte,debug lte1 mbim: state 6=>7
16:17:21 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:21 lte,packet,raw lte1 mbim: wdm <<< send #6
16:17:21 lte,packet,raw lte1 mbim: 03000000 30000000 06000000 01000000
16:17:21 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:21 lte,async,raw lte1: rcvd +QENG: "servingcell","SEARCH"
16:17:21 lte,async,raw lte1: sent AT+CSQ
16:17:21 lte,async,raw lte1: rcvd +CSQ: 99,99
16:17:21 lte,packet,raw lte1 mbim: wdm >>> recv #6
16:17:21 lte,packet,raw lte1 mbim: 03000080 b4000000 06000000 01000000
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:21 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:21 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:21 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:21 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:21 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:21 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:21 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:21 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:21 lte,packet,raw lte1 mbim: 30004600
16:17:21 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:21 lte,packet lte1 mbim: status data:
16:17:21 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:21 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:21 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:21 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:21 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:21 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:21 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:21 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:21 lte,packet lte1 mbim: 30004600
16:17:21 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:21 lte,async lte1: sent AT+QCFG="ims"
16:17:21 lte,debug lte1 mbim: state 7=>10
16:17:21 lte,debug lte1 mbim: request register, operator: [auto]
16:17:21 lte,debug lte1 mbim: <<< S - connect: register state
16:17:21 lte,packet,raw lte1 mbim: wdm <<< send #7
16:17:21 lte,packet,raw lte1 mbim: 03000000 40000000 07000000 01000000
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:21 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:21 lte,packet,raw lte1 mbim: wdm >>> recv #7
16:17:21 lte,packet,raw lte1 mbim: 03000080 60000000 07000000 01000000
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:21 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:21 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:21 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:21 lte,debug lte1 mbim: >>> D - connect: register state
16:17:21 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:21 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:21 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:21 lte,debug lte1 mbim: register state: deregistered
16:17:21 lte,debug lte1 mbim: state 10=>11
16:17:21 lte,debug lte1 mbim: set radio: on
16:17:21 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:21 lte,packet,raw lte1 mbim: wdm <<< send #8
16:17:21 lte,packet,raw lte1 mbim: 03000000 34000000 08000000 01000000
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:21 lte,async lte1: rcvd +QCFG: "ims",0,0
16:17:21 lte,async lte1: sent AT+CGEREP=2,0
16:17:21 lte,async lte1: rcvd OK
16:17:21 lte,async lte1: sent AT+CMGF=0
16:17:21 lte,async lte1: sent AT+CNMI=1,1,0,1,0
16:17:21 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:21 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:21 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:21 lte,packet lte1 mbim: 01000000 01000000
16:17:21 lte,packet,raw lte1 mbim: wdm >>> recv #8
16:17:21 lte,packet,raw lte1 mbim: 03000080 38000000 08000000 01000000
16:17:21 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:21 lte,packet,raw lte1 mbim: 01000000 01000000
16:17:21 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:22 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:22 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:22 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:22 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:22 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:22 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:22 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:22 lte,debug lte1 mbim: >>> N - connect: register state
16:17:22 lte,packet lte1 mbim: status data:
16:17:22 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:22 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:22 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:22 lte,debug lte1 mbim: register state: searching
16:17:22 lte,debug lte1 mbim: state 11=>12
16:17:22 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:22 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:22 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:22 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:22 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:22 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:22 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:22 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:22 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:22 lte,debug lte1 mbim: sms service center +12063130004
16:17:22 system,info device changed by tcp-msg(winbox):admin@192.168.88.254 (/interface set lte1 disabled=no mtu=1500 name=lte1; /interface lte set [ find ] allow-roaming=no apn-profiles=default band="" disabled=no mtu=1500 name=lte1 network-mode=lte nr-band=""; /queue interface set lte1)
16:17:23 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:23 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:23 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:23 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 05000000
16:17:23 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:23 lte,packet,raw lte1 mbim: 07000080 78000000 00000000 01000000
16:17:23 lte,packet,raw lte1 mbim: c2aae6df 09000000 4c000000 00000000
16:17:23 lte,packet,raw lte1 mbim: 03000000 01000000 20000000 01000000
16:17:23 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 10000000
16:17:23 lte,packet,raw lte1 mbim: 00000000 00000000 02000000 33003100
16:17:23 lte,packet,raw lte1 mbim: 30003200 36003000 54002d00 4d006f00
16:17:23 lte,packet,raw lte1 mbim: 62006900 6c006500
16:17:23 lte,debug lte1 mbim: >>> N - connect: register state
16:17:23 lte,packet lte1 mbim: status data:
16:17:23 lte,packet lte1 mbim: 00000000 03000000 01000000 20000000
16:17:23 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
16:17:23 lte,packet lte1 mbim: 10000000 00000000 00000000 02000000
16:17:23 lte,packet lte1 mbim: 33003100 30003200 36003000 54002d00
16:17:23 lte,packet lte1 mbim: 4d006f00 62006900 6c006500
16:17:23 lte,debug lte1 mbim: register state: home, gsm operator: 310260, T-Mobile, avail data classes: 0x20
16:17:23 lte,debug lte1 mbim: state 12=>14
16:17:23 lte,debug lte1 mbim: waiting for auto attach
16:17:23 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:23 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:23 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:23 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:23 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:23 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:23 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:23 lte,debug lte1 mbim: state 14=>16
16:17:24 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:24 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:24 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:24 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:24 lte,packet,raw lte1 mbim: 02000000 20000000 80f0fa02 00000000
16:17:24 lte,packet,raw lte1 mbim: 00e1f505 00000000
16:17:24 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:24 lte,packet lte1 mbim: status data:
16:17:24 lte,packet lte1 mbim: 00000000 02000000 20000000 80f0fa02
16:17:24 lte,packet lte1 mbim: 00000000 00e1f505 00000000
16:17:24 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
16:17:24 lte,debug lte1 mbim: state 16=>17
16:17:25 lte,debug lte1 mbim: do connect activate #0
16:17:25 lte,debug lte1 mbim: apn: Mobilenet iptype: 0
16:17:25 lte,debug lte1 mbim: <<< S - connect: connect
16:17:25 lte,packet,raw lte1 mbim: wdm <<< send #9
16:17:25 lte,packet,raw lte1 mbim: 03000000 80000000 09000000 01000000
16:17:25 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:25 lte,packet,raw lte1 mbim: c2aae6df 0c000000 01000000 50000000
16:17:25 lte,packet,raw lte1 mbim: 00000000 01000000 3c000000 12000000
16:17:25 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:25 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 7e5e2a7e
16:17:25 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 4d006f00
16:17:25 lte,packet,raw lte1 mbim: 62006900 6c006500 6e006500 74000000
16:17:25 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:25 lte,packet,raw lte1 mbim: 07000080 50000000 00000000 01000000
16:17:25 lte,packet,raw lte1 mbim: c2aae6df 0c000000 24000000 00000000
16:17:25 lte,packet,raw lte1 mbim: 02000000 00000000 01000000 7e5e2a7e
16:17:25 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 00000000
16:17:25 lte,debug lte1 mbim: >>> N - connect: connect
16:17:25 lte,packet lte1 mbim: status data:
16:17:25 lte,packet lte1 mbim: 00000000 02000000 00000000 01000000
16:17:25 lte,packet lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:25 lte,debug lte1 mbim: connect: #0 activating, nwe:
16:17:25 lte,debug lte1 mbim: waiting for done
16:17:25 lte,packet,raw lte1 mbim: wdm >>> recv #9
16:17:25 lte,packet,raw lte1 mbim: 03000080 54000000 09000000 01000000
16:17:25 lte,packet,raw lte1 mbim: c2aae6df 0c000000 02000000 24000000
16:17:25 lte,packet,raw lte1 mbim: 00000000 03000000 00000000 00000000
16:17:25 lte,packet,raw lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:25 lte,debug lte1 mbim: >>> E - connect: connect, error: FAILURE
16:17:25 lte,packet lte1 mbim: 00000000 03000000 00000000 00000000
16:17:25 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
16:17:26 lte,debug lte1 mbim: all bearers failed, restarting
16:17:26 lte,debug lte1 mbim: state 17=>5
16:17:26 lte,debug lte1 mbim: set radio: off
16:17:26 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:26 lte,packet,raw lte1 mbim: wdm <<< send #10
16:17:26 lte,packet,raw lte1 mbim: 03000000 34000000 0a000000 01000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:26 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:26 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 03000000
16:17:26 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:17:26 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:26 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:26 lte,packet lte1 mbim: status data:
16:17:26 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:17:26 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:26 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:17:26 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:26 lte,debug lte1 mbim: >>> N - connect: register state
16:17:26 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:26 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:26 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:26 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:26 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:26 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:26 lte,packet,raw lte1 mbim: wdm >>> recv #10
16:17:26 lte,packet,raw lte1 mbim: 03000080 38000000 0a000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:26 lte,packet,raw lte1 mbim: 01000000 00000000
16:17:26 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:26 lte,debug lte1 mbim: state 5=>6
16:17:26 lte,debug lte1 mbim: state 6=>7
16:17:26 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:26 lte,packet,raw lte1 mbim: wdm <<< send #11
16:17:26 lte,packet,raw lte1 mbim: 03000000 30000000 0b000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:26 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:26 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:26 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:26 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:26 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:26 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:26 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:26 lte,debug lte1 mbim: sms service center +12063130004
16:17:26 lte,packet,raw lte1 mbim: wdm >>> recv #11
16:17:26 lte,packet,raw lte1 mbim: 03000080 b4000000 0b000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:26 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:26 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:26 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:26 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:26 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:26 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:26 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:26 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:26 lte,packet,raw lte1 mbim: 30004600
16:17:26 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:26 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:26 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:26 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:26 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:26 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:26 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:26 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:26 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:26 lte,packet lte1 mbim: 30004600
16:17:26 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:26 lte,debug lte1 mbim: state 7=>10
16:17:26 lte,debug lte1 mbim: request register, operator: [auto]
16:17:26 lte,debug lte1 mbim: <<< S - connect: register state
16:17:26 lte,packet,raw lte1 mbim: wdm <<< send #12
16:17:26 lte,packet,raw lte1 mbim: 03000000 40000000 0c000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:26 lte,packet,raw lte1 mbim: wdm >>> recv #12
16:17:26 lte,packet,raw lte1 mbim: 03000080 60000000 0c000000 01000000
16:17:26 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:26 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:26 lte,debug lte1 mbim: >>> D - connect: register state
16:17:26 lte,debug lte1 mbim: register state: deregistered
16:17:26 lte,debug lte1 mbim: state 10=>11
16:17:26 lte,debug lte1 mbim: set radio: on
16:17:26 lte,packet,raw lte1 mbim: wdm <<< send #13
16:17:26 lte,packet,raw lte1 mbim: 03000000 34000000 0d000000 01000000
16:17:26 lte,packet lte1 mbim: 01000000 01000000
16:17:26 lte,packet,raw lte1 mbim: wdm >>> recv #13
16:17:26 lte,packet,raw lte1 mbim: 03000080 38000000 0d000000 01000000
16:17:26 lte,debug lte1 mbim: register state: searching
16:17:26 lte,debug lte1 mbim: state 11=>12
16:17:27 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:27 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:27 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:27 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 04000000
16:17:27 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:28 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:28 lte,packet,raw lte1 mbim: 07000080 78000000 00000000 01000000
16:17:28 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:28 lte,packet,raw lte1 mbim: c2aae6df 09000000 4c000000 00000000
16:17:28 lte,packet,raw lte1 mbim: 03000000 01000000 20000000 01000000
16:17:28 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 10000000
16:17:28 lte,packet,raw lte1 mbim: 00000000 00000000 02000000 33003100
16:17:28 lte,packet,raw lte1 mbim: 30003200 36003000 54002d00 4d006f00
16:17:28 lte,packet,raw lte1 mbim: 62006900 6c006500
16:17:28 lte,debug lte1 mbim: >>> N - connect: register state
16:17:28 lte,packet lte1 mbim: status data:
16:17:28 lte,packet lte1 mbim: 00000000 03000000 01000000 20000000
16:17:28 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
16:17:28 lte,packet lte1 mbim: 10000000 00000000 00000000 02000000
16:17:28 lte,packet lte1 mbim: 33003100 30003200 36003000 54002d00
16:17:28 lte,packet lte1 mbim: 4d006f00 62006900 6c006500
16:17:28 lte,debug lte1 mbim: register state: home, gsm operator: 310260, T-Mobile, avail data classes: 0x20
16:17:28 lte,debug lte1 mbim: state 12=>14
16:17:28 lte,debug lte1 mbim: waiting for auto attach
16:17:28 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:28 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:28 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:28 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:28 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:28 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:28 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:28 lte,debug lte1 mbim: state 14=>16
16:17:28 lte,packet,raw lte1 mbim: 02000000 20000000 80f0fa02 00000000
16:17:28 lte,packet,raw lte1 mbim: 00e1f505 00000000
16:17:28 lte,packet lte1 mbim: 00000000 02000000 20000000 80f0fa02
16:17:28 lte,packet lte1 mbim: 00000000 00e1f505 00000000
16:17:28 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
16:17:28 lte,debug lte1 mbim: state 16=>17
16:17:29 lte,debug lte1 mbim: do connect activate #0
16:17:29 lte,debug lte1 mbim: apn: Mobilenet iptype: 0
16:17:29 lte,debug lte1 mbim: <<< S - connect: connect
16:17:29 lte,packet,raw lte1 mbim: wdm <<< send #14
16:17:29 lte,packet,raw lte1 mbim: 03000000 80000000 0e000000 01000000
16:17:29 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:29 lte,packet,raw lte1 mbim: c2aae6df 0c000000 01000000 50000000
16:17:29 lte,packet,raw lte1 mbim: 00000000 01000000 3c000000 12000000
16:17:29 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:29 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 7e5e2a7e
16:17:29 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 4d006f00
16:17:29 lte,packet,raw lte1 mbim: 62006900 6c006500 6e006500 74000000
16:17:29 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:29 lte,packet,raw lte1 mbim: 07000080 50000000 00000000 01000000
16:17:29 lte,packet,raw lte1 mbim: c2aae6df 0c000000 24000000 00000000
16:17:29 lte,packet,raw lte1 mbim: 02000000 00000000 01000000 7e5e2a7e
16:17:29 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 00000000
16:17:29 lte,debug lte1 mbim: >>> N - connect: connect
16:17:29 lte,packet lte1 mbim: status data:
16:17:29 lte,packet lte1 mbim: 00000000 02000000 00000000 01000000
16:17:29 lte,packet lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:29 lte,debug lte1 mbim: connect: #0 activating, nwe:
16:17:29 lte,debug lte1 mbim: waiting for done
16:17:29 lte,packet,raw lte1 mbim: wdm >>> recv #14
16:17:29 lte,packet,raw lte1 mbim: 03000080 54000000 0e000000 01000000
16:17:29 lte,packet,raw lte1 mbim: c2aae6df 0c000000 02000000 24000000
16:17:29 lte,packet,raw lte1 mbim: 00000000 03000000 00000000 00000000
16:17:29 lte,packet,raw lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:29 lte,debug lte1 mbim: >>> E - connect: connect, error: FAILURE
16:17:29 lte,packet lte1 mbim: 00000000 03000000 00000000 00000000
16:17:29 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
16:17:30 lte,debug lte1 mbim: all bearers failed, restarting
16:17:30 lte,debug lte1 mbim: state 17=>5
16:17:30 lte,debug lte1 mbim: set radio: off
16:17:30 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:30 lte,packet,raw lte1 mbim: wdm <<< send #15
16:17:30 lte,packet,raw lte1 mbim: 03000000 34000000 0f000000 01000000
16:17:30 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:30 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:30 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:30 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:30 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:17:30 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:30 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:30 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:30 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:17:30 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:30 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:30 lte,packet lte1 mbim: status data:
16:17:30 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:17:30 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:30 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:17:30 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:30 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:30 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:30 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:30 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:30 lte,debug lte1 mbim: >>> N - connect: register state
16:17:30 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:30 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:30 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:30 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:30 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:31 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:31 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:31 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:31 lte,packet lte1 mbim: status data:
16:17:31 lte,packet lte1 mbim: 01000000 00000000
16:17:31 lte,packet,raw lte1 mbim: wdm >>> recv #15
16:17:31 lte,packet,raw lte1 mbim: 03000080 38000000 0f000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:31 lte,packet,raw lte1 mbim: 01000000 00000000
16:17:31 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:31 lte,debug lte1 mbim: state 5=>6
16:17:31 lte,debug lte1 mbim: state 6=>7
16:17:31 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:31 lte,packet,raw lte1 mbim: wdm <<< send #16
16:17:31 lte,packet,raw lte1 mbim: 03000000 30000000 10000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:31 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:31 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:31 lte,debug lte1 mbim: >>> N - connect: register state
16:17:31 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:31 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:31 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:31 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:31 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:31 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:31 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:31 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:31 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:31 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:31 lte,debug lte1 mbim: sms service center +12063130004
16:17:31 lte,packet,raw lte1 mbim: wdm >>> recv #16
16:17:31 lte,packet,raw lte1 mbim: 03000080 b4000000 10000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:31 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:31 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:31 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:31 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:31 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:31 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:31 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:31 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:31 lte,packet,raw lte1 mbim: 30004600
16:17:31 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:31 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:31 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:31 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:31 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:31 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:31 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:31 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:31 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:31 lte,packet lte1 mbim: 30004600
16:17:31 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:31 lte,debug lte1 mbim: state 7=>10
16:17:31 lte,debug lte1 mbim: request register, operator: [auto]
16:17:31 lte,debug lte1 mbim: <<< S - connect: register state
16:17:31 lte,packet,raw lte1 mbim: wdm <<< send #17
16:17:31 lte,packet,raw lte1 mbim: 03000000 40000000 11000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:31 lte,packet,raw lte1 mbim: wdm >>> recv #17
16:17:31 lte,packet,raw lte1 mbim: 03000080 60000000 11000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:31 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:31 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:31 lte,debug lte1 mbim: >>> D - connect: register state
16:17:31 lte,debug lte1 mbim: register state: deregistered
16:17:31 lte,debug lte1 mbim: state 10=>11
16:17:31 lte,debug lte1 mbim: set radio: on
16:17:31 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:31 lte,packet,raw lte1 mbim: wdm <<< send #18
16:17:31 lte,packet,raw lte1 mbim: 03000000 34000000 12000000 01000000
16:17:31 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:31 lte,packet lte1 mbim: 01000000 01000000
16:17:31 lte,packet,raw lte1 mbim: wdm >>> recv #18
16:17:31 lte,packet,raw lte1 mbim: 03000080 38000000 12000000 01000000
16:17:31 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:31 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:31 lte,debug lte1 mbim: register state: searching
16:17:31 lte,debug lte1 mbim: state 11=>12
16:17:32 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:32 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:32 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:32 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 04000000
16:17:32 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:32 lte,packet,raw lte1 mbim: 07000080 78000000 00000000 01000000
16:17:32 lte,packet,raw lte1 mbim: c2aae6df 09000000 4c000000 00000000
16:17:32 lte,packet,raw lte1 mbim: 03000000 01000000 20000000 01000000
16:17:32 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 10000000
16:17:32 lte,packet,raw lte1 mbim: 00000000 00000000 02000000 33003100
16:17:32 lte,packet,raw lte1 mbim: 30003200 36003000 54002d00 4d006f00
16:17:32 lte,packet,raw lte1 mbim: 62006900 6c006500
16:17:32 lte,debug lte1 mbim: >>> N - connect: register state
16:17:32 lte,packet lte1 mbim: status data:
16:17:32 lte,packet lte1 mbim: 00000000 03000000 01000000 20000000
16:17:32 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
16:17:32 lte,packet lte1 mbim: 10000000 00000000 00000000 02000000
16:17:32 lte,packet lte1 mbim: 33003100 30003200 36003000 54002d00
16:17:32 lte,packet lte1 mbim: 4d006f00 62006900 6c006500
16:17:32 lte,debug lte1 mbim: register state: home, gsm operator: 310260, T-Mobile, avail data classes: 0x20
16:17:32 lte,debug lte1 mbim: state 12=>14
16:17:32 lte,debug lte1 mbim: waiting for auto attach
16:17:32 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:32 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:32 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:32 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:32 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:32 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:32 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:32 lte,debug lte1 mbim: state 14=>16
16:17:32 lte,async lte1: sent AT E0 V1
16:17:33 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:33 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:33 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:33 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:33 lte,packet,raw lte1 mbim: 02000000 20000000 80f0fa02 00000000
16:17:33 lte,packet,raw lte1 mbim: 00e1f505 00000000
16:17:33 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:33 lte,packet lte1 mbim: status data:
16:17:33 lte,packet lte1 mbim: 00000000 02000000 20000000 80f0fa02
16:17:33 lte,packet lte1 mbim: 00000000 00e1f505 00000000
16:17:33 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
16:17:33 lte,debug lte1 mbim: state 16=>17
16:17:34 lte,debug lte1 mbim: do connect activate #0
16:17:34 lte,debug lte1 mbim: apn: Mobilenet iptype: 0
16:17:34 lte,debug lte1 mbim: <<< S - connect: connect
16:17:34 lte,packet,raw lte1 mbim: wdm <<< send #19
16:17:34 lte,packet,raw lte1 mbim: 03000000 80000000 13000000 01000000
16:17:34 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:34 lte,packet,raw lte1 mbim: c2aae6df 0c000000 01000000 50000000
16:17:34 lte,packet,raw lte1 mbim: 00000000 01000000 3c000000 12000000
16:17:34 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:34 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 7e5e2a7e
16:17:34 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 4d006f00
16:17:34 lte,packet,raw lte1 mbim: 62006900 6c006500 6e006500 74000000
16:17:34 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:34 lte,packet,raw lte1 mbim: 07000080 50000000 00000000 01000000
16:17:34 lte,packet,raw lte1 mbim: c2aae6df 0c000000 24000000 00000000
16:17:34 lte,packet,raw lte1 mbim: 02000000 00000000 01000000 7e5e2a7e
16:17:34 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 00000000
16:17:34 lte,debug lte1 mbim: >>> N - connect: connect
16:17:34 lte,packet lte1 mbim: status data:
16:17:34 lte,packet lte1 mbim: 00000000 02000000 00000000 01000000
16:17:34 lte,packet lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:34 lte,debug lte1 mbim: connect: #0 activating, nwe:
16:17:34 lte,debug lte1 mbim: waiting for done
16:17:34 lte,packet,raw lte1 mbim: wdm >>> recv #19
16:17:34 lte,packet,raw lte1 mbim: 03000080 54000000 13000000 01000000
16:17:34 lte,packet,raw lte1 mbim: c2aae6df 0c000000 02000000 24000000
16:17:34 lte,packet,raw lte1 mbim: 00000000 03000000 00000000 00000000
16:17:34 lte,packet,raw lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:34 lte,debug lte1 mbim: >>> E - connect: connect, error: FAILURE
16:17:34 lte,packet lte1 mbim: 00000000 03000000 00000000 00000000
16:17:34 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
16:17:35 lte,debug lte1 mbim: all bearers failed, restarting
16:17:35 lte,debug lte1 mbim: state 17=>5
16:17:35 lte,debug lte1 mbim: set radio: off
16:17:35 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:35 lte,packet,raw lte1 mbim: wdm <<< send #20
16:17:35 lte,packet,raw lte1 mbim: 03000000 34000000 14000000 01000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:35 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:35 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:17:35 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:35 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:35 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:35 lte,packet lte1 mbim: status data:
16:17:35 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:17:35 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:35 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:17:35 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:35 lte,debug lte1 mbim: >>> N - connect: register state
16:17:35 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:35 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:35 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:35 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:35 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:35 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:35 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:35 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:35 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:35 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:35 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:35 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:35 lte,debug lte1 mbim: sms service center +12063130004
16:17:35 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:35 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:35 lte,packet,raw lte1 mbim: wdm >>> recv #20
16:17:35 lte,packet,raw lte1 mbim: 03000080 38000000 14000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:35 lte,packet,raw lte1 mbim: 01000000 00000000
16:17:35 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:35 lte,debug lte1 mbim: state 5=>6
16:17:35 lte,debug lte1 mbim: state 6=>7
16:17:35 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:35 lte,packet,raw lte1 mbim: wdm <<< send #21
16:17:35 lte,packet,raw lte1 mbim: 03000000 30000000 15000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:35 lte,packet,raw lte1 mbim: wdm >>> recv #21
16:17:35 lte,packet,raw lte1 mbim: 03000080 b4000000 15000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:35 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:35 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:35 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:35 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:35 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:35 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:35 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:35 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:35 lte,packet,raw lte1 mbim: 30004600
16:17:35 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:35 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:35 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:35 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:35 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:35 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:35 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:35 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:35 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:35 lte,packet lte1 mbim: 30004600
16:17:35 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:35 lte,debug lte1 mbim: state 7=>10
16:17:35 lte,debug lte1 mbim: request register, operator: [auto]
16:17:35 lte,debug lte1 mbim: <<< S - connect: register state
16:17:35 lte,packet,raw lte1 mbim: wdm <<< send #22
16:17:35 lte,packet,raw lte1 mbim: 03000000 40000000 16000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:35 lte,packet,raw lte1 mbim: wdm >>> recv #22
16:17:35 lte,packet,raw lte1 mbim: 03000080 60000000 16000000 01000000
16:17:35 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:35 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:35 lte,debug lte1 mbim: >>> D - connect: register state
16:17:35 lte,debug lte1 mbim: register state: deregistered
16:17:35 lte,debug lte1 mbim: state 10=>11
16:17:35 lte,debug lte1 mbim: set radio: on
16:17:35 lte,packet,raw lte1 mbim: wdm <<< send #23
16:17:35 lte,packet,raw lte1 mbim: 03000000 34000000 17000000 01000000
16:17:35 lte,packet lte1 mbim: 01000000 01000000
16:17:35 lte,packet,raw lte1 mbim: wdm >>> recv #23
16:17:35 lte,packet,raw lte1 mbim: 03000080 38000000 17000000 01000000
16:17:35 lte,debug lte1 mbim: register state: searching
16:17:35 lte,debug lte1 mbim: state 11=>12
16:17:36 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:36 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:36 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:36 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 05000000
16:17:36 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:36 lte,packet,raw lte1 mbim: 07000080 78000000 00000000 01000000
16:17:36 lte,packet,raw lte1 mbim: c2aae6df 09000000 4c000000 00000000
16:17:36 lte,packet,raw lte1 mbim: 03000000 01000000 20000000 01000000
16:17:36 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 10000000
16:17:36 lte,packet,raw lte1 mbim: 00000000 00000000 02000000 33003100
16:17:36 lte,packet,raw lte1 mbim: 30003200 36003000 54002d00 4d006f00
16:17:36 lte,packet,raw lte1 mbim: 62006900 6c006500
16:17:36 lte,debug lte1 mbim: >>> N - connect: register state
16:17:36 lte,packet lte1 mbim: status data:
16:17:36 lte,packet lte1 mbim: 00000000 03000000 01000000 20000000
16:17:36 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
16:17:36 lte,packet lte1 mbim: 10000000 00000000 00000000 02000000
16:17:36 lte,packet lte1 mbim: 33003100 30003200 36003000 54002d00
16:17:36 lte,packet lte1 mbim: 4d006f00 62006900 6c006500
16:17:36 lte,debug lte1 mbim: register state: home, gsm operator: 310260, T-Mobile, avail data classes: 0x20
16:17:36 lte,debug lte1 mbim: state 12=>14
16:17:36 lte,debug lte1 mbim: waiting for auto attach
16:17:36 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:36 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:36 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:36 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:36 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:36 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:36 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:36 lte,debug lte1 mbim: state 14=>16
16:17:37 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:37 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:37 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:37 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:37 lte,packet,raw lte1 mbim: 02000000 20000000 80f0fa02 00000000
16:17:37 lte,packet,raw lte1 mbim: 00e1f505 00000000
16:17:37 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:37 lte,packet lte1 mbim: status data:
16:17:37 lte,packet lte1 mbim: 00000000 02000000 20000000 80f0fa02
16:17:37 lte,packet lte1 mbim: 00000000 00e1f505 00000000
16:17:37 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
16:17:37 lte,debug lte1 mbim: state 16=>17
16:17:38 lte,debug lte1 mbim: do connect activate #0
16:17:38 lte,debug lte1 mbim: apn: Mobilenet iptype: 0
16:17:38 lte,debug lte1 mbim: <<< S - connect: connect
16:17:38 lte,packet,raw lte1 mbim: wdm <<< send #24
16:17:38 lte,packet,raw lte1 mbim: 03000000 80000000 18000000 01000000
16:17:38 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:38 lte,packet,raw lte1 mbim: c2aae6df 0c000000 01000000 50000000
16:17:38 lte,packet,raw lte1 mbim: 00000000 01000000 3c000000 12000000
16:17:38 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:38 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 7e5e2a7e
16:17:38 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 4d006f00
16:17:38 lte,packet,raw lte1 mbim: 62006900 6c006500 6e006500 74000000
16:17:38 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:38 lte,packet,raw lte1 mbim: 07000080 50000000 00000000 01000000
16:17:38 lte,packet,raw lte1 mbim: c2aae6df 0c000000 24000000 00000000
16:17:38 lte,packet,raw lte1 mbim: 02000000 00000000 01000000 7e5e2a7e
16:17:38 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 00000000
16:17:38 lte,debug lte1 mbim: >>> N - connect: connect
16:17:38 lte,packet lte1 mbim: status data:
16:17:38 lte,packet lte1 mbim: 00000000 02000000 00000000 01000000
16:17:38 lte,packet lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:38 lte,debug lte1 mbim: connect: #0 activating, nwe:
16:17:38 lte,debug lte1 mbim: waiting for done
16:17:38 lte,packet,raw lte1 mbim: wdm >>> recv #24
16:17:38 lte,packet,raw lte1 mbim: 03000080 54000000 18000000 01000000
16:17:38 lte,packet,raw lte1 mbim: c2aae6df 0c000000 02000000 24000000
16:17:38 lte,packet,raw lte1 mbim: 00000000 03000000 00000000 00000000
16:17:38 lte,packet,raw lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:38 lte,debug lte1 mbim: >>> E - connect: connect, error: FAILURE
16:17:38 lte,packet lte1 mbim: 00000000 03000000 00000000 00000000
16:17:38 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
16:17:39 lte,debug lte1 mbim: all bearers failed, restarting
16:17:39 lte,debug lte1 mbim: state 17=>5
16:17:39 lte,debug lte1 mbim: set radio: off
16:17:39 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:39 lte,packet,raw lte1 mbim: wdm <<< send #25
16:17:39 lte,packet,raw lte1 mbim: 03000000 34000000 19000000 01000000
16:17:39 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:39 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:39 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:39 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:39 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:39 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:39 lte,packet lte1 mbim: status data:
16:17:39 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:39 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:39 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:39 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:17:39 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:39 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:39 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:39 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:39 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:39 lte,debug lte1 mbim: >>> N - connect: register state
16:17:39 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:39 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:39 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:39 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:39 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:39 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:17:39 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:17:39 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:17:39 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:39 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:39 lte,packet,raw lte1 mbim: wdm >>> recv #25
16:17:39 lte,packet,raw lte1 mbim: 03000080 38000000 19000000 01000000
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:39 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:39 lte,debug lte1 mbim: state 5=>6
16:17:39 lte,debug lte1 mbim: state 6=>7
16:17:39 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:39 lte,packet,raw lte1 mbim: wdm <<< send #26
16:17:39 lte,packet,raw lte1 mbim: 03000000 30000000 1a000000 01000000
16:17:39 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:40 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:40 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:40 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:40 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:40 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:40 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:40 lte,packet lte1 mbim: status data:
16:17:40 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:40 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:40 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:40 lte,debug lte1 mbim: sms service center +12063130004
16:17:40 lte,packet,raw lte1 mbim: wdm >>> recv #26
16:17:40 lte,packet,raw lte1 mbim: 03000080 b4000000 1a000000 01000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:40 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:40 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:40 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:40 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:40 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:40 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:40 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:40 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:40 lte,packet,raw lte1 mbim: 30004600
16:17:40 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:40 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:40 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:40 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:40 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:40 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:40 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:40 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:40 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:40 lte,packet lte1 mbim: 30004600
16:17:40 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:40 lte,debug lte1 mbim: state 7=>10
16:17:40 lte,debug lte1 mbim: request register, operator: [auto]
16:17:40 lte,debug lte1 mbim: <<< S - connect: register state
16:17:40 lte,packet,raw lte1 mbim: wdm <<< send #27
16:17:40 lte,packet,raw lte1 mbim: 03000000 40000000 1b000000 01000000
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:40 lte,packet,raw lte1 mbim: wdm >>> recv #27
16:17:40 lte,packet,raw lte1 mbim: 03000080 60000000 1b000000 01000000
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:40 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:40 lte,debug lte1 mbim: >>> D - connect: register state
16:17:40 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:40 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:40 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:40 lte,debug lte1 mbim: register state: deregistered
16:17:40 lte,debug lte1 mbim: state 10=>11
16:17:40 lte,debug lte1 mbim: set radio: on
16:17:40 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:40 lte,packet,raw lte1 mbim: wdm <<< send #28
16:17:40 lte,packet,raw lte1 mbim: 03000000 34000000 1c000000 01000000
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:40 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:40 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:40 lte,packet lte1 mbim: 01000000 01000000
16:17:40 lte,packet,raw lte1 mbim: wdm >>> recv #28
16:17:40 lte,packet,raw lte1 mbim: 03000080 38000000 1c000000 01000000
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:40 lte,packet,raw lte1 mbim: 01000000 01000000
16:17:40 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:40 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:40 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:40 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:40 lte,debug lte1 mbim: >>> N - connect: register state
16:17:40 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:40 lte,debug lte1 mbim: register state: searching
16:17:40 lte,debug lte1 mbim: state 11=>12
16:17:41 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:41 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:41 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:41 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 05000000
16:17:41 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:41 lte,packet,raw lte1 mbim: 07000080 78000000 00000000 01000000
16:17:41 lte,packet,raw lte1 mbim: c2aae6df 09000000 4c000000 00000000
16:17:41 lte,packet,raw lte1 mbim: 03000000 01000000 20000000 01000000
16:17:41 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 10000000
16:17:41 lte,packet,raw lte1 mbim: 00000000 00000000 02000000 33003100
16:17:41 lte,packet,raw lte1 mbim: 30003200 36003000 54002d00 4d006f00
16:17:41 lte,packet,raw lte1 mbim: 62006900 6c006500
16:17:41 lte,debug lte1 mbim: >>> N - connect: register state
16:17:41 lte,packet lte1 mbim: status data:
16:17:41 lte,packet lte1 mbim: 00000000 03000000 01000000 20000000
16:17:41 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
16:17:41 lte,packet lte1 mbim: 10000000 00000000 00000000 02000000
16:17:41 lte,packet lte1 mbim: 33003100 30003200 36003000 54002d00
16:17:41 lte,packet lte1 mbim: 4d006f00 62006900 6c006500
16:17:41 lte,debug lte1 mbim: register state: home, gsm operator: 310260, T-Mobile, avail data classes: 0x20
16:17:41 lte,debug lte1 mbim: state 12=>14
16:17:41 lte,debug lte1 mbim: waiting for auto attach
16:17:41 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:41 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:41 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:41 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:41 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:41 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:41 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:41 lte,debug lte1 mbim: state 14=>16
16:17:41 lte,packet,raw lte1 mbim: 02000000 20000000 80f0fa02 00000000
16:17:41 lte,packet,raw lte1 mbim: 00e1f505 00000000
16:17:41 lte,packet lte1 mbim: 00000000 02000000 20000000 80f0fa02
16:17:41 lte,packet lte1 mbim: 00000000 00e1f505 00000000
16:17:41 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
16:17:41 lte,debug lte1 mbim: state 16=>17
16:17:42 lte,debug lte1 mbim: do connect activate #0
16:17:42 lte,debug lte1 mbim: apn: Mobilenet iptype: 0
16:17:42 lte,debug lte1 mbim: <<< S - connect: connect
16:17:42 lte,packet,raw lte1 mbim: wdm <<< send #29
16:17:42 lte,packet,raw lte1 mbim: 03000000 80000000 1d000000 01000000
16:17:42 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:42 lte,packet,raw lte1 mbim: c2aae6df 0c000000 01000000 50000000
16:17:42 lte,packet,raw lte1 mbim: 00000000 01000000 3c000000 12000000
16:17:42 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:42 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 7e5e2a7e
16:17:42 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 4d006f00
16:17:42 lte,packet,raw lte1 mbim: 62006900 6c006500 6e006500 74000000
16:17:42 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:42 lte,packet,raw lte1 mbim: 07000080 50000000 00000000 01000000
16:17:42 lte,packet,raw lte1 mbim: c2aae6df 0c000000 24000000 00000000
16:17:42 lte,packet,raw lte1 mbim: 02000000 00000000 01000000 7e5e2a7e
16:17:42 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 00000000
16:17:42 lte,debug lte1 mbim: >>> N - connect: connect
16:17:42 lte,packet lte1 mbim: status data:
16:17:42 lte,packet lte1 mbim: 00000000 02000000 00000000 01000000
16:17:42 lte,packet lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:42 lte,debug lte1 mbim: connect: #0 activating, nwe:
16:17:42 lte,debug lte1 mbim: waiting for done
16:17:42 lte,packet,raw lte1 mbim: wdm >>> recv #29
16:17:42 lte,packet,raw lte1 mbim: 03000080 54000000 1d000000 01000000
16:17:42 lte,packet,raw lte1 mbim: c2aae6df 0c000000 02000000 24000000
16:17:42 lte,packet,raw lte1 mbim: 00000000 03000000 00000000 00000000
16:17:42 lte,packet,raw lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:42 lte,debug lte1 mbim: >>> E - connect: connect, error: FAILURE
16:17:42 lte,packet lte1 mbim: 00000000 03000000 00000000 00000000
16:17:42 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
16:17:43 lte,debug lte1 mbim: all bearers failed, restarting
16:17:43 lte,debug lte1 mbim: state 17=>5
16:17:43 lte,debug lte1 mbim: set radio: off
16:17:43 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:43 lte,packet,raw lte1 mbim: wdm <<< send #30
16:17:43 lte,packet,raw lte1 mbim: 03000000 34000000 1e000000 01000000
16:17:43 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:43 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:43 lte,async lte1: sent AT E0 V1
16:17:43 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:43 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:43 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:17:43 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:44 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:44 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:44 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:44 lte,packet lte1 mbim: status data:
16:17:44 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:17:44 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:44 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:17:44 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:44 lte,debug lte1 mbim: >>> N - connect: register state
16:17:44 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:44 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:44 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:44 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:44 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:44 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:44 lte,packet,raw lte1 mbim: wdm >>> recv #30
16:17:44 lte,packet,raw lte1 mbim: 03000080 38000000 1e000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:44 lte,packet,raw lte1 mbim: 01000000 00000000
16:17:44 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:44 lte,debug lte1 mbim: state 5=>6
16:17:44 lte,debug lte1 mbim: state 6=>7
16:17:44 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:44 lte,packet,raw lte1 mbim: wdm <<< send #31
16:17:44 lte,packet,raw lte1 mbim: 03000000 30000000 1f000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:44 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:44 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:44 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:44 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:44 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:44 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:44 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:44 lte,debug lte1 mbim: sms service center +12063130004
16:17:44 lte,packet,raw lte1 mbim: wdm >>> recv #31
16:17:44 lte,packet,raw lte1 mbim: 03000080 b4000000 1f000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:44 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:44 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:44 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:44 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:44 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:44 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:44 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:44 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:44 lte,packet,raw lte1 mbim: 30004600
16:17:44 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:44 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:44 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:44 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:44 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:44 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:44 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:44 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:44 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:44 lte,packet lte1 mbim: 30004600
16:17:44 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:44 lte,debug lte1 mbim: state 7=>10
16:17:44 lte,debug lte1 mbim: request register, operator: [auto]
16:17:44 lte,debug lte1 mbim: <<< S - connect: register state
16:17:44 lte,packet,raw lte1 mbim: wdm <<< send #32
16:17:44 lte,packet,raw lte1 mbim: 03000000 40000000 20000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:44 lte,packet,raw lte1 mbim: wdm >>> recv #32
16:17:44 lte,packet,raw lte1 mbim: 03000080 60000000 20000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:44 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:44 lte,debug lte1 mbim: >>> D - connect: register state
16:17:44 lte,debug lte1 mbim: register state: deregistered
16:17:44 lte,debug lte1 mbim: state 10=>11
16:17:44 lte,debug lte1 mbim: set radio: on
16:17:44 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:44 lte,packet,raw lte1 mbim: wdm <<< send #33
16:17:44 lte,packet,raw lte1 mbim: 03000000 34000000 21000000 01000000
16:17:44 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:44 lte,packet lte1 mbim: 01000000 01000000
16:17:44 lte,packet,raw lte1 mbim: wdm >>> recv #33
16:17:44 lte,packet,raw lte1 mbim: 03000080 38000000 21000000 01000000
16:17:44 lte,debug lte1 mbim: register state: searching
16:17:44 lte,debug lte1 mbim: state 11=>12
16:17:45 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:45 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:45 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:45 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 05000000
16:17:45 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:45 lte,packet,raw lte1 mbim: 07000080 78000000 00000000 01000000
16:17:45 lte,packet,raw lte1 mbim: c2aae6df 09000000 4c000000 00000000
16:17:45 lte,packet,raw lte1 mbim: 03000000 01000000 20000000 01000000
16:17:45 lte,packet,raw lte1 mbim: 30000000 0c000000 3c000000 10000000
16:17:45 lte,packet,raw lte1 mbim: 00000000 00000000 02000000 33003100
16:17:45 lte,packet,raw lte1 mbim: 30003200 36003000 54002d00 4d006f00
16:17:45 lte,packet,raw lte1 mbim: 62006900 6c006500
16:17:45 lte,debug lte1 mbim: >>> N - connect: register state
16:17:45 lte,packet lte1 mbim: status data:
16:17:45 lte,packet lte1 mbim: 00000000 03000000 01000000 20000000
16:17:45 lte,packet lte1 mbim: 01000000 30000000 0c000000 3c000000
16:17:45 lte,packet lte1 mbim: 10000000 00000000 00000000 02000000
16:17:45 lte,packet lte1 mbim: 33003100 30003200 36003000 54002d00
16:17:45 lte,packet lte1 mbim: 4d006f00 62006900 6c006500
16:17:45 lte,debug lte1 mbim: register state: home, gsm operator: 310260, T-Mobile, avail data classes: 0x20
16:17:45 lte,debug lte1 mbim: state 12=>14
16:17:45 lte,debug lte1 mbim: waiting for auto attach
16:17:46 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:46 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:46 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:46 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:46 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:46 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:46 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:46 lte,packet lte1 mbim: status data:
16:17:46 lte,packet lte1 mbim: 00000000 01000000 00000000 00000000
16:17:46 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:46 lte,debug lte1 mbim: packet service: attaching data class: 0 nwe:
16:17:46 lte,debug lte1 mbim: state 14=>16
16:17:46 lte,packet,raw lte1 mbim: 02000000 20000000 80f0fa02 00000000
16:17:46 lte,packet,raw lte1 mbim: 00e1f505 00000000
16:17:46 lte,packet lte1 mbim: 00000000 02000000 20000000 80f0fa02
16:17:46 lte,packet lte1 mbim: 00000000 00e1f505 00000000
16:17:46 lte,debug lte1 mbim: packet service: attached data class: LTE nwe:
16:17:46 lte,debug lte1 mbim: state 16=>17
16:17:47 lte,debug lte1 mbim: do connect activate #0
16:17:47 lte,debug lte1 mbim: apn: Mobilenet iptype: 0
16:17:47 lte,debug lte1 mbim: <<< S - connect: connect
16:17:47 lte,packet,raw lte1 mbim: wdm <<< send #34
16:17:47 lte,packet,raw lte1 mbim: 03000000 80000000 22000000 01000000
16:17:47 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:47 lte,packet,raw lte1 mbim: c2aae6df 0c000000 01000000 50000000
16:17:47 lte,packet,raw lte1 mbim: 00000000 01000000 3c000000 12000000
16:17:47 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:47 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 7e5e2a7e
16:17:47 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 4d006f00
16:17:47 lte,packet,raw lte1 mbim: 62006900 6c006500 6e006500 74000000
16:17:47 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:47 lte,packet,raw lte1 mbim: 07000080 50000000 00000000 01000000
16:17:47 lte,packet,raw lte1 mbim: c2aae6df 0c000000 24000000 00000000
16:17:47 lte,packet,raw lte1 mbim: 02000000 00000000 01000000 7e5e2a7e
16:17:47 lte,packet,raw lte1 mbim: 4e6f7272 736b656e 7e5e2a7e 00000000
16:17:47 lte,debug lte1 mbim: >>> N - connect: connect
16:17:47 lte,packet lte1 mbim: status data:
16:17:47 lte,packet lte1 mbim: 00000000 02000000 00000000 01000000
16:17:47 lte,packet lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:47 lte,debug lte1 mbim: connect: #0 activating, nwe:
16:17:47 lte,debug lte1 mbim: waiting for done
16:17:47 lte,packet,raw lte1 mbim: wdm >>> recv #34
16:17:47 lte,packet,raw lte1 mbim: 03000080 54000000 22000000 01000000
16:17:47 lte,packet,raw lte1 mbim: c2aae6df 0c000000 02000000 24000000
16:17:47 lte,packet,raw lte1 mbim: 00000000 03000000 00000000 00000000
16:17:47 lte,packet,raw lte1 mbim: 7e5e2a7e 4e6f7272 736b656e 7e5e2a7e
16:17:47 lte,debug lte1 mbim: >>> E - connect: connect, error: FAILURE
16:17:47 lte,packet lte1 mbim: 00000000 03000000 00000000 00000000
16:17:47 lte,debug lte1 mbim: connect: #0 deactivated, nwe:
16:17:48 lte,debug lte1 mbim: all bearers failed, restarting
16:17:48 lte,debug lte1 mbim: state 17=>5
16:17:48 lte,debug lte1 mbim: set radio: off
16:17:48 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:48 lte,packet,raw lte1 mbim: wdm <<< send #35
16:17:48 lte,packet,raw lte1 mbim: 03000000 34000000 23000000 01000000
16:17:48 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:48 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:50 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:50 lte,packet,raw lte1 mbim: 07000080 40000000 00000000 01000000
16:17:50 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:50 lte,packet,raw lte1 mbim: c2aae6df 0b000000 14000000 63000000
16:17:50 lte,packet,raw lte1 mbim: 63000000 05000000 02000000 ffffffff
16:17:50 lte,packet,raw lte1 mbim: 07000080 48000000 00000000 01000000
16:17:50 lte,packet,raw lte1 mbim: c2aae6df 0a000000 1c000000 00000000
16:17:50 lte,packet,raw lte1 mbim: 04000000 00000000 00000000 00000000
16:17:50 lte,packet,raw lte1 mbim: 00000000 00000000
16:17:50 lte,debug lte1 mbim: >>> N - connect: packet service
16:17:50 lte,packet lte1 mbim: status data:
16:17:50 lte,packet lte1 mbim: 00000000 04000000 00000000 00000000
16:17:50 lte,packet lte1 mbim: 00000000 00000000 00000000
16:17:50 lte,debug lte1 mbim: packet service: detached data class: 0 nwe:
16:17:51 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:51 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:51 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:51 lte,debug lte1 mbim: >>> N - connect: register state
16:17:51 lte,packet lte1 mbim: status data:
16:17:51 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:51 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:51 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:51 lte,packet,raw lte1 mbim: 02000000 01000000 00000000 01000000
16:17:51 lte,packet lte1 mbim: 00000000 02000000 01000000 00000000
16:17:51 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:51 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:51 lte,packet,raw lte1 mbim: wdm >>> recv #35
16:17:51 lte,packet,raw lte1 mbim: 03000080 38000000 23000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:51 lte,packet,raw lte1 mbim: 01000000 00000000
16:17:51 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:51 lte,debug lte1 mbim: state 5=>6
16:17:51 lte,debug lte1 mbim: state 6=>7
16:17:51 lte,debug lte1 mbim: <<< Q - connect: subscriber ready status
16:17:51 lte,packet,raw lte1 mbim: wdm <<< send #36
16:17:51 lte,packet,raw lte1 mbim: 03000000 30000000 24000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 00000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:51 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:51 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:51 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:51 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:51 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:51 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:51 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:51 lte,debug lte1 mbim: sms service center +12063130004
16:17:51 lte,packet,raw lte1 mbim: wdm >>> recv #36
16:17:51 lte,packet,raw lte1 mbim: 03000080 b4000000 24000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 02000000 00000000 84000000
16:17:51 lte,packet,raw lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:51 lte,packet,raw lte1 mbim: 28000000 00000000 01000000 24000000
16:17:51 lte,packet,raw lte1 mbim: 16000000 31003500 33003900 32003100
16:17:51 lte,packet,raw lte1 mbim: 35003100 36003800 31000000 33003100
16:17:51 lte,packet,raw lte1 mbim: 30003200 34003000 32003000 31003300
16:17:51 lte,packet,raw lte1 mbim: 30003800 30003600 39000000 38003900
16:17:51 lte,packet,raw lte1 mbim: 30003100 32003400 30003200 30003400
16:17:51 lte,packet,raw lte1 mbim: 31003100 33003000 38003000 36003900
16:17:51 lte,packet,raw lte1 mbim: 30004600
16:17:51 lte,debug lte1 mbim: >>> D - connect: subscriber ready status
16:17:51 lte,packet lte1 mbim: 01000000 3c000000 1e000000 5c000000
16:17:51 lte,packet lte1 mbim: 28000000 00000000 01000000 24000000
16:17:51 lte,packet lte1 mbim: 16000000 31003500 33003900 32003100
16:17:51 lte,packet lte1 mbim: 35003100 36003800 31000000 33003100
16:17:51 lte,packet lte1 mbim: 30003200 34003000 32003000 31003300
16:17:51 lte,packet lte1 mbim: 30003800 30003600 39000000 38003900
16:17:51 lte,packet lte1 mbim: 30003100 32003400 30003200 30003400
16:17:51 lte,packet lte1 mbim: 31003100 33003000 38003000 36003900
16:17:51 lte,packet lte1 mbim: 30004600
16:17:51 lte,debug lte1 mbim: subscriber ready state: initialized
16:17:51 lte,debug lte1 mbim: state 7=>10
16:17:51 lte,debug lte1 mbim: request register, operator: [auto]
16:17:51 lte,debug lte1 mbim: <<< S - connect: register state
16:17:51 lte,packet,raw lte1 mbim: wdm <<< send #37
16:17:51 lte,packet,raw lte1 mbim: 03000000 40000000 25000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 09000000 01000000 10000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 20000000
16:17:51 lte,packet,raw lte1 mbim: wdm >>> recv #37
16:17:51 lte,packet,raw lte1 mbim: 03000080 60000000 25000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 09000000 00000000 30000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 01000000 01000000 00000000
16:17:51 lte,packet,raw lte1 mbim: 01000000 00000000 00000000 00000000
16:17:51 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 02000000
16:17:51 lte,debug lte1 mbim: >>> D - connect: register state
16:17:51 lte,debug lte1 mbim: register state: deregistered
16:17:51 lte,debug lte1 mbim: state 10=>11
16:17:51 lte,debug lte1 mbim: set radio: on
16:17:51 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:51 lte,packet,raw lte1 mbim: wdm <<< send #38
16:17:51 lte,packet,raw lte1 mbim: 03000000 34000000 26000000 01000000
16:17:51 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:51 lte,packet lte1 mbim: 01000000 01000000
16:17:51 lte,packet,raw lte1 mbim: wdm >>> recv #38
16:17:51 lte,packet,raw lte1 mbim: 03000080 38000000 26000000 01000000
16:17:51 lte,debug lte1 mbim: register state: searching
16:17:51 lte,debug lte1 mbim: state 11=>12
16:17:52 lte,debug lte1 mbim: state 12=>5
16:17:52 lte,debug lte1 mbim: set radio: off
16:17:52 lte,debug lte1 mbim: <<< S - connect: radio state
16:17:52 lte,packet,raw lte1 mbim: wdm <<< send #39
16:17:52 lte,packet,raw lte1 mbim: 03000000 34000000 27000000 01000000
16:17:52 lte,packet,raw lte1 mbim: 00000000 a289cc33 bcbb8b4f b6b0133e
16:17:52 lte,packet,raw lte1 mbim: c2aae6df 03000000 01000000 04000000
16:17:52 lte,packet,raw lte1 mbim: wdm >>> recv #0
16:17:52 lte,packet,raw lte1 mbim: 07000080 34000000 00000000 01000000
16:17:52 lte,packet,raw lte1 mbim: c2aae6df 03000000 08000000 01000000
16:17:52 lte,debug lte1 mbim: >>> N - connect: radio state
16:17:52 lte,packet lte1 mbim: status data:
16:17:52 lte,packet lte1 mbim: 01000000 00000000
16:17:52 lte,packet,raw lte1 mbim: wdm >>> recv #39
16:17:52 lte,packet,raw lte1 mbim: 03000080 38000000 27000000 01000000
16:17:52 lte,packet,raw lte1 mbim: c2aae6df 03000000 00000000 08000000
16:17:52 lte,packet,raw lte1 mbim: 01000000 00000000
16:17:52 lte,debug lte1 mbim: >>> D - connect: radio state
16:17:52 lte,debug lte1 mbim: state 5=>6
16:17:52 lte,packet,raw lte1 mbim: 07000080 5c000000 00000000 01000000
16:17:52 lte,packet,raw lte1 mbim: c2aae6df 09000000 30000000 00000000
16:17:52 lte,packet,raw lte1 mbim: 01000000 01000000 00000000 01000000
16:17:52 lte,packet,raw lte1 mbim: 00000000 00000000 00000000 00000000
16:17:52 lte,packet,raw lte1 mbim: 00000000 00000000 02000000
16:17:52 lte,debug lte1 mbim: >>> N - connect: register state
16:17:52 lte,packet lte1 mbim: 00000000 01000000 01000000 00000000
16:17:52 lte,packet lte1 mbim: 01000000 00000000 00000000 00000000
16:17:52 lte,packet lte1 mbim: 00000000 00000000 00000000 02000000
16:17:52 lte,packet,raw lte1 mbim: 00000000 533fbeeb 14fe4467 9f9033a2
16:17:52 lte,packet,raw lte1 mbim: 23e56c3f 01000000 30000000 01000000
16:17:52 lte,packet,raw lte1 mbim: 00000000 1d010000 00000000 18000000
16:17:52 lte,packet,raw lte1 mbim: 18000000 2b003100 32003000 36003300
16:17:52 lte,packet,raw lte1 mbim: 31003300 30003000 30003400
16:17:52 lte,debug lte1 mbim: >>> N - sms: configuration
16:17:52 lte,packet lte1 mbim: 01000000 00000000 1d010000 00000000
16:17:52 lte,packet lte1 mbim: 18000000 18000000 2b003100 32003000
16:17:52 lte,packet lte1 mbim: 36003300 31003300 30003000 30003400
16:17:52 lte,debug lte1 mbim: sms service center +12063130004
16:17:54 lte,async lte1: sent AT E0 V1
16:18:05 lte,async lte1: sent AT E0 V1
16:18:05 lte,async lte1: rcvd OK
Here are the AT commands I am able to run on the module to show it is connected. I can also move it to my Windows PC and get Internet through T-Mobile so I know it has to be a Mikrotik issue.
CMD: ATI
Quectel
EC25
Revision: EC25AFFAR07A14M4G
CMD: AT+QCFG="usbnet"
+QCFG: "usbnet",2
CMD: AT+QPING=1,"8.8.8.8"
+QPING: 0,"8.8.8.8",32,71,255
+QPING: 0,"8.8.8.8",32,69,255
+QPING: 0,"8.8.8.8",32,67,255
+QPING: 0,"8.8.8.8",32,78,255
+QPING: 0,4,4,0,67,78,71
CMD: AT+COPS?
+COPS: 0,0,"T-Mobile",7
CMD: AT+CREG?
+CREG: 0,1
CMD: AT+CSQ
+CSQ: 21,99
