Hello everyone,
my first post here. My networking skills are hmm okay, but this kind of edge case is reaching my limits. Played with Mikrotik in uni, some 8 years ago... I have a funky scenario, I'm not asking for a solution, but more of an answer to a) is my idea absolutely stupid, b) can CCR2004 or CSS326 be used?
Situation:
- I have 6 or 8 or 16 (plenty, numbers varies on number of ports on a router/switch) devices with the *same IP address* (thanks god, they have different MACs), I cannot change IP, data volume is small,
- I have a computer (Linux) which wants to talk to all of them over Ethernet.
My imagined solution:
- grab a router/smart-switch,
- connect devices to separate ports,
- setup each port to a different VLAN, except for one port (used for the computer),
- therefore same IP is not a problem - different VLANs,
- the computer on another port, but since the other devices are on different VLANs, it cannot communicate with them yet,
- so setup some firewall/routing per VLAN - get source IP i.e. 10.10.10.1 + VLAN tag 2, and route them as different IP to my computer, i.e. 10.10.10.1(tag2) becomes 192.168.123.2, 10.10.10.1(t3) becomes 192.168.123.3
- put the computer on. 192.168.123.0/24 network, since now the devices have different IP, they can be easily accessed.
This is such a funky weird case Does this idea make any sense? And can it be done on i.e. CCR2004 or CSS326?
Thanks!
