Zilch
Leaking IPs from one VRF to another VRF?
Fri Apr 26, 2024 10:39 am
Hi all,
I have two VRF's running, main and MTN-Gateway. The former has a gateway IP of 10.255.211.1 and the latter 10.255.212.1.
Each of the VRF's are routing to their own gateway, so I have two WAN interfaces, and two LAN.
So here's the problem: I'd like to be able to access some of the IP's on 'main' from 'MTN-Gateway'.
I am at a loss. I have been trying to sort this for days now, with no luck. Any help would be much appreciated
Zilch
Re: Leaking IPs from one VRF to another VRF?
Fri Apr 26, 2024 11:51 am
Please see the attached snapshots for some idea of my config.
Zilch
Fri Apr 26, 2024 11:54 am
I also tried adding a mangle rule, but I never see any packets traveling through it.
Zilch
Thu May 02, 2024 5:04 pm
I eventually managed to figure it out. It seems the idea I had of routing everything to the subnet was completely off! Instead you have to add a 'prerouting' mangle rule for each subnet and set the correct route-mark. Such as the below...
Users browsing this forum: Bing [Bot], dervomsee, shamet and 32 guests
