kleshki
IKEv2 VPN with DNS in another internal VLAN
Mon Apr 15, 2024 10:58 pm
Hi everyone!
Looking for a help in configuring DNS in IKEv2. Internal routing is done via L3-switch. Switch routes traffic through vlan150 to MT. Local network to access through VPN is in vlan100. AD DNS servers are in vlan 200. All addresses are in format 10.vlanid.x.x (e.g. DNS servers are 10.200.0.x, LAN addresses are 10.100.x.x). I do include 10.100.0.0/16 as split-include. Windows clients only accept first split-include, so I can't also include DNS-subnet. Can I add some sort of "virtual" IP to DNS property of split-include, and forward traffic to it internally into the real internal IPs? Like add something like 10.100.255.254 and NAT it to 10.200.0.x?
Here's related configuration parts:
# apr/16/2024 00:22:45 by RouterOS 6.49.13
# software id = 6TTH-KAVK
# model = 2011iL
# serial number = 5BEC04B45E97
/interface bonding
add forced-mac-address=4C:5E:0C:EC:67:2E lacp-rate=1sec mode=802.3ad name=\
    switchLacp slaves=ether4,ether2 transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=switchLacp name=InternetOnly vlan-id=50
add interface=switchLacp name=LAN vlan-id=100
add interface=switchLacp name=Management vlan-id=20
add interface=switchLacp name=RouterGW vlan-id=150
add arp=reply-only interface=switchLacp name=Voice vlan-id=40
add arp=reply-only interface=switchLacp name=WiFi vlan-id=10
add name=Gateway
/ip ipsec policy group
add name=IKEv2
/ip ipsec profile
add enc-algorithm=aes-256,aes-128 hash-algorithm=sha256 name=IKEv2Profile
/ip ipsec peer
add exchange-mode=ike2 local-address=*WHITE_IP* name=IKEv2Peer passive=\
    yes profile=IKEv2Profile
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms="aes-256-cbc,aes-256-ctr\
    ,aes-256-gcm,aes-192-cbc,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,a\
    es-128-gcm" lifetime=1h name=proposal_IKEv2 pfs-group=none
add name=l2tpPool ranges=192.168.230.0/24
add name=IKEv2Pool ranges=192.168.210.2-192.168.210.254
add name=DHCP_InternetOnly ranges=10.50.0.2-10.50.255.254
/ip ipsec mode-config
add address-pool=IKEv2Pool address-prefix-length=16 name=IKE split-include=\
    10.100.0.0/16 static-dns=10.100.0.10 system-dns=no
add address-pool=IKEv2Pool name=ManagementVLAN split-include=10.20.0.0/16
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/certificate settings
set crl-use=yes
/interface l2tp-server server
set authentication=mschap2 default-profile=VPN230 enabled=yes use-ipsec=yes
add interface=ether1 list=Gateway
add address=*WHITE_IP*/25 comment=WAN interface=ether1 network=\
    *ISP_GW*
add address=10.10.0.2/16 interface=WiFi network=10.10.0.0
add address=10.150.0.2/30 interface=RouterGW network=10.150.0.0
add address=10.40.0.1/16 interface=Voice network=10.40.0.0
add address=10.50.0.1/16 interface=InternetOnly network=10.50.0.0
/ip dhcp-client
add disabled=no interface=Management
add disabled=no interface=WiFi
add dhcp-options=clientid disabled=no interface=LAN
/ip firewall address-list
add address=*WHITE_IP* list=RealIP
add address=10.100.0.0/16 list="Hairpin NAT"
add address=10.10.0.0/16 list="Hairpin NAT"
add address=192.168.188.0/24 list="Hairpin NAT"
add action=add-src-to-address-list address-list=port_scanners \
    address-list-timeout=2w chain=input comment="Port scanners to list" \
    in-interface-list=Gateway log=yes protocol=tcp psd=21,3s,3,1
    address-list-timeout=2w chain=input in-interface-list=Gateway protocol=\
    tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
    tcp tcp-flags=fin,syn
    tcp tcp-flags=syn,rst
    tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    tcp tcp-flags=fin,syn,rst,psh,ack,urg
    tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=accept chain=input connection-state=established,related
add action=accept chain=input comment=VPN dst-port=1701,500,4500 protocol=udp
add action=accept chain=input in-interface=Management
add action=drop chain=input
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward in-interface=RouterGW out-interface-list=\
    Gateway
add action=accept chain=forward in-interface=WiFi out-interface-list=Gateway
add action=accept chain=forward in-interface=InternetOnly out-interface-list=\
    Gateway
add action=accept chain=forward comment="Allow NAT" connection-nat-state=\
    dstnat connection-state=new
add action=accept chain=forward comment="L2TP forward rule" in-interface=\
    all-ppp out-interface=LAN
add action=accept chain=forward comment="IKEv2 forward rule" ipsec-policy=\
    in,ipsec out-interface=LAN
add action=accept chain=forward dst-address=10.20.0.0/16 ipsec-policy=\
    in,ipsec
add action=drop chain=forward comment="Drop everything else"
add action=src-nat chain=srcnat out-interface-list=Gateway to-addresses=\
    *WHITE_IP*
add action=src-nat chain=srcnat src-address-list="Hairpin NAT" to-addresses=\
    10.150.0.2
/ip firewall raw
add action=drop chain=prerouting log-prefix="port_scanner drop" \
    src-address-list=port_scanners
add action=drop chain=prerouting src-address-list=Blacklist
/ip ipsec policy
add dst-address=192.168.210.0/24 group=IKEv2 proposal=proposal_IKEv2 \
    src-address=0.0.0.0/0 template=yes
add check-gateway=ping distance=1 gateway=*ISP_GW*
add distance=1 dst-address=10.200.0.0/29 gateway=10.150.0.1 pref-src=\
    10.150.0.2
kleshki
Re: IKEv2 VPN with DNS in another internal VLAN
Wed Apr 17, 2024 11:08 pm
Any ideas on that?
What I've tried so far:
1) Enable DNS on Mikrotik itself, enable remote requests. Add an address on LAN interface. Add FW rule chain input, dst address - LAN ip, protocol udp, port 53 - counters increase on this rule. Pings are ok from VPN to LAN ip (e.g. 10.100.0.250/24). DNS cache is created on mikrotik for responses, but VPN clients doesn't receive response (Powershell Resolve-DnsName -server "Lan ip" "internal record" - returns timeout).
2) Create an address on LAN interface. Add netmap rule from this address to the actual DNS server. Counters increase on this rule, but PS test is same - timeout
abbio90
Sun Apr 21, 2024 10:34 am
set the correct DNS l.ip of vlan200 in the ike conf and create a rule where the traffic coming from ike is destined for the DNS server therefore protocol udp dst-port 53 action masquerade
kleshki
Mon Apr 22, 2024 1:32 pm
How clients would know about this ip (10.200.0.2/29 in my case), if the only route pushed is for vlan100 (10.100.0.0/16)? I know multiple routes is acceptable configuration in MikroTik, but most OSes only take first route into account. Adding a custom route on clients is, well, not very desired solution for the problem.
kleshki
Fri May 03, 2024 2:32 am
Any ideas on how to accomplish this?
LdB
Fri May 03, 2024 6:46 pm
The PPP profile for the VPN sets the DNS and WINS server if need be ... set an address don't leave it blank and the client uses it.
Its the last entries before the radio boxes for Change TCP MSS
kleshki
Fri May 03, 2024 8:21 pm
That's what I'm doing already - in ip/ipsec/mode configs I have System DNS unchecked and manual DNS address is set. It works perfectly fine now, the question is not about this. Here's a visualized setup I have now
The setup works fine for now; however, the red text info is the problem here. Near the IKEv2 client box I'm showing current settings pushed to clients.
I've tried DNS remote requests on mikrotik with RB having IP address in vlan100. When DNS request is received, correct dns record appends to MT dns cache, however the client doesn't receive it - seems like some kind of firewall issue, but adding an input accept rule to udp port 53 didn't do the trick.
Another idea was to somehow have some kind of ghost IP on RB and NAT all DNS traffic to internal servers - dunno if this is even possible, but that's what I'm asking. If it is possible, this looks like a better idea for me, to bypass remote requests feature.
pe1chl
Sat May 04, 2024 12:46 am
Yes of course that is possible, that is just a dst-nat rule (possibly combined with a src-nat rule to translate the source address as well)...
I thought you already tried that.
kleshki
Sat May 04, 2024 9:19 pm
Yes, I've tried that, but maybe did something wrong since it didn't do the job for me. What I did was:
1. 10.100.0.2/16 on LAN interface (vlan100)
2. dst-nat rule protocol=udp dst-port=53 dst-address = 10.100.0.2 action dst-nat to address=10.200.0.2 to port=53 (have an /ip/route to 10.200.0.0/29 through 10.150.0.1 reachable)
Not tried src-nat rule, however I have a hairpin rule in first post and tried adding DC subnet to the list, that didn't work either
kleshki
Mon May 06, 2024 5:34 pm
What I've tried now:
add arp=disabled name=lo protocol-mode=none
add address=10.100.2.0 interface=lo network=10.100.2.0
add action=dst-nat chain=dstnat dst-address=10.100.2.0 dst-port=53 \
    ipsec-policy=in,ipsec protocol=udp to-addresses=10.200.0.2 to-ports=53
10.100.2.0 is pingable through ipsec interface
The last rule I've tried with and without ipsec-policy parameter. The traffic is not passing through the rule.
I also added
add action=accept chain=input connection-nat-state=dstnat connection-state=new log=yes
Now I feel lost at the point
pe1chl
Mon May 06, 2024 5:47 pm
It is impossible to debug such things remotely. All I know is that such constructs work for me.
kleshki
Mon May 06, 2024 7:48 pm
Maybe you can provide an example config with firewall rules and if/ip configuration that works with IPSec, so I can adjust it to my config? That would be nice
kleshki
Tue May 07, 2024 3:17 am
I've added a firewall rule to input chain
add action=accept chain=input connection-nat-state="" connection-state="" ipsec-policy=in,ipsec log=yes
Now in logs I see
input: in:ether1 out:(unknown 0), src-mac 00:00:5e:00:01:0f, proto UDP, 192.168.210.252:57921->10.100.2.0:53, len 73
Why is this packet not catched by dst-nat rule above?
kleshki
Wed May 08, 2024 3:17 pm
While investigating CHR in my test vm, I can see there's input/output chains in NAT in ROS7 now, seems like it's what I'm looking for, but there's no such option in 6.49. Is there any workaround for this or should I upgrade to ROS7?
Users browsing this forum: own3r1138, rscott78, tarfox and 31 guests
