Network setup
My network uses a Mikrotik hAP ax3 as a router connected to my ISP modem (192.168.1.1). A local DNS server is running with an assigned IP-address of 10.0.0.10.
The router serves as a DHCP server for all clients with an IP-pool in the range of 10.0.0.100 to 10.0.0.254 and a DNS server of 10.0.0.1 (router address).
The Mikrotik DNS server is configured as the ISP modem address, making use of the ISP provided DNS servers by default.
Problem description
I want to make sure all DNS traffic is redirected to the local DNS server using a firewall NAT rule for TCP/UDP traffic on port 53.
I have configured the following firewall NAT rules:
Code: Select all
add action=dst-nat chain=dstnat comment="DNS dst-nat UDP" disabled=no \
dst-port=53 in-interface=bridge-LAN protocol=udp src-address=!10.0.0.10 \
to-addresses=10.0.0.10 to-ports=53
add action=dst-nat chain=dstnat comment="DNS dst-nat TCP" disabled=no \
dst-port=53 in-interface=bridge-LAN protocol=tcp src-address=!10.0.0.10 \
The following behaviour is observed:
- When configuring the DHCP server to provide the DNS address of the Mikrotik router (10.0.0.1), everything works as expected.
- When configuring the DHCP server to provide the DNS address of my local DNS server (10.0.0.10), everything works as expected as well.
- However, if I configure the DHCP server to provide the DNS address of the router and enable the NAT rules then DNS queries are not resolved anymore.
Any help would be much appreciated.
Configuration
RouterOS version is 7.14.2 with RouterBOARD version 7.14.2 using the following configuration:
Code: Select all
# 2024-04-14 10:37:19 by RouterOS 7.14.2
# software id = 2IEW-LXGZ
# model = C53UiG+5HPaxD2HPaxD
# serial number = HEQ09CE89JG
add admin-mac=78:9A:18:05:DA:B5 auto-mac=no name=bridge-LAN port-cost-mode=\
short
set [ find default-name=ether1 ] name=ether1-LAN1
set [ find default-name=ether2 ] name=ether2-LAN2
set [ find default-name=ether3 ] name=ether3-LAN3
set [ find default-name=ether4 ] name=ether4-LAN4
set [ find default-name=ether5 ] name=ether5-WAN
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=2ghz-ax disabled=no name=channel-2.4GHz skip-dfs-channels=10min-cac
add band=5ghz-ax disabled=no name=channel-5GHz skip-dfs-channels=10min-cac
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-home
/interface wifi configuration
add country=Netherlands disabled=no mode=ap name=cfg-home security=sec-home \
ssid=wifi-test
/interface wifi
set [ find default-name=wifi2 ] channel=channel-2.4GHz configuration=cfg-home \
configuration.mode=ap disabled=no name="wifi1-WLAN1 (2.4GHz)" \
security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi1 ] channel=channel-5GHz configuration=cfg-home \
configuration.mode=ap disabled=no name="wifi2-WLAN2 (5GHz)" \
add name=dhcp-pool ranges=10.0.0.100-10.0.0.254
add address-pool=dhcp-pool interface=bridge-LAN lease-time=10m name=\
dhcp-server
/ip smb users
add bridge=bridge-LAN interface=ether1-LAN1 internal-path-cost=10 path-cost=\
10
add bridge=bridge-LAN interface=ether2-LAN2 internal-path-cost=10 path-cost=\
10
add bridge=bridge-LAN interface=ether3-LAN3 internal-path-cost=10 path-cost=\
10
add bridge=bridge-LAN interface=ether4-LAN4 internal-path-cost=10 path-cost=\
10
add bridge=bridge-LAN interface="wifi2-WLAN2 (5GHz)" internal-path-cost=10 \
path-cost=10
add bridge=bridge-LAN interface="wifi1-WLAN1 (2.4GHz)" internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/interface detect-internet
set detect-interface-list=WAN
add interface=bridge-LAN list=LAN
add interface=ether5-WAN list=WAN
add address=10.0.0.1/24 comment=defconf interface=bridge-LAN network=10.0.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=10.0.0.10 comment="Static IP-address for DNS server" mac-address=\
B8:27:EB:4F:FF:D0 server=dhcp-server
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=10.0.0.1
#add address=10.0.0.0/24 dns-server=10.0.0.10 gateway=10.0.0.1
set allow-remote-requests=yes
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=router
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.nl.pool.ntp.org
add address=1.nl.pool.ntp.org
add address=2.nl.pool.ntp.org
add address=3.nl.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
