sweitzel
ATL Kit how to properly connect Ethernet cable?
Sun Apr 14, 2024 12:23 pm
I feel a bit dumb, but what is the intended way of connecting the Ethernet cable through the seal?
The way I do it, just laying it on the seal leaves a gap open, and its quite big so I am afraid some Ants might get in.
BR
Sebastian
jaclaz
Long time Member
Long time Member
Re: ATL Kit how to properly connect Ethernet cable?
Sun Apr 14, 2024 12:46 pm
You should be able to lift the white block and insert the cable under it and press it back into position with cable inside the "hole".
Check this video around 4:00:
https://www.youtube.com/watch?app=desktop&v=ghSPsiOuFzg
Depending on your cable size (if it is too thin), you might need/want to use some electrical tape around it so that it is pressed "tight".
sweitzel
Sun Apr 14, 2024 12:59 pm
Thank you , I wasnt able to find a similar good video!
In the video he didn't lift the block, but simply made a cut to insert the cable.
I was considering this, but would like to get a official answer how this should be done.
Ideally this would be documented as well of course.
jaclaz
Long time Member
Long time Member
Re: ATL Kit how to properly connect Ethernet cable?  [SOLVED]
Sun Apr 14, 2024 2:00 pm
I think the proper word is "grommet", that kind usually comes pre-cut, and (though it is black in the image) it seems like also the Mikrotik one is pre-cut:
https://i.mt.lv/cdn/rb_images/2216_hi_res.png
Maybe your is different?
Maybe it is just a groove that you can cut:
viewtopic.php?p=1028741
viewtopic.php?p=1028741#p1028741
sweitzel
Sun Apr 14, 2024 5:24 pm
Thank you! I will just cut it, also makes sense somehow :)
BR
Sebastian
Users browsing this forum: No registered users and 3 guests
